    • 4857
    Waconut, Looks remarkable. I'll do some 'reflection' on your work. Best, LB
    • scootergenie
      Jet lover
      • 261
      • Stuart FL.
      Looking pretty sweet at this point ! Keep going .:pop
      • Waconut
        • Feb 2020
        • 310
        • Cincinnati, Ohio
        Nothing like waiting for paint to dry.
        I painted the white portions of the wings and tail surfaces last evening. I used Krylon White Gloss. The can says 48 hour cure time@ 70 deg. I have space heater going in my hobby room and have the temp up to 80 deg. That should cut the cure time down to 40 hours and I can mask and spray the red and blue tomorrow afternoon.
        If you handle the chrome paint with bare hand you will leave marks on the surface. I have found that if you use latex gloves the surface is not affected. I will have to wear gloves while masking and spraying also while applying the graphics.
        • Waconut
          • Feb 2020
          • 310
          • Cincinnati, Ohio
          Does anyone know how Polycrylic does over to of Krylon/Duplicolor spray paint? I want to spray a clear over the plane to seal the graphics and protect the chrome paint.
          Thanks!!!
          Anthony
          • C17loadmaster
            Retired USAF Aircrew
            • May 2018
            • 371
            • Auburn, CA
            Plane looks good! I took these pics the other day in case you are searching for references... I have about 100 of this Sabre, a 10 minute video of a walkaround (and under) an F-14, also some F-104, and A-10 pics. Being as those are the my only planes the museum had that I also had in my Freewing Fleet.
            It was about a quarter mile from my dentists office so i made a solo field trip...
Name:	F86 LTAIL.JPG
ID:	245971Click image for larger version
            • Waconut
              • Feb 2020
              • 310
              • Cincinnati, Ohio
              Thanks for the pics,
              I pretty much have all the info I need to complete the details that I am putting into the plane.
              Thanks Again!!
              Anthony
              • Waconut
                • Feb 2020
                • 310
                • Cincinnati, Ohio
                I started masking and spraying the red and blue. The white paint was good and dry on the tail surfaces. I had only a couple minor problems on the tail with paint lifting. On the top of the fuse where the tail mounts the white paint lifted after spraying the red. I will have to mask off the red and spray the white again.
                I did a test with all 4 colors sprayed on a paint cup. I sprayed 2 coats of Polycrylic over the paints with no issues. I will clear the plane with Polycrylic after the graphics are applied.
                Here is a pic of the stab/elevators.
                Later!!
                Anthony
                  • 4857
                  Waconut Looks great, Sir. Best, LB
                  • scootergenie
                    Jet lover
                    • 261
                    • Stuart FL.
                    Yes... Turned out very nice !
                    • Waconut
                      • Feb 2020
                      • 310
                      • Cincinnati, Ohio
                      I have the red,white and blue sprayed on the plane. I have to say the chrome paint does not tolerate being touched by hand or masked. You can handle it with latex gloves and it will not affect the surface. I will have to wait for the colored paints to cure so I can mask off and re-spray the chrome paint.
                        • 4857
                        WN, I thought you had shot clear acrylic on the 'chrome' before adding the Red, White, & Blue. Best, LB
                        • Waconut
                          • Feb 2020
                          • 310
                          • Cincinnati, Ohio
                          No, I had already made a few fingerprints in it. I will just shoot another coat after the color coats dry.
                          I may shoot a coat of clear before and after the graphics.
                          • Waconut
                            • Feb 2020
                            • 310
                            • Cincinnati, Ohio
                            To be honest it never hit me to seal the chrome with Polycrylic before masking and spraying the colors. I will seal the colors with Polycrylic before re-spraying the chrome.
                            • Waconut
                              • Feb 2020
                              • 310
                              • Cincinnati, Ohio
                              All the painting is complete on my F-86. The graphics from Callie should arrive today. I am hoping the red, white and blue fuselage stripes are included. If not I am going to order pinstripe tape to put the stripes on. I am done fighting masking this plane.
                              Later!!
                              Anthony
                              • Waconut
                                • Feb 2020
                                • 310
                                • Cincinnati, Ohio
                                The graphics did not arrive today, hopefully tomorrow. I did receive my F-4 Phantom, 3D cockpit, exhaust nozzles and double afterburners from RC Geek. I will resist the urge to start another project until the F-86 is finished.
                                • Waconut
                                  • Feb 2020
                                  • 310
                                  • Cincinnati, Ohio
                                  I decided to put the F-86 together and see how the paint scheme is looking. Can’t wait for the graphics to get here’s.
                                  • Waconut
                                    • Feb 2020
                                    • 310
                                    • Cincinnati, Ohio
                                    The graphics arrived today. Callie does great work. The stripes were not included but I didn’t think they would be. I will order some pinstripe tape.
                                    I am happy with how it turned out.
                                      • 4857
                                      Originally posted by Waconut
                                      The graphics arrived today. Callie does great work. I am happy with how it turned out.
                                      WN, Phenomenal livery and very well executed...but you knew that. Bravo Zulu, Sir. Best, LB
                                      • scootergenie
                                        Jet lover
                                        • 261
                                        • Stuart FL.
                                        I would be proud to have that one in my hanger.... Nice job !
                                        • Waconut
                                          • Feb 2020
                                          • 310
                                          • Cincinnati, Ohio
                                          Thanks guys,
                                          I have liked the F-86 in this paint scheme since I was a kid. I was worried while doing the painting that I might not get the proportions right and the angle of the blue/silver separation line would not be on the correct angle to match the black/white USAF decal. I have emailed Callie asking her if she can make me the fuselage stripes if I supply the dimensions. I would hate to spend a hundred bucks buying six different rolls of pinstripe tapes.
                                          Later!!
                                          Anthony
