I am an RC addict and innovator that loves to share my knowledge with those that need help. Ask me anything via PM if you need help! Check out my Website here https://www.gooniac33.me/ -
Even with the bigger avanti nose wheel I can't get this thing to fly off grass. I've flown it off a dirt area next to our field. But only a matter of time before a rock gets kicked up into the cheater hole. It's happened twice to one of our club members. Might have to sell this one. It's a shame cause it flys so well.Comment
I'm pretty sure it is. Not sure how to check. As soon as I start to taxi the font shock compresses all the way. Only does this on grass. Any pointers would be appreciated. I've got new good batterys. I've been trying half flaps. She just can't get enough speedComment
I fly from grass. And rough grass at that. Make sure you do the throttle calibration on the ESC (turnon tx, put throttle at full, power rx, when you get the beeps lower throttle to min, repower rx). You only have to do this once unless you re-bind again.
If the throttle calibration is not the culprit, then a new battery might be. New batteries need 4 or 5 cycles before they give good power for jets.Meridian Aeromodelers, Meridian MSComment
Thanks for the tip. I'll recalibrate esc and try it. Our grass is not super rough but it is thick. My batterys are good this is not my only 6s plane so I'm gonna rule that out. Like I said it has no problems off a hard surface.I fly from grass. And rough grass at that. Make sure you do the throttle calibration on the ESC (turnon tx, put throttle at full, power rx, when you get the beeps lower throttle to min, repower rx). You only have to do this once unless you re-bind again.
If the throttle calibration is not the culprit, then a new battery might be. New batteries need 4 or 5 cycles before they give good power for jets.Comment
I would also check to see if you are too nose heavy. I fly off of grass and have no problem either. I will say that I have moved my battery back as far as it would go and the jet flies great now. I have the battery even with the end of the rear of the cockpit. I have even flown it off our field when the grass was wet. I'm using a Roaring Top 5000mah 70c battery.Comment
Yeah I was thinking that too Rosytime. If you think all is well, then try using half flaps and some back pressure on the stick to get the nose up. But not too far. Just let it ride the main wheels and accelerate. I use this technique with the T-45 at our field.
It's called a soft field takeoff. Should work.Meridian Aeromodelers, Meridian MSComment
That's some thick grass TJ! I'm flying mine off grass too, but I'm the one cutting it, and I cut it short! The A-4 works fine for me, but I have to admit that my first takeoff roll was a bit longer than I expected. Been using full flaps to get airborne since then. I understand your frustration.This is my field
https://www.dropbox.com/s/3xki08rf22...%20AM.mov?dl=0Comment
I'll know more later today when Pilot Ryan and Captain Mike arrive. We cut our field short and for events like the one we're having Saturday we roll it.
Your grass field is better than my front lawn. Lush. Our field is a hybrid Bermuda but this year some St. Augustine has crept in. Just a few patches but it hates airplanes with small wheels. We're going to kill it. The 70 and 80mm jets are okay. The 90's have a tougher time.
We'll see later today when we fly my A4 and the DH-112 Venom. News at 11.
I Want: 80mm A-4, twin 80mm F4J PhantomComment
I still say to get that front lighter. I never saw the nose bounce up once while you were taxiing around. I also agree your grass field is lush and soft. Our grass at out field is only about 3/4 of an inch after I cut it. Of course it's more weeds than grass but it mows short.Comment
