  • Spad Driver
    Okay I'm airborne. Now how do I land?..
    • Apr 2020
    • 57
    • mountains of Utah U.S.A.
    I've installed the strut upgrade and Dubro wheels on my P-38. Has anyone else had an issue with the nose wheel hitting the gear door hinge at rear of the door?. It is not allowing the gear door to close completely. Is there a simple solution without sanding on the hinge?. The mains are closing properly without interference. Thanks for any suggestions.
    • Cape Jets
      Member- Jet Jockey
      • Dec 2020
      • 120
      • Cape Cod, MA
      A little off subject, but since I am using a Hobby Eagle A3 Super 3 gyro in my P-38 it kind of applies. Also have an Admiral 10ch receiver. How do I set up the adjustable gains to work on my DX-8?
      • Cape Jets
        Member- Jet Jockey
        • Dec 2020
        • 120
        • Cape Cod, MA
        Mine were a real close fit as well. I did move the mount on the door hinge to the back of the bracket. I saw that on a post somewhere and it seemed to work from hitting the strut. Plus the wheel needs to be straight of course while going down...
        • Spad Driver
          • Apr 2020
          • 57
          Thanks, I'll give that a try.
          • Cape Jets
            Member- Jet Jockey
            • Dec 2020
            • 120
            • Cape Cod, MA
            Another winter project completed. Up-graded the Gear Struts to include 2.75" Front / 3" Rear Low Bounce Tires. Went to 11x7x3 Prop blades to run 6S power. Installed MrRC Sound card with P-38 sounds. Also "Thanks" to Callie Graphics on the nose art. We might have some decent weather here on Cape Cod this weekend so maybe she will maiden soon. Cant wait to see this bird in the air.
ID:	301137Click image for larger version
Name:	P-38 Front.JPG
ID:	301138Click image for larger version
              • 4829
              CJ, Truly well done.:trophy: Love it. Best, LB
              • Cape Jets
                Member- Jet Jockey
                • Dec 2020
                • 120
                • Cape Cod, MA
                Well the last day of February gave us a gift here up on Cape Cod. Temps in the low 40's and no wind (alittle cloudy though). So the perfect day to get the Lightning in the air for the first time.
                What a great plane to fly and watch in the air. The 6's power was perfect and the manual suggested rates were pretty much dead on for trim. Needed about 2mm more up trim on the elevator to level her out. Prob cuz of the extra weight of the MrRC Sound transducers in the engine bays. Once that was trimmed out, man did she fly great. Got to admit though the sound card sounds cool, but the dual props sound amazing..... Got a good 4 flights on her and averaged 8 mins flight time on a 6S 5200mah 50C batteries. Couldn't have asked for a better maiden...
                  Cape Jets
                  What motors did ya use with the 6S power You said batteries as in plural for more than one, where you using 2 of those 6S 5200mAh 50C per flight ??
                  • Cape Jets
                    Member- Jet Jockey
                    • Dec 2020
                    • 120
                    • Cape Cod, MA
                    Originally posted by OV10
                    Cape Jets
                    Stock motors that come in the plane. 11X7X3 props though.... Only one 6S battery per flight. Thats a tough fit just for one to get the CG right.
                    • airotroy
                      • 31
                      You did a great job on a great plane. Well done. I'm just about to push that button and purchase this one. I have no need or desire for the upgrade motors and props but interested in what mods you might of made or problems to watch out for in building. The nose art is really nice from Callie and one thing I'd like to add as I'm not crazy about those that come with the plane. Good that you finally had some flying weather. Here in NC we've had tons of rain but its warming up nice mid day and flying more. Which gear struts did you go with ? And are those the DuBro tires shown on the sight.?
                      Thanks in advance for your help and once again - beautiful plane.
                      Russ NC/USA
                      • Cape Jets
                        Member- Jet Jockey
                        • Dec 2020
                        • 120
                        • Cape Cod, MA
                        Russ NC/USA
                        I would buy this plane again in a heart beat. This is likely gonna be my favorite plane to fly(but don't let my jets know that- F-15 Eagle, F-18 Blue Angel, F-16 Thunderbird and my faithful Habu STS) Upgraded struts came from Motion on the options page, DuBro- Low Bounce 2.75" front and 3" mains. Be prepared to make some adjustments to the foam in the gear bays to make them fit in the gear wells. Also will need some minor shims on the mains so the tires don't hit the struts. Only thing I did for 6S power is go to the 11X7X3 props. ESC and motors are stock with the plane. I run alot of 6S and seemed like a good option so I wouldn't need extra batteries just for her. When you hear her and see her in the air with the dual props you will be glad you got her. Cant wait till the weather finally breaks up here to get her in the air again and again...
                        • airotroy
                          • 31
                          Did you buy your 11x7's on Motion and are they like the originals counter rotation ? Noticed in your pictures that the black paint on your fuse has a sheen to it and stands out really nice. Is that from applying minwax polycrylic or does the plane come that bright. What I'v seen in pics is kind of a dull black color. I usually coat my planes with the poly as it helps preserve the paint, decals, and foam in the hot summer sun. Also water proofs when we fly off ponds with floats. Thanks for the tips and info - I'm sure I'll have more questions as I get into this and appreciate your responses. Russ
                          • Cape Jets
                            Member- Jet Jockey
                            • Dec 2020
                            • 120
                            • Cape Cod, MA
                            The struts and tires are from Motion. The 11x7x3 Props are Master Airscrew and yes you order on counter rotating and one standard rotating prop. To fit those you need to make some mods to the prop backing plates and the spinners. Yes, I coat all my planes with Minwax Poly to get a nice shine on the plane. I apply all the decals first then 2 coats. One real thin coat and one heavy coat with a foam brush. Minwax levels out really nice and shines great.
                            • airotroy
                              • 31
                              Exactly how I do it and my planes all look brand new (except the bone pile) What battery are you running in that 6s . Im finding the Zee's on Amazon at that 5200 50C rating.
                              • Larry D
                                • Feb 2020
                                • 58
                                Recommendations for placement of receiver and Hobby Eagle AS3S in the P-38.
                                Guys, I just purchased the P-38 and before it arrives I want to get my assembly game plan together. I know the P-38 has been out for a long time, so there has to be a lot of experience with this. I would really like to hear some recommendations for locating both the receiver (I will be using a Futaba R3008SB) and a Hobby Eagle AS3S V2 "gyro". If you know Futaba, they don't make a receiver I can use with integrated stabilization, so the HE AS3S V2 is my choice to use. I am currently using this combo in my F7F-3 Tigercat and it works perfectly and that was a TIGHT fit. This is the same combo I will use on the P-38. I also know that so many rc pilots do not believe in "gyros" or stabilization, but I install it on planes I like to keep, even if I never turn it on.
                                ANYWAY - Apparently the P-38 is pretty well known for a wiring "rats nest" already and it appears there is very little room in the nacelle for anything else. SO...any helpful, constructive, recommendations or "this is what I did" would be sincerely appreciated. Pictures are always helpful too :) Thanks in advance!
                                • Cape Jets
                                  Member- Jet Jockey
                                  • Dec 2020
                                  • 120
                                  • Cape Cod, MA
                                  You are gonna love this bird.... For what it's worth here is a picture of how I set up the receiver and HE Gyro. Gyro should be a close to CG as possible and this position is pretty close.
                                  Also must do's: Upgrade to the strut landing gears and larger wheels. 2.75 Front- 3" mains. Pilot Ryan has a video on this upgrade. Good Luck and Good Flying....
                                  • Larry D
                                    • Feb 2020
                                    • 58
                                    Thanks Jets. That's a huge help. I got her in Thursday and all is assembled (minus the gyro for right now). My thoughts ran exactly where you placed your gyro. Will do that. As soon as MRC has the strut upgrade back in stock, it will be ordered and installed. I got the DuBros, 2.75 for the nose and 3" for the mains...but ran into a slight issue with the 2.75" on the nose gear in that the collar will not go back on very far and I honestly don't think it will stay. My other issue with just putting the larger (3") on the mains is/was that the head of the grub screw on the right main was "stripped" from the factory. The others came off fine...go figure. Thanks again and I am looking forward to flying this beautiful aircraft. Maiden SOON!!!
                                    • Larry D
                                      • Feb 2020
                                      • 58
                                      What am I doing wrong? Guys - I was installing the DuBro low bounce 2 3/4" treaded wheel on the nose gear of the P-38 and there is barely 1/16" left to install the collar back on. Yes, I removed the spacer prior to trying to get everything to fit. Simply put, the axle seems to short. I installed it anyway and after a few rolls to check it, sure enough the wheel came off. What am I doing wrong? I know there have been lots of pilots of this wonderful aircraft that have switched out wheels on both the nose and the mains. What did I screw up?
                                      BTW - the maiden went beautifully. One of the most experienced pilots at our field did the honors and after some trimming flights...YES!!! My turn next :) Many asked about the wheels and why I had not upgraded to the suspension struts. Simple - they are out of stock. As soon as they are restocked, I'll get them in and do the upgrade.
                                      Thanks for all your help and encouragement. I am very proud to have this one. She's a beauty!
                                        • 4829
                                        LD, Bravo Zulu, Sir. Best, LB
                                        • Larry D
                                          • Feb 2020
                                          • 58
                                          Just HAD to share. THANKS CALLIE!!!!!! Custom nose art. 43 years ago My Girl said yes when I asked her to marry me. I thought her portrait as nose art was a perfect pairing on this P-38. Yeah, I'm proud!
