Official Freewing 70mm Twin Me 262 Thread
    Welcome to Hobby Squawk CWS! I would start with what the manual suggests then tweak it to your liking, here's a link to the manual.
      Well I finally got one of these, the only bad thing I can find about it is that I waited this long to get one! The 262 is one of the best looking, most well built planes I own...if it flys half as good as it looks I'll be thrilled.
        Most excellent George...........Do the front end reinforcement mod though to ensure longevity.;)
          Which is?
            Which is?
            Seaviper posted this back in March. There were others that did CF laterally in the nose with postings over on the other forum.
            It was pretty well known that the front end was susceptible to snapping off with unkind turf.
            Be interesting to know if they did any reinforcements on the newer ones.
            If so, it would be kind of like the unannounced upgrade to the A-6 in the battery tray area. :Cool:
              I'll take some pictures and work on a fix for the weak point.
                • 7383
                Originally posted by Cws
                I have my Freewing 262 ready to Maiden and wonder what the control throws should be? Also what is the best CG location?
                Hey CWS, welcome from me as well!
                Check with your manual for the CG and the throws. Initially that's where they recommend you start from, once you're used to the plane, you can adjust it to suit your individual taste.
                That's one manual I'll put on my list for rewriting.
                  That's what I said but the manual has nothing about it.
                    • 7383
                    Hmm, now that's interesting. Now I'll really have to look!!
                      • 7383
                      CG is 100 - 110 from the point at the leading edge back to where I crudely drew the line.
                        But nothing about throws or rates.
                          • 7383
                          I hear you George, I'll do some research and see what I can find. That's one OLD manual and it screams for updating. Let me gather what info I can and I'll get into it.
                            • 7383
                            No, can't get any info on throws, Ryan said he didn't mention the throws in the video because they aren't in the manual.
                            So the only thing you can do ("I don't need no stinking throws!") bind her up, center your servos and blast off. I hate to admit it, but I've done that, throw her in low rates and hold one. Bad advice, but you have to come up with a starting point somehow.
                            Maybe Seaviper can advise you.....
                            • ryramZ
                              Pilot Ryan
                              • Dec 2012
                              • 814
                              I always flew with the old Admiral 5000 about an inch back. Maiden I'm sure I flew with it all the way forward.
                              If I had to guess on rates I'd say set it up like a warbird. Some jets need throws that look uncomfortable but end up being what's needed.
                              My advice a smooth low deflected warbird type throw will serve you well. Some have acted like this bird is a handful but I found it well behaved. It's kind of heavy so it likes its speed, also I think the lower deflection will keep her in the groove so she won't exhibit any nastiness.
                                • 7383
                                My initial thought was to mimick the F-86 throws. Maybe even the Avanti's??
                                  Absolutely Ryan.................probably 90% of my fleet has 15 degree throw on the ELE & AIL.
                                  Fractional or millimeter length settings have been counterintuitive to me.;)
                                  • Arcangel
                                    • Jun 2016
                                    • 85
                                    • 29 palms CA, north of Moss Eisley and just this side of Anchor-head.
                                    Just a quick ? for every body that owns one these beauties..... Now that the ver.2 release of the ME-262 comes w/ the new type 2, 70mm ; 12 blade ; standard rotation only ; plastic fans,
                                    has anybody had any trouble with or noticed a drift in the model's flight performance with their throttle usage???
                                    In the past, the ver.1 had a 5 blade standard & reverse rotation fans to counter each other being that they were so far apart from center. On mine, I opted for the power upgrade to the High Performance inrunner power systems w/ the red standard & reversed rotation metal fans.
                                    I'm just curious as to other people's experience with the newer ver.2s and I am contemplating on whether I should be looking at upgrading the Gloster Meteor if / when I decide to get one. :)
                                      No issues with mine, and I have had both versions. FWIW, I don't think torque is really a factor on EDFs. Now, if you have one motor go out, that's a different story as the fans are spread so far apart.
                                      • fhhuber
                                        • Aug 2015
                                        • 1476
                                        You have to get a bit extreme for EDF torque to be much of an issue.
                                        But I could hit the throttle and lift the right wheel before the airplane moved forward.
                                        Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                                          It's funny, my V1 used to do that, but the V2 doesn't.
