  • radfordc
    • 375
    • Lansing, KS
    That is so.
    • rms
      • Nov 2020
      • 63
      • Senja, North Norway
      Are doing som small maintenance on my Gripen. So I fly the Mirage. Almost as good as the Gripen in hige alpha ;-)
      • janmb
        Slow and low
        • 729
        When I stated that yaw really effects roll in my earlier post I want to clarify that I meant during high alpha or very low/ zero airspeed Using the yaw TV really effects roll. And not necessarily in a bad way, you can do some neat things with it.
        I also said way back after my first TV flights with the Gripen to be careful using a lot of yaw TV input because the plane will do a quick corkscrew and end up pointed straight down and to play with it at altitude.
        All of those aspects are 100% as one should expect.
        Slamming in a lot of yaw from vectoring at slow speed/high thrust does do exactly that. Not unique for the Gripen in the slightest.
        • janmb
          Slow and low
          • 729
          Originally posted by radfordc
          The effect you describe is not the primary reason that yaw/roll coupling occurs...in fact it's nearly negligible. The reason a plane rolls when yawed is almost all due to dihedral effect. An aircraft with positive dihedral will roll in the same direction that the rudder is moved. An aircraft with negative dihedral (anhedral) will roll opposite the direction that the rudder is moved. Zero effective dihedral often results in no roll coupling at all (as Kallend pointed out with finely tuned pattern ships).
          Not the case at all.
          I've flown planes ranging from high anhendral to high dihedral, obviously including straight wings, and they all have positive yaw to roll coupling.
          What on the other hand does affect this a lot is the angle of the rudder, both sideways tilt in the case of twin rudders, as well as hinge line.
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1664
            • Catalonia
            Precisely.
            And vertical placement of the rudder affects that too.
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1664
              • Catalonia
              Got asked about my Gripen programming... didn't measure throws in mm (leaving that for another day), but, FWIW, this is what I have set up on the transmitter and gyro (Taranis X9D+ / S8R):
              Radio: Taranis X9D+
              INPUTS PAGE (Sticks; Low-Medium-High rates)
              ROLL THROWS 60-70-90
              ROLL EXPO 70-70-70
              PITCH THROWS 60-70-100
              PITCH EXPO 55-55-55
              RUDDER THROWS 45-55-100
              RUDDER EXPO 40-45-55
              MIXES PAGE
              ALL WEIGHTS TO 100%
              SERVO OUTPUTS PAGE
              LEFT ELEVON 150%
              RIGHT ELEVON 150%
              RUDDER 150%
              CANARD 100% (Remember this one goes through an external gyro on my JAS, and it didn't seem to appreciate the extra Tx range)
              S8R SETTINGS
              Master gain 70-90 (On a dial, I typically have it around those values)
              Config Settings
              Delta Horz
              S8R enable
              Quick mode disable
              Ch5 ail2 (Not relevant for elevon setup)
              Ch6 ele2 (Not relevant for elevon setup)
              Ail reverse
              Ele reverse
              Rud reverse
              Ail2 normal (Not relevant for elevon setup)
              Ele2 normal (Not relevant for elevon setup)
              Ail stab gain 42
              Ele stab gain 80
              Rud stab gain 50
              All else: default (not used)
              • HaroldAnderson
                • Mar 2019
                • 101
                • Oklahoma
                That looked like on of my flights after the landing. "Hey, I've got 14 seconds of battery left, time for another quick flight!". Way to get that battery down to 3.8 volts... 😎
                • Captain Moron
                  • Jun 2019
                  • 213
                  Think Motion RC seem to have an issue with there stock. The Gripen has been out if stock now for 3 months!!!!! Never mind the Rafale is due in a week Thursday 👍
                    • 8748
                    Must be an EU thing. MotionRC.com and RC Castle has had stock during that time period.
                    • Captain Moron
                      • Jun 2019
                      • 213
                      Be interesting to see how the Rafale compares with the Gripen. One thing I have notice is it looks like the Rafale canard only work in pitch, unlike the Gripen which work in both pitch and roll.. Also the Rafale comes with a built in gyro. Will the Gripen be back in stock in Europe before the Rafale is released??????
                        • 8748
                        It's likely that the canards on the Rafale can be wired to work in pitch and roll, if so desired. Evan D has indicated that roll mixing on the Gripen canards have limited effectiveness, so I suspect it will be no different for the Rafale. The control box on the Rafale takes all the inputs and does the mixing for you. Nothing says you can't unplug the two leads for the canards and do your own mixing in the RX. Horizon Hobby distributes the Rafale in N. America and it won't come with the Reflex. You can see the recent videos (on the other forum) of the first couple of flights of the Rafale. It appears to be more sluggish due to it being a heavier plane and those twin exhausts reducing the thrust somewhat. Even with Reflex, it still waddles like a fat duck walking. I think with the use of a different gyro, most of this can be dialed out.
                        Have you tried sending a message to MotionEU and asking them for an ETA?
                        • Captain Moron
                          • Jun 2019
                          • 213
                          I have contacted Motion RC and I do not think they really know
                          I was told it would be early January and then I was told it would be early this week but I surpose it is on a container from China and it will be here when it arrives, not much Motion RC can do. All I can do is do what I am not good at and that is be just wait, it will get here at some time. Funny you should say it is sluggish I thought that when I watch the video
                          Thanks for your reply
                            • 5385
                            I was told "I haven't a clue" when I called and asked when the TVs are coming. I understand delays but would think if they wanted to know they could find out exactly what ship the container is on and when it will dock. If it's docked they should have some idea when it'll be released, etc...
                            In the case of the TVs at least remove the expected late 2020 from the web site.
                            • kallend
                              • 1857
                              Many of us have disabled (or not enabled) the roll input to the Gripen's canards. It is not scale, it is aerodynamically undesirable, and unnecessary to achieve a high roll rate anyway.
                              • Captain Moron
                                • Jun 2019
                                • 213
                                That is interesting ,so you do not use the roll rate on your canards just use the pitch movement and have the roll rate on your canard disabled
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1664
                                  • Catalonia
                                  Yes.
                                  And even better if you use a gyro on canards (pitch only).
                                  This is the way.
                                  • kallend
                                    • 1857
                                    Correct. The canards are too close to the centerline to produce much rolling moment unless they have a lot of deflection, which will also produce a lot of drag and produce asymmetric .airflow over the wing. The elevons, being farther out, have a much greater effect.
                                    • janmb
                                      Slow and low
                                      • 729
                                      Neither of the two should have canards operate in roll anyway.
                                      Not only is it completely meaningless in terms of providing roll authority. These aircraft roll like drill bits at the merest hint of elevon control input anyway.
                                      And more importantly, it acts against the canards' primary purpose of shaping the on-coming air onto the main wing. Huge roll deflections on the canards messes that up completely, and gives one wing completely different alpha than the other.
                                        • 5385
                                        That said I prefer the quality of the roll with the canards active in roll.
                                        • Captain Moron
                                          • Jun 2019
                                          • 213
                                          Just like to thank Evan D. Your video on setting up the Gripen was great. It has cleared up all the confusion I had on setting up the Gripen. Now all I need is for Motion RC Europe to pull it's finger out and get the Gripen back in stock. I can not wait now I know how easy it is to set up
                                          Thanks Dave
