  • Corsair nut
    Jets...warbirds...mmm hmmm
    • 218
    • Tehachapi ca
    Thanks man! Much appreciated. Ive been wanting to dust my a4 off and do a proper blue angels. Full refinish with maximum smoothness. Maybe fullgear doors too
    • Monty500
      Pigs can fly!
      • 60
      • Lower Hutt, New Zealand
      Originally posted by Hardway
      Getting ready for a few flights after the weather clears a bit...
      Fantastic job on the livery Hardway. Greetings from New Zealand !!
      • Brinka
        Because I was inverted!
        • 121
        Perhaps I should enter this in the contest, A4 with fuel tanks and missiles attached.
          Monty500 Thank you Sir!!! Greetings & Blessings from Texas!! Jerry
            Brinka You bet!!! Great job!!!
              • 4857
              BK, Nothing beats a failure, but a try, my friend. Just do it. Best, LB
                Brinka Please do!
                • santanig5
                  • Mar 2020
                  • 22
                  • Beachwood, NJ USA
                  Greetings Pilots,
                  I just picked up a used one, it's a little ruff, hoping if flies well, if so I will probably purchase new wings as these have been repaired, are missing the ordinance and the mounting points. I've downloaded the current manual from MRC's site, but reading through this forum there seems to be a lot of discussion about the what the CG should be and it's starting point. I will be flying a Zippy 4500 6S pack that weighs 725g slightly less than the Admiral 5000 most of you all are using at 732g. I have it pushed all the way forward and it seems to balance fine at the documented location and a little forward of that. Am I safe starting at this location for the maiden or should I add some weight to the nose to balance it further forward?
                  Also is anyone using the recommended throws for high and low rates?
                  Thanks in advance,
                  Santa
                    • 4857
                    Originally posted by santanig5
                    Greetings Pilots, Santa
                    S5, Welcome to Hobby Squawk. glad you're on board, Sir. Best, LB
                    • EA-6B Geek
                      EW Misfit
                      • 485
                      • South Central Ohio
                      Greetings Pilots,
                      Thanks in advance,
                      Santa
                      Hey Santa. The A-4 seems to be happiest riding the forward setting on the CG. Don’t over do that, but it will fly safely there. The control throw settings stated in the manual are a little aggressive. I think you’ll find at least a few references to “drill bit” roll rates if you search through the thread. Try the low rate settings, you’ll be at a good start point. It’s my favorite jet. Enjoy!
                      • CVA59
                        A4 Driver
                        • Nov 2018
                        • 398
                        • Texas
                        Thanks in advance,
                        Santa
                        This guy does an excellent review including telling you where to set your throws, expo and such.
                        EAA# 1366802
                        AMA# 631508
                        https://vf59.weebly.com/
                        • Phantom
                          • Mar 2019
                          • 504
                          • M.D.
                          Anybody remove the nose weight? I don't have time to read through the 116 pages, so thought I'd ask...
                          • CVA59
                            A4 Driver
                            • Nov 2018
                            • 398
                            • Texas
                            I have not.
                            EAA# 1366802
                            AMA# 631508
                            • Phantom
                              • Mar 2019
                              • 504
                              • M.D.
                              Originally posted by CVA59
                              I have not.
                              I just did obviously, I've heard this birds power system described as being efficient, but my experience has been the opposite. So looking forward to hooking up two 4200mah 6s in parallel to get some decent flight times on her.
                              • Johnnyrabuse
                                winner wolf
                                • Apr 2020
                                • 136
                                • NY
                                Builds finished I am using a 5000 admiral the cg is right about were the back end of the factory recommended cg with the gear down I added about an ounce and a quarter it's about a quarter inch forward of the back end mark watching you tube videos I see it proposing up on landings and leaping off the ground on take off I'll try another batt first and if that doesn't work I'll add more weight to get it about a half inch forward of the cg mark
                                This one's got me nervous
                                70 percent hight rates aerolines 80 on elevator
                                Mids 65 aero
                                Low is 60
                                Any input?
                                Thanks in advance
                                • themudduck
                                  -TMD- Foaming at the Mouth!
                                  • 1041
                                  • Burton OH (near Cleveland)
                                  Mids 65 aero
                                  Low is 60
                                  Any input?
                                  Thanks in advance
                                  Reduce your ailerons to 50/45/40 and use at least 35% expo.. You'll thank me later.
                                  • Beeg
                                    • 1335
                                    • Texas
                                    I had my throws set to the book low settings and the ailerons were still too sensitive. Herb at RCG posted these numbers and after I set mine up the same it is a delight to fly.
                                    Ail.
                                    +- 10mm
                                    Elev.
                                    +-20mm
                                    Rudder
                                    +- 15mm
                                    Flaps
                                    18mm 28mm
                                    • Phantom
                                      • Mar 2019
                                      • 504
                                      • M.D.
                                      Nose weight removed, I'm flying her with a hrb 6s 6000mah 50c, it fits snug as a bug against the back bulkhead and gives me perfect CG.
                                      • Bogietrim
                                        Ultimate gravity tester
                                        • Oct 2013
                                        • 112
                                        • Cincinnati, Ohio
                                        Originally posted by Alpha
                                        Bogietrim When is your maiden of your awesome Aggressor?
                                        Sorry, I took a bit of a break from the forums. Just getting caught up here. Maiden was months ago and went perfectly! She’s a sweetheart and has quickly become my go to jet. I think it flies better with the 6000mah battery. The added weight just makes it a little more solid. I will try to get some video up soon!
                                        • Bogietrim
                                          • Oct 2013
                                          • 112
                                          • Cincinnati, Ohio
                                          I have been using the Admiral 6000’s right at the rear edge of the battery tray. It flies great with authority and I am getting well over 4 minutes of spirited flight landing with reserve left in the tank.
