My Havoc did a high speed belly landing on a bad takeoff. The motor does not align because the plastic mounting has moved partly forward. It does not push back into place. Does anyone have any suggestions. I might try heating the inside front up with a hot air gun and putting pressure on the plastic mount to bring it back into alignment.
Official Skynetic 1000mm Havok Racer Thread
I would highly recommend you order a new fuselage. You can probably fix it so it will fly, as I've did this with my EFExtra's, (very very similar to the Havok). I've don't usually feel the need to replace the fuse, even though the plane might be a little under par. But my favorite one, my green one, (my favorite color) I just had to have it right, bought a new fuse. Good Luck!
Woody
True, I have a foxeer mini in my fpv zohd dart, which is pretty small. They also make a nano, which is smaller.Originally posted by AceMigKiller View PostIt's a pretty small canopy to be honest, but very well made and pretty clear.
Could be fun! Or could make you sick because it's moving at such a high rate of speed!
That's what Andrew told me yesterday. I thought about the v900, but I want to put a fpv camera in cockpitOriginally posted by becevit View Post
Wow no waay :( that's they told me on June 23rd when I posted this msg. No way I'll wait another 5 weeks.... maybe I should just pick up the V900..
