  • Bajora
    AA6JB
    • 462
    • Sonoma County, California
    • fredmdbud
      • 450
      Originally posted by Bajora
      Other than the afterburners, was the plane flown stock?
      • fredmdbud
        • 450
        Being enclosed may help in keeping the camera warm enough so that they don't shut-off mid-flight.
        They shouldn't be enclosed - that would block airflow over the heatsinks (exposed metal blocks in the Mobius, the screw-holes on the Mobius Mini).
        That would be a great way to puff the battery and shorten its life.
        • HellHathNoFury
          • 247
          A simple Mod to reduce Elevator Flex .. With only one C/F Rod in the middle running length wise no wonder there is Flex..Click image for larger version  Name:	9E268FCA-82A6-4E87-8DE8-EC30E3E4C9B9.jpeg Views:	0 Size:	73.0 KB ID:	286192
          • PaulZ
            Crashing less
            • 279
            • DFW Area
            All - I have been monitoring and contributing to this thread for a while now and I have to say it is nice to start seeing more and more positive postings. Looks like the doom and gloom crowd is giving way to more excitment with this amazing model. This is definitely one of Freewing/MRC best designes!
            it was a beautiful Sunday evening in Texas yesterday with a packed flying field. I flew the MiG for three hours non-stop, a quick picture attached.
            I have to say I am starting to like the up angle thrust line which puts the model in high alpha at slower speed - it makes the landings amazing!
            Good job Alpha !
            • janmb
              Slow and low
              • 729
              I know you have that problem janmb , I have run into it too!
              Will likely test it out myself! :)
              After some digging I found this for the Mobius. Understand there's a separate version for the Runcam.
              May even end up doing my own version for a Firefly Q6! :)
              This is an aerodynamic box to hold a Mobius ActionCam camera, for mounting on Freewing R/C aircraft weapons pylons. Or, any other object that has the mounting hardware (see notes below). The camera box is offered in TWO versions - one can be mounted under an attachment point, the other can be mounted above an attachment point. An additional two designs are available without the NACA cooling duct (the back of the box is open so cooling air flows through). The box is designed to snugly hold the camera without needing any additional hardware (the camera slides in).DESIGN IS BY GRATEFULFROGI also have a couple of pylons which can be used to extend the camera from the mounting surface, check my other thing files to find those.
              Credit to themudduck !
              Precisely. Unfortunately, it seems it is very sensitive to temperature, so this enclosed mount might indeed help - especially when rear facing
              • janmb
                Slow and low
                • 729
                The run cam doesn't have any. And some of us live in a climate where too much cooling is the problem, not too little
                • Bajora
                  AA6JB
                  • 462
                  As far as I know, the only change out of the box is using the upgraded elevator servos sent to him by MRC.
                  • kallend
                    • 1862
                    Good job Alpha !
                    Be careful with that high alpha due to the thrust line, you can get into a deep stall. From a previous post by GliderGuy:
                    The thrust line is such that once into the high alpha, deep stall, falling leaf realm, adding power only holds the nose up and keeps the alpha high...not recoverable. There is no response to any control input other than throttle.
                      • 8755
                      And herein lies the reason I won't try any extreme high alpha stuff till the plane has VT nozzles on it - no fast dives, either just in case.
                      • HK111
                        • Oct 2020
                        • 52
                        Alpha !
                        Good to hear. For my initial hover tests, it makes things much harder - the plane really pitches up.
                        High time for thrust vectoring :-).
                        • PaulZ
                          Crashing less
                          • 279
                          • DFW Area
                          I actually like it because I can simply use throttle to control the angle of attack. I don't think this plane needs VT but that is all a personal choice.
                          • janmb
                            Slow and low
                            • 729
                            The problem is that this works great - until you overdo it just a tiny touch, and then you are screwed unless you have a lot of altitude to trade.
                            I much prefer a neutrally balanced model that doesn't need neither up elevator nor up thrust line to fly stable high alpha. Which is exactly what my MiG will be once I get VT on it.
                            It definitely flies really well without VT as well, but not being able to push the limits properly in terms of high alpha (yet) is a bit of a bummer, and something I look forward to remedy.
                              • 8755
                              You don't "need" VT until you need it.
                              • f4u ausie
                                • 1230
                                • Melbourne
                                Wow what a fun read. Hope the plane can be sorted
                                • Gringotuerto
                                  • 409
                                  • San Diego
                                  But on the bright side, if you pancake into the ground, you already have a headstart on removing the stock nozzles
                                  • Jet jocky
                                    • Aug 2020
                                    • 44
                                    Got the reinforcement parts epoxied and taped in place waiting to dry. Turning out quit nice. Once the epoxy is dry will paint and reassemble.
                                    • fredmdbud
                                      • 450
                                      If you remove the battery, you'll see circuit boards right next to the vent holes, which are mounted on metal blocks/covers - heatsinks.
                                      And a good number of us live where summers can get pretty hot - not enough cooling.
                                      Click image for larger version  Name:	RC2-01-1__61175.1470711429.1280.1280.jpg Views:	0 Size:	59.9 KB ID:	286318
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1664
                                        • Catalonia
                                        You pretty much always get enough cooling for these cameras once they get flying if they are out in the open.
                                        • fredmdbud
                                          • 450
                                          Not necessarily if they are in fairings as shown in post #3152. Some people have reported that they get warm up enough to start melting hot gun glue.
