  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1688
    • Catalonia
    • jackdcannon
      • 25
      Just received the red star as a surprise gift! Any mods or adjustments right out of the box. Going to use SMC 5200’s. I’ve got several FW jets but this is my first TV, so I don’t think I’ll be using it right away.
        • 2716
        Absolutely USE IT, set it up so you can switch it on or off if you must, but the TV is what makes this special. Without it, you can get it stuck in a high alpha dead drop that is very difficult to get out of without having the TV. Beyond that, it is so much more agile and a pleasure to fly with the TV. Flying this aircraft that has TV nozzles and shutting them off is like dating a world class model and making her wear a garbage bag coving herself head to toe at all times!!
        • jackdcannon
          • 25
          Since it’s my first TV, are there any good videos that help with programming. I have a spectrum dx9 transmitter and haven’t yet bough a receiver for it
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1688
            • Catalonia
            • jackdcannon
              • 25
              Just getting the MiG set up with a10 ch spectrum receiver. Only getting power out of the right side EDF. I have the UBEC plugged into the receiver but the other power lead has the 2 wire, red lead (pic attached)and I’m wondering IFB that needs to be plugged in somewhere. Sorry if this is a noob question but it’s my first twin jet
              • SkyZee
                • Jul 2025
                • 3
                Originally posted by viper1gj
                Does anyone have a photo of the Home Depot touch up paint code for the stock Mig-29 grey color?
                Hi Guys, I realise this is an old thread. I'm trying to colour match the base grey for this as well, and the paint shop has struggled with it after 3 attempts. Does anybody have any paint / mix formulas for it? I'm in Australia, so if anyone has done this with local Australian paint manufacturers (e.g. Dulux, Taubmans) that would be very helpful and appreciated.
                • Alphonso
                  • Aug 2020
                  • 101
                  • Hastings, UK
                  I have sometimes had difficulty getting a scanned match, particularly with some greys. It's either too blue or too yellow etc. The Euro was a pain to copy .
                  What I do in that situation is take a bit of the model to the store and compare it to the card swatches they have. Large stores over here that do Dulux have hundreds of colours, shades and hues to select. Quite often I find one that is a shade darker and one a shade too light but not exact. So I simply buy a sample of both and mix em together until it's correct. That's how I matched the 90mm Eurofighter grey.
                  I spent days trying to match the grey of a friends Yellow F15 turbine after repairing it for him. Had it scanned, tried mixing myself but a slight change in ambient light altered it, it was either too red, blue or yellow after getting it looking right. I then realised the weathering was polarising it, so added weathering and it was spot on.
                  Scanning only works to a degree, the finish can diffract the light you see if the sheen or matt is not the same.
                  • SkyZee
                    • Jul 2025
                    • 3
                    Thank you for your great tips, much appreciated.
                    • baseballrn64
                      • Nov 2025
                      • 8
                      Hello. new to this site. I’m sure this has probably already been answered. I was wondering i have a v1 freewing Mig with the 9 blade edf (original version). just wondering can i just drop in the new freewing 12 blade edf ( the ones that are currently in v2) will the original esc’s be compatable with these Thanks in advance
                        • 8835
                        New EDF has same dimensions as the old 9-bl, so yes. ESCs on old and new are 100A, so again, yes.
                        • baseballrn64
                          • Nov 2025
                          • 8
ID:	439234 Click image for larger version
                          Hello. I was just wondering what the preferred battery layout is. i’ve seen these two posted obviously keeping CG in mind is there a preferred positions for the batteries. ill be using 6s 6000 packs. The forward and rear would work best for me just wondering what people are doing with there’s with best results for scale and high speed pass flying.
                          Thank you
                            • 5426
                            For the weight of your batteries mid and rear.
                            • baseballrn64
                              • Nov 2025
                              • 8
                              Thanks for the reply. So if i understand you if i use 6000 mid rear. if i went to 5000ish i could use the front and rear? i’m relatively new to edf and electrics coming from large scale gassers. Does the weight of the extra mAh basically zero out extra flight time of the smaller packs. Thanks
                                • 5426
                                If you have light 5000’s yes. And prefer a more tail heavy plane…
                                • baseballrn64
                                  • Nov 2025
                                  • 8
                                  Hello all. i was just wondering if anyone has owned and or flew both the V1 and V2 versions with the different motors and blades. i was wondering the performance difference. Thank You
                                  • Alphonso
                                    • Aug 2020
                                    • 101
                                    • Hastings, UK
                                    I have the vectored thrust and my 5900mah packs weigh 750g. I have to use front and rear trays to be 25mm aft of the CG marks.
                                    in answer to the second question, the plane can handle a wide range of lipo sizes and the extra mah will give longer flights. If you went large enough to dramatically notice the weight increase, the packs would not fit in the model. The reason for this is heavy packs would mean having to use the mid lipo tray and then they become difficult to actually mount without removing lots of canopy foam.
                                    • Alphonso
                                      • Aug 2020
                                      • 101
                                      • Hastings, UK
                                      A good increase in thrust
                                        • 8835
                                        A good analogy would be the A-10 - V1 vs V2. My V2 with the latest 12-bl inrunner is immensely more powerful than my old V1.
                                        I'm looking forward to when the MiG comes back into stock. Maybe it'll be a V2.1 and have quick attach wings. :fingers_crossed:
                                        • baseballrn64
                                          • Nov 2025
                                          • 8
                                          Hello. has anyone here actually placed. the new 80mm 12 blade edf units in the v1. Some have said it is the same size unit with the same esc’s are the same amperage but the motion rc people said it wouldn’t work. Just curious
