  • dahawk
    Augermeister
    • Jun 2013
    • 1006
    • Keller,Texas
    I stopped trying to outsmart the designers a long time ago. The B-24 design and construction is rock solid. I fly mine with mostly rudder. Needs alot if rudder in the turns to swing that big arse end around. My Dad, who was a tech sarge/ flight engr. told me the full scale flew like that. Great scale replica!
    • NoDirt!
      • 183
      Well, no flying weather all weekend. AND probably the rest of the week :P
      I did get in a range check which failed so I swapped receivers and added telemetry. Better now.
      And I found my mods made it tail heavy. So as much as I didn't want to, had to add some nose weight to hit the 3" C.G. But, I'll get there yet!
      • themudduck
        -TMD- Foaming at the Mouth!
        • 1041
        • Burton OH (near Cleveland)
        Interestingly, I've found that this model is pretty tolerant with the CG. With 3S 3600 batteries in mine, the nose is light and it's most likely "tail heavy" according to what's recommended. I installed one battery in the tray and the other one fully forward to the front of the foam shelf... but it flies beautifully and flares nicely during landing.
        So another way of looking at it is, they stock setup is probably somewhat nose-heavy, which results in a stable airplane. Moving the CG back a bit makes the model more maneuverable but its still a very nice flyer.
        I haven't tried it with 3S batteries in the middle of the tray. You know what they say about tail-heavy planes! "Nose heavy planes fly badly, tail heavy planes fly once!"
        If you add some weight, make it so that you can remove it later... after you get some flying time you may find its not needed.
        Hoping for a nice weekend (as always)….
          • 8205
          Hey folks...PSA...We now offer STL files for the nose gear doors. For the left gear door .stl file click here. For the right gear door .stl file click here.
          You can thank Santa Alpha. ;)
            Just an FYI, the file names are backwards. Right is left and left is right. ;) But the good news is the parts themselves have L and R printed on them, so once printed there will be no mistaking which goes where.
            Thank you Santa Alpha!
            • dkalwishky
              Warbird Lover
              • Sep 2015
              • 1382
              • Des Moines, IA
              I've already given the STL files to one of my guys to print.
              • skrez
                • 13
                Hi Guys,
                I just purchased the B-24 and joined Hobbysquawk because of all the great info. here. I was thinking of going the 3s rout , I have some Admiral 3700 that I use for my FMS B-25. What kind of flight times can I expect with these? Thanks in advance.
                Regards,
                Frank
                  If i ever get to the point i can afford this plane, im definitely going 3S on it. Just to keep her tame and more scale in effect
                  • themudduck
                    • 1041
                    Originally posted by skrez
                    Hi Guys,
                    Regards,
                    Frank
                    Hey Frank,
                    I'm at work (ha ha, they don't know I'm on here) so I can't tell you what my timer is set for. But I'll say that I haven't really wrung it out yet to see how long I can fly. I'm using the same Admiral 3700's. The plane flies with the throttles cracked and I fly and fly until I get tired and then the batteries are at 3.9v per cell or something, so they obviously can go for a long time. Now if you fly like a maniac at full throttle, doing stuff this plane wasn't meant to do, I suppose it will use the batteries up a lot quicker!
                    I'll check when I get home and amend this post with what my timer is set for.
                      • 4819
                      Hi Guys, I just purchased the B-24 and joined Hobbysquawk because of all the great info here. Regards, Frank
                      Welcome, Skrez! This is a great forum and the feedback is quick and accurate. I am envious of your purchase, :Cool: though there is a WWII bomber in my 2019 Buy List. Best to you and yours, LB
                      • Woodcock
                        Old Returning Pilot
                        • Apr 2018
                        • 830
                        • SoCal
                        Basically what he said. Welcome.
                        Woody
                        • skrez
                          • 13
                          Thank you all for your kind words of welcome and friendly advise. I can`t say enough about MotionRc, I ordered the plane on Sunday and it arrived today. I briefly looked at the contents and it looked great and very well packed. I will spread on my workbench this weekend to take a parts inventory .
                          Regards,
                          Frank
                          • Captain Awesome
                            On our last bit of fall sunshine in Western Washington, I was able to take to the skies with my recently built 78" wingspan Consolidated B-24J Liberator. This one in particular has been custom-painted and given a livery that matches a real bomber that flew in the South Pacific from 1944 to 1945 in World War II. This particular aircraft is from the 372nd Squadron, of the 307th Bomb Group. Known as the "Long Rangers" they flew missions that spanned thousands of miles, at night, over what was mostly open-ocean. My grandfather, Elwood T. Lippincott was Squadron Commander of the 372nd, and flew with many brave crews, including that of famed Olympic Runner, and the Subject of the film "Unbroken", Louis Zamperini. This is the first of two builds, with my next B-24 project will be an accurate representation of the plane that my grandfather flew on his first, and notable mission to bomb Wake Island in December of 1942.
                            • Captain Awesome
                              Photos of my B-24.. :)
                              • themudduck
                                • 1041
                                Its a beauty, Cap'n, awesome pictures and video. I think you are ready to make a full-length movie. You just need some actors!
                                • Boots Whirlygig
                                  • 560
                                  • Granville Ohio USA
                                  That’s awesome Captain Awesome!
                                    • 4819
                                    CA, Beautiful job on your LIberator and Welcome to Hobby Squawk. Best, LB
                                    • fieldofdreamsflyer
                                      Banned
                                      • Jan 2013
                                      • 289
                                      I'm going to buy the silver version soon and use a single 3s 8000mah Lipo for it
                                      • boomer108
                                        Chief Boom
                                        • Apr 2014
                                        • 867
                                        • Chicago IL.
                                        Welcome Captain! That plane is beautiful. :Cool:
                                          Banned
                                          • Jan 2013
                                          • 289
                                          How do you get the nose gear doors to go up or down when the gear retracts
