Finally ordered the ME -262 also another Gensace 5000 60c, Merry Christmas too me...............:)
Official Freewing 70mm Twin Me 262 Thread
I too received a freewing me-262 for Christmas, my first rc. Bought a champ s+ to train with
ordered the killerplanes reinforcement kit to beef up the foam parts.
I too would like the flying surfaces control travels and settings for the flaps, any suggestions would be greatly appreciated. JohnComment
While a Me-262 makes a decent first twin EDF... its probably going to take you 3 to 4 other airplanes to be ready to fly it.I too received a freewing me-262 for Christmas, my first rc. Bought a champ s+ to train with
Control throws:
I have the Dynam. Same size, not quite the same airplane, but it should be close.
20 deg up/down from center ailerons
30 deg up/down from center elevator
35 to 40 deg right/left from center rudder.
If you have the channels to put the nose wheel on a separate channel, do it and put it 35 to 40 deg each way (so you can make tight enough turns taxiing out) but have HIGH (40% to 60% expo to make it easier to track straight on takeoff.
I did a mod to make the horizontal stab incidence adjustable in flight. After a lot of trim testing I found optimum stab incidence and CG, making the airplane capable of an outside loop. (can't do it with the Dynam Me-262 set up by the manual.)
Dynam starts you out VERY nose-heavy to make up for a tendency of the low mounted EDFs to push the nose up at low speed and high power. Its better to get the CG right and learn the throttle management to deal with the issue.
I talked with the pilot of one of the full scale reproductions and he said the full scale has the same issue and they have to be careful not to drive the nose up with power during takeoff.
Reproduction uses modern, more powerful (and more fuel efficient) engines than the original and is modified for a back seat. Otherwise its built from plans developed by disassembling an original for restoration.
Dynam horizontal stab in flight adjustable incidence mod:
Full scale Me-262 pilot holding my Dynam Me-262
Thanks fhhuber, I will put the information to good use. Plan on doing a lot of taxi testing and median speed runs without take offs, if possible lol.
lots of practice with my champ s+ in the near future if weather cooperates. Meanwhile installing the carbon fiber rods in the crashproofing kit.
JohnComment
I never did a crashproofing kit.
First Me-262 lasted a bit over a year and a half and then lost its tail in the vertical nose down of a split S at about 115 mph.
Second I pinned the vertical in place with some toothpicks and glued it in to back up the screw-on mounting. Its about done at 3 years old. Looking at the Freewing to replace it. But I'm disappointed at the very non-scale flaps of the Freewing (Dynam has no flaps though)FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
To Moderator: I will remove this post after a reasonable time, it won't be permanent.
I have a box of spare parts available for anyone who's interested. Send me a PM with a decent offer.
Unfortunately my Swallow met its end last summer, it suffered a brownout and went down into a plowed field. I had originally purchased my bird two years ago at a swap shop because its first owner had cartwheeled it, so I fixed the broken nose, purchased a new nose gear, did a bunch of repairs on the wing and replaced a nacelle. Lots of "body work and repainting". It was in really excellent shape and I enjoyed flying this plane a lot.
My accident completely destroyed the nose and it isn't repairable this time IMO due to foam compression. So I saved all the rest of the wreck, thinking that I would buy the new version and keep the parts as spares. But time has passed and I spent my money on the new F-4. (!!) I'm thinking that my collection of ME262 parts might come in very handy for any of you who are flying it.
The fuselage isn't usable as a spare part, but realize there are a large number of other valuable parts here:- Two 6-blade EDFs and ESCs
- All three retracts and wheels. (nose gear doors are no good)
- all of the Servos (seven?), pushrods, and wiring
- removable Tail part (fin and stab).
- Canopy and pilot, the plastic wing parts like the connectors and ESC louvers (all good).
- Nacelles (they are not in good shape, one is bent. I think the louvers are broken)
- Wings (they are damaged but repairable)
- and I have most of a new decal sheet (I used some of the red dotted line on my earlier repair)
Since I disassembled the plane, it will fit into a box and I can ship it by FedEx ground for about $20 so factor that into your offer.
In other words if you offer me $50 keep in mind you're really only offering me $30.
Now, I feel just the twin motors/EDFs/ESCs and servos/retracts are worth at least $100. These parts alone from MRC would cost you $280.
Obviously I will take the best offer. Thank you ! -MarcMarc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
I have done allot of work on my 262 but have only a few flights on her. I have to say she is one of the best flying jets I have, the plane is very well built and designed. I'm running my own non counter rotation edf power system @75A each and have not seen any negative effects. I'd suggest reinforcing the nose as the front section can be easy to do and a few people have had the nose break on a hard landing.The plane is super stable, the only thing to watch out is not to power up too quickly on takeoff as the thrust line is low so the nose can be pushed up too quickly before the plane has reached flyable speed (NO flap on take off, just let her come to speed and come up). Also as with any jet large sweeping turns and keep speed up. I have found you can cut power and she will glide right in, nice.
cg 110-113mm
10 to 12mm ele up (top of ele) I always use as little ele as needed as bad things can happen with too much ele :o)
15mm ale ( might add more, she rolled slow )
20mm rudder
Good starting point, the plane felt good right away, no pitch change with wheels or flaps, I will add a little down ele with throttle mix. She is a thing of beauty, hard to find a more beautiful jet.
Good luck.
here is the maiden video
rc flyin addictComment
Really is one of Freewing's better "Gen 1" jets. I may have to pony up for another. Flies great, very well behaved. Even with a loss of power and my friend thought she was toast, she just glided right in for a soft landing like it was nothing. Nice job btw!My YouTube RC videos:
+1 and thanks Aros. I could tell right away that this kit was a step up in quality and build from previous kits. The current v2 with the 12 blade fans looks to have excellent performance. I went with wemotec EVO fans and 75a CC controllers and it too is a solid setup, I wanted to be as efficient as possible given the total current draw from 2 edf units. This one I spent way too much time on (the biggest mod was changing to the dynam canopy, I wish freewing would mold a smaller one) but was rewarded in the end with a superb looking and flying scale jet, I highly recommend it. ( funny how the designers got the first jet right, notice how it looks exactly like the current passenger plane layout ! )1 Photorc flyin addictComment
LOL the ME262 was carefully researched after the war by the Americans and Russians, the aerodynamics were certainly superb. The F86 Sabre and MiG-15 were direct offshoots. Many modern jets owe a lot to their "grandfather's" good looks. So in other words, the Me262 doesn't look like modern jets - its the other way around !!+1 and thanks Aros. I could tell right away that this kit was a step up in quality and build from previous kits. The current v2 with the 12 blade fans looks to have excellent performance. I went with wemotec EVO fans and 75a CC controllers and it too is a solid setup, I wanted to be as efficient as possible given the total current draw from 2 edf units. This one I spent way too much time on (the biggest mod was changing to the dynam canopy, I wish freewing would mold a smaller one) but was rewarded in the end with a superb looking and flying scale jet, I highly recommend it. ( funny how the designers got the first jet right, notice how it looks exactly like the current passenger plane layout ! )Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Here's another video of Barrett Hochhaus' beautiful scratch-built airliner utilizing the wings/motors/landing gear from the Freewing Me-262 that I shot at AEF last weekend.
This one's a bit different than Pat's as it was shot during the Southwest Airlines "Heritage Flight"....
I personally prefer the older tan color over the newer blue scheme...it's what I grew up with!
Watch as Barrett absolutely GREASES the landing, and then stay tuned for an impromptu interview with Barrett about where he got the inspiration to build it, and HOW he built it!
I especially like the fact he calls it a "Boeing 737-262"!
Blue Skies!Comment
We have a flyer at our club who is a Captain with Southwest. He has a Windrider 737-700 that was custom painted for him in the SWA colors one generation ago as it was current when he had it done. They did a few formation flights during our event a few weekends ago.
Here's one of the vids.
PatComment
