That's where the difference is when using Spektrum. "0" is a mid-point on a switch travel. If it's at position "0", it doesn't really know which way to go. It could stay on forward or reverse, depending on where it started when the battery is plugged in. The danger being that while flying, position "0" is confusing for a Spektrum set up where it needs to see the far ends of the range (IE, -100 or +100), thus having the possibility of going the other way. It would be horrible for it to go into reverse while flying with no way to bring it back to forward. The only option would be to shut down the throttle and dead stick it in.
Good thing you confined your search to your radio system.
. After nearly crashing :: turning to final.. the 1100 grams of HRB was to heavy 🪨.. did fly very well... Went back to 6s for a bit, but struggling to get off the grass.. also to fly well on 6 U need alot of throttle.
anyway will replace. It. Sooo. Thinking about flaperons and tailerons.
