Flew my f86 with tiger meet power system wow take off distance reduced by 50 percent .pic of the day has a before vid and a link to an after vid 15 mph speed increase faster than my avanti now
speed run with tiger meet power 104mph 3.95 per cell after flight:Cool::popNew motor from tiger meet mirage ....104 mphComment
I am using Oracal 751 series vinyl film. It is a peel and stick, self adhesive, film commonly used for vinyl signs and vehicle wraps. I have wrapped several foam planes with it. I think it looks good, but perhaps as important, it protects the foam from day to day bumps and my less than perfect landings. It weighs about 17 grams per square foot, so I'm not adding much more weight than if I painted the model.Comment
Thanks
There is a mild learning curve to it, but once you play with it a bit, it gets pretty easy. I can usually cover a 1400mm plane in a week or two of evenings.
My planes are not contest winners, but they look good from a few feet and in the air. I started doing this to cover the foam look of some of my early foamys, but now I do it as much for the protection of the foam.
It has been awhile but I posted a little "how to" in the tips section.
Below are some of the planes I have wrapped. Like I said, my goal is for them to look good from a few feet.
8 PhotosComment
found out that freewing quit making the 1820kv in runner .. that's the upgrade motor for a6 and f86 anybody know a better powerfull replacement fan?
anyone ever try the fms 2000kv inrunner fan? says it puts out 6.25 lbs thrustComment
I haven’t with an 80mm but I put a FMS fan in my 90mm F-16 and it was a big difference. It was only about $80. I did have to replace the ESC to a YEP 150, but the two components were cheaper than the FW InrunnerComment
