Official Freewing 80mm EDF F-86 Sabre Thread
  • hotrod23t
    jim jets
    • Nov 2017
    • 312
    • EUSTIS FL.
    Flew my f86 with tiger meet power system wow take off distance reduced by 50 percent .pic of the day has a before vid and a link to an after vid 15 mph speed increase faster than my avanti now
    F86 with 9 blade tiger meet power system. 90mph + level flight.FLAPS malfuntioned so no flap landing 8 to 10 mph winds
    • davecee
      • 179
      • Nashville, NC
      sweet
      • hotrod23t
        jim jets
        • Nov 2017
        • 312
        • EUSTIS FL.
        the take off was no flaps also obviously.. about 30ft and a steep clime out
          That looks really nice man. :)
          • hotrod23t
            jim jets
            • Nov 2017
            • 312
            • EUSTIS FL.
            that was a shake down flight want to strech it out this weekend and try some verticals:)
            • Ron1950
              Retired ATC
              • Oct 2015
              • 887
              • brandon ms
              not sure how your vert will increase. but with the upgrade in runner its great!!! I have to throttle back to make it come back down lol good luck with it
              • hotrod23t
                jim jets
                • Nov 2017
                • 312
                • EUSTIS FL.
                speed run with tiger meet power 104mph 3.95 per cell after flight:Cool:
                • Ron1950
                  Retired ATC
                  • Oct 2015
                  • 887
                  • brandon ms
                  nice vid...id have to take a chainsaw for those trees lol love my f86 also
                  • hotrod23t
                    jim jets
                    • Nov 2017
                    • 312
                    • EUSTIS FL.
                    I live at this airfield it's my backyard got a 30 foot hanger full of planes don't have too travel I will put up with the trees..for now;)
                    • wvrailfan
                      • Sep 2013
                      • 682
                      • West Virginia
                      I've had my F-86 for a while, but I am just now getting started on wrapping and building it. I am going to do mine as a WV Air Guard plane.
                      Anything major I need to watch out for in the build?
                        What are you covering it with?
                        • wvrailfan
                          • Sep 2013
                          • 682
                          • West Virginia
                          I am using Oracal 751 series vinyl film. It is a peel and stick, self adhesive, film commonly used for vinyl signs and vehicle wraps. I have wrapped several foam planes with it. I think it looks good, but perhaps as important, it protects the foam from day to day bumps and my less than perfect landings. It weighs about 17 grams per square foot, so I'm not adding much more weight than if I painted the model.
                            Is it hard to work with? Looks great!
                            • wvrailfan
                              • Sep 2013
                              • 682
                              • West Virginia
                              There is a mild learning curve to it, but once you play with it a bit, it gets pretty easy. I can usually cover a 1400mm plane in a week or two of evenings.
                              My planes are not contest winners, but they look good from a few feet and in the air. I started doing this to cover the foam look of some of my early foamys, but now I do it as much for the protection of the foam.
                              It has been awhile but I posted a little "how to" in the tips section.
                              Below are some of the planes I have wrapped. Like I said, my goal is for them to look good from a few feet.
                              • Ron1950
                                Retired ATC
                                • Oct 2015
                                • 887
                                • brandon ms
                                man those are nice...id have wrinkels all over the place where or what kit is that t38? nice
                                • wvrailfan
                                  • Sep 2013
                                  • 682
                                  • West Virginia
                                  Thanks,
                                  The T-38 is a modified Freewing F-5.
                                  • C17loadmaster
                                    Retired USAF Aircrew
                                    • May 2018
                                    • 371
                                    • Auburn, CA
                                    I decided to use Callie’s Hartmann decals. This is by far my easiest EDF to fly
                                    • Ron1950
                                      Retired ATC
                                      • Oct 2015
                                      • 887
                                      • brandon ms
                                      found out that freewing quit making the 1820kv in runner .. that's the upgrade motor for a6 and f86 anybody know a better powerfull replacement fan?
                                      anyone ever try the fms 2000kv inrunner fan? says it puts out 6.25 lbs thrust
                                      • C17loadmaster
                                        • May 2018
                                        • 371
                                        • Auburn, CA
                                        I haven’t with an 80mm but I put a FMS fan in my 90mm F-16 and it was a big difference. It was only about $80. I did have to replace the ESC to a YEP 150, but the two components were cheaper than the FW Inrunner
                                          Try the A-10 fan.
