Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
    • 5415
    Motion has yet to post any reviews though the site says 4.7stars with 34 reviews.
    Edit- Reviews are up. 34 reviews and only two are critical.
    • thedarkwraith
      • Apr 2024
      • 13
      Originally posted by Rayant
      What range do you have set on the flaps? In the manual it says LOW RATE 11 mm. and at HIGH RATE 19 mm. They are right?.
      The one thing that is really critical with the flaps is ensure that they don't allow the wings to sweep back with them deployed. You need to ensure this on both low rate and high rate. The onboard gyro takes care of the logic for this so you just have to ensure that you have enough travel in low and high rate for the gyro to 'see' flaps are deployed.
      • rlcamden
        • 112
        • Lansing, KS
        After reading a few posts about the flap hinges, I decided to check mine out of an abundance of caution. I discovered that the right wing had very little glue on the hinges, and the left wing had a tad bit more, but all the hinges were relatively easy to pop off. This is definitely something you need to check if you own this plane. I haven't flown it yet, but I am glad I decided to check those hinges. Waiting to upgrade the swing-wing push rods.
        • Chris_WaterGuy
          • Jan 2021
          • 25
          • Nottingham, UK
          Pretty much as expected, the hinges on my example pulled off very easily. In fact they just 'popped off' with a little force with a blade underneath each of them. As I think I mentioned before, it's something I've learned to do with all my EPO models when they are new.
          • rlcamden
            • 112
            • Lansing, KS
            Finally got my F-14 complete and was able to get the maiden out of the way. I needed a lot of up trim with the book recommended CG and stabilator neutral position. But no issues.
            Maiden was a non-issue. I run flight modes on my flaps, so I was able to get all the trims set and fold the wings back on the maiden for a few passes. This thing flew like it was on rails on a 10-15mph windy day, without the gyro on.
            2nd flight was seeing how the gyro affected the flight characteristics. It seemed a little sluggish on the controls, but that may have been me. Get a few fast passes with the wings in and out. I even inadvertently checked the sturdiness of the airframe and the upgrades to the landing gear.
            She covers a lot of sky in a short amount of time, so be prepared for that. All in all, I like my 80mm better, just didn't like having to do all the upgrades to get it to fly the way it should. This 64mm version is a winner due to the ease of transport, the flight envelope, and the appearance. Kudos to Freewing and MotionRC.
            • kallend
              • 1877
              The stock nozzles on this F-14A are incorrect, they just look like scaled down parts from Freewing's twin 80mm F-16D. The nozzles on the A version were quite different - see image below .
              Here is a STL file to 3DP a (more or less) correct nozzle. Exit diameter is unchanged from stock.
              https://www.thingiverse.com/thing:6607424
              • nuts-n-volts
                Duke City Electric Flyers
                • 262
                • Albuquerque, New Mexico
                Nice nozzle, Kallend. I'll use it. Thanks!
                And, here's my trick... To take the stock nozzles off easily, I used acetone. I spray a small stream around the inside of the nozzle in between the plastic and foam. You can then just tug around the outside diameter and she'll loosen right up and off. The acetone won't hurt the foam. Only use a small amount to get the parts to loosen. You don't want streaks running through your paint! That is, unless you're going to re-paint anyway. The acetone could damage the nozzles, altho I used only a small amount and had none. The cool thing is that the glue stays put. I lined my ducts in foil tape for afterburners and needed to get the nozzles out of the way. I put them back on by simply "painting" the glue with acetone, which thinned it out. Stuck them on within a few seconds and presto!
                Fly low, fly fast, turn left
                • wstimax
                  • May 2022
                  • 15
                  So did anyone figure out the problem with the twitching Hitec Servos as i just finished my build and the same thing is happening.
                  • moti
                    • Jun 2020
                    Hi, the servo almost don't move when it on stab. mode red and green led.....why?
                    Thanks
                    Moti
                    • kallend
                      • 1877
                      Thanks
                      Moti
                      Why? Because that's the way it was programmed.
                      If you don't like it you can bypass it.
                      • Rayant
                        • Feb 2019
                        • 16
                        • Madrid. Spain.
                        How can I solve this problem? I can't download the app
                        • Icarus the 2nd
                          • Aug 2018
                          • 164
                          • Pajottenland, Belgium
                          Here's a flight I recorded earlier this week at a club in the north of France.
                          • kallend
                            • 1877
                            Fan(s) out of balance?
                            • Gravythe clown
                              • Mar 2019
                              • 711
                              • Clovis, California
                              Started working on my spoiler and full span flap setup.
                              I’m about half way done on first wing. Waiting on Amazon right now.
                              Gravy
                              • kallend
                                • 1877
                                I have an early one and the gear/door sequencing is very slow. Absurdly slow.
                                I'm told that recent deliveries have acceptably fast sequencing (as well as a rear-seat pilot so clearly there have been improvements made to the kit.)
                                Assuming the speed improvement is true, does anyone know if the faster control boards are available as spare parts?
                                • Gravythe clown
                                  • Mar 2019
                                  • 711
                                  Getting close to finishing up first wing. Works as good as the 80 mm one I setup.
                                  Gravy
                                  • kallend
                                    • 1877
                                    I put an AR10360T with the recent (today) firmware update to AS3X+ in my 64mm Tomcat. I am pleased to report that it works really well with the default gains with the wings forward, and needs the roll gain reduced slightly with the wings back, when it is also very good. Certainly better than my experience with the stock gyro.
                                    • Reptielenfreak
                                      • May 2024
                                      • 153
                                      So you bypassed the control board and put in the ar10360t?
                                      • rlcamden
                                        • 112
                                        • Lansing, KS
                                        For those of you who are using the SMC 5900 LIHV pack, can you share a photo of your battery placement? With mine as pictured, it balances at the marks on the fuselage, but the marks on the wings is extremely nose heavy. I have flown this thing about 5 times with 1 successful landing. For some reason, this thing is giving me a headache trying to find the right battery placement for proper cg. I don't want to give up on it yet. Thanks in advance.
                                        • kallend
                                          • 1877
                                          yes.
