My Havoc did a high speed belly landing on a bad takeoff. The motor does not align because the plastic mounting has moved partly forward. It does not push back into place. Does anyone have any suggestions. I might try heating the inside front up with a hot air gun and putting pressure on the plastic mount to bring it back into alignment.
Official Skynetic 1000mm Havok Racer Thread
I would highly recommend you order a new fuselage. You can probably fix it so it will fly, as I've did this with my EFExtra's, (very very similar to the Havok). I've don't usually feel the need to replace the fuse, even though the plane might be a little under par. But my favorite one, my green one, (my favorite color) I just had to have it right, bought a new fuse. Good Luck!
WoodyComment
It's a pretty small canopy to be honest, but very well made and pretty clear.
Could be fun! Or could make you sick because it's moving at such a high rate of speed!
True, I have a foxeer mini in my fpv zohd dart, which is pretty small. They also make a nano, which is smaller.Comment
Now running an APC 8x6, the 8x8 was too much, launch is better and components staying a bit cooler. Clocked at 130 straight and level,this prop feels about perfect to me. I have to say this is a really slick plane.rc flyin addictComment
I too, settled on the APC 8x6. For what it's worth, sand down the sharp leading edge to a round edge with super fine sandpaper, balance it, then install it for some added mph and efficiency!!!Comment
+1 true, the 8x8 was nearly perfectly shaped out of the box, the 8x6 had allot of flash, I like the broad foam filled nail files for the shape balance and sharpen. This is a really fun plane.These props are allot quieter and more efficient than the stock one.rc flyin addictComment
There's not a "huge" difference in MPH between 8x8 and 8x6 on 6s. Haven't really played with 5s.
I've had the best luck on 8x6e APC (smoothed and balanced as mentioned above) so I'm gonna stick with that.Comment
