That will help with the CG with bigger batteris. But I like to take weight out if possible.
I use a SLS 6s3500 505g that keep the CG ok. But would like to use bigger 5000 battery..
The front nose is 28g and the cockpit is 78g, Should be easy to take of half of that and even more in the front ;-)
It is also possible to put receiver+ other electronic in the middle in the bodyside wing root outside the duct, cutting out space for it. If cutting the servolead shorter 30-40g goes of.
This way we can remove approx 100g from the plane and CG goes backwards.
Was looking into putting battery further back but the fanduct is the limit, wheels are in the way.
