Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
  • Reptielenfreak
    • May 2024
    • 153
    Originally posted by kallend
    yes.
    So for my understanding
Name:	Screenshot_20240720_121743_Samsung Internet.jpg
    Yellow goed to the reciever using Y harnasses.
    Red is removed?
    • kallend
      • 1877
      I still use the board for lights, flaps and sweep.
      • Reptielenfreak
        • May 2024
        • 153
        But if not, you run the yellow servo wires to the reciever right?
        • Bruchpilot24
          • Jul 2024
          Hi All,
          I had my maiden yesterday and following happened:
          1 gyro wants to constantly autolevel, is there a another function I can apply?
          2. the engines stopped multiple times to run during flight
          , whether full throttle, half or low it randomly stopped working and came back within a second again … anyone experienced something similar??
          Thank you,
          Peter
          • Gravythe clown
            • Mar 2019
            • 711
            • Clovis, California
            Flew the new modified spoiler and full span flap wings today. Flew great, didn’t notice any real difference in performance, but it looks cool.
            Gravy
            • kallend
              • 1877
              Originally posted by Bruchpilot24
              Hi All,
              Thank you,
              Peter
              1. I didn't like the stock gyro at all, so I bypassed it and use AS3X+ on my receiver Stock gyro seems to get very mixed reviews, some people love it, others are like me.
              2. What battery are you using? Sounds like LVC. And do you have reverse thrust set up?
              • pullupnow
                Pilot
                • 70
                • Long Island NY
                Gravy
                Nice work! very cool functional scale detail
                • kallend
                  • 1877
                  I finally got so irritated with the gear/door sequencer taking 15+ seconds to get the gear down that I made an Arduino based sequencer that does it in 5 seconds.
                  Code available on request.
                  • EDF-Jetpilot
                    Jets are a lot of fun
                    • May 2024
                    • 137
                    • Aarburg, Schweiz
                    neue Lieferungen inkl. RIO
                    Originally posted by SanExup
                    Uh, where's the RIO?
                    Bei meiner Lieferung von vor 14 Tagen (Schweiz) ist der RIO, also der "zweite Pilot" auch dabei... das hat mich sehr positiv überrascht!
                    • EDF-Jetpilot
                      • May 2024
                      • 137
                      • Aarburg, Schweiz
                      Bild dazu...
                        • 5415
                        You got the 80mm not the 64mm....
                        • EDF-Jetpilot
                          • May 2024
                          • 137
                          • Aarburg, Schweiz
                          Genau, ich spreche hier immer vom im Thread hier offiziellen twin 64mm Version. Sonst drücke ich dies klar aus. :-)
                          • EDF-Jetpilot
                            • May 2024
                            • 137
                            • Aarburg, Schweiz
                            oh aufgepasst.... das Foto ist die 80mm ja, aber ich habe die 64mm gemeint, die habe ich auch mit 2 Piloten bekommen, nur gerade kein Originalbild dabei gehabt. ;-)
                              • 5415
                              Understood.
                              • EDF-Jetpilot
                                • May 2024
                                • 137
                                • Aarburg, Schweiz
                                Ich habe Gestern in meiner neuen F-14 64mm den Empfänger installiert und nach dem Binden festgestellt, dass der Motor rechts keinen Muks macht, linker Antrieb ist in Ordnung, der rechte geht nicht. Kennt jemand den Grund oder hatte das auch? Ich muss jetzt rausfinden, ob es am Regler oder am Motor liegt.
                                  • 5415
                                  I would first calibrate the ESCs, assuming you haven't. The only other possibility is maybe one of the ESC servo connections is in backwards.
                                  But pretty sure it's ESC calibration.
                                  • EDF-Jetpilot
                                    • May 2024
                                    • 137
                                    • Aarburg, Schweiz
                                    Danke für den Hinweis, das habe ich noch nicht gemacht.... häufig sucht man gleich zu weit. Das könnte wirklich das Problem sein, ich werde schauen.
                                    • EDF-Jetpilot
                                      • May 2024
                                      • 137
                                      • Aarburg, Schweiz
                                      Hey Evan... es hat geklappt, nun laufen beide EDF's, dir sei Dank für den Hinweis.
                                      • EDF-Jetpilot
                                        • May 2024
                                        • 137
                                        • Aarburg, Schweiz
                                        Meine F-14 Twin 64mm habe ich nun am vergangenen Samstag eingeflogen. Der Jet fliegt sehr gut, aber bei voller Spannweite ist er anfällig auf Strömungsabriss, wenn man den Landeanflug zu langsam macht. Ich habe diese Eigenschaft hoch oben ausgiebig getestet und habe Respekt, so zu landen. Ich lande den Vogel immer in der Mittelstellung der Flügel, ich habe die Schwenkflügel auf einem 3-Stufen Schalter und kann 100/50/0% Schwenkstrecke einstellen. In der Mittelstellung der Flügel, also halb gepfeilt, kann man die F-14 wie eine F-16 wunderbar landen und braucht keine Angst vor Stall zu haben, auch braucht man so die Klappen nicht, da man angestellt reinkommen kann. Geht auch bei Wind sehr gut!
                                          • 5415
                                          Congrats on the flights!
