    • 8749
    Originally posted by Ric
    Looking for some help reprogramming ESC's. Mine are set to "Brake On". Need to reprogram to "Brake Off".
    It's similar to throttle calibration. Throttle stick to max, plug in plane (with one throttle input at a time), wait for initialization beeps, then at the end of the next set of beeps, lower stick. Repeat for the other throttle input. If you need a visualization of this, go to YouTube and search for "ESC brake set". Or download most any ESC instruction manual.
    • Mr D
      NASM Docent
      • 33
      • Silver Spring, MD
      Download the ESC manual found on the MRC website for the B-24. It is the same power system and gives you the tone sequence for changing the brake and setting throttle calibration. See attached.
      • Gilatrout
        RC Pilot Addict
        • 806
        • Albuquerque NM
        Originally posted by vduniec
        I don’t have the wing pylons made yet. Hoping to design and print them at some point. If you’re going to do a Desert Storm bird, you may want to add this. It is the ALQ-144 IRCM “Disco light” jammer. It goes on the bulge on the top at the back of the fuselage.
        Here’s the link on Thingiverse: https://www.thingiverse.com/search?q...&sort=relevant
        cool, I hope some of you geniuses with the 3d design skills can do something about that cockpit too.
        • Narly
          • 52
          • Wunderful Wyoming
          OK, "build" complete w/ a few hanger rash spots. Tried to match OD with extensive collection of Model Masters, Floquil, Testers, Tamiya & Revell bit nothing very close. So, has anyone found the OD matching paint??
          ..... and what a beaut her is!! 😄
          • themudduck
            -TMD- Foaming at the Mouth!
            • 1041
            • Burton OH (near Cleveland)
            Sunday evening I picked up a jar of paint at Home Depot, color matched - I needed to touch up a couple of spots after my "tree adventure". But this isn't OD. Its a medium forest green.
            I think its extremely close to the OEM color.
            Base: Behr PP103 (flat)
            Color Codes: CL:88 DL:36 KXL:12 LL:187
            In this picture, this paint was used to touch up the bottom edge of the cockpit below the plastic. I'm happy with it.
            • sam51401
              • 368
              • Sellersburg IN
              I seen this earlier and i think they were on the D and D+ versions but i havent seen any photos of it on the A's. I will be looking for your pylons when ready and are you going to use the FW clips for attachments?
              • themudduck
                • 1041
                I looked it up, here's what the real thing looks like. Pretty cool!
                • sam51401
                  • 368
                  • Sellersburg IN
                  Ok, you got me curious and i did find pics of several with disco ball on A's. 454, 459 and 473 have them mounted.in several photos in DS.
                  • Phantom
                    • Mar 2019
                    • 504
                    • M.D.
                    ALQ-144 is what was standard on my Hawks back during my 1st deployment. I was enlisted then and everytime we landed and shut down I was up on top cleaning it, keeping those mirrors shiny. It's not exactly a jammer.... that's all I can say about that.
                    • MikeT
                      Here......Hold my beer.
                      • 1060
                      Assembling mine today. I'm really impressed by the finish and parts fit on this.
                      Mike
                      • Ric
                        • 3
                        Xviper and MrD,
                        Thanks for your reply's and helpful information. I got her all sorted out and will probably maiden tomorrow.
                        • Jpmcdo
                          • Dec 2015
                          • 60
                          I pulled the trigger and purchased the Bronco today. Supposed to be delivered tomorrow. What batteries are being used besides the Admirals? I bought two but would like backups. And has any one used the Admiral 600sp receiver? I didn't include that in my order but can of course get one.
                          • Mr D
                            NASM Docent
                            • 33
                            • Silver Spring, MD
                            I am using HRB 4S batteries purchased from Amazon. She flies beautifully with a range from 3300 to 4200 mAh.
                              • 5385
                              Hobby Star 4600 35c 380g each.
                              • vduniec
                                Hobby Squawk Pilot
                                • 314
                                She’s flown nicely for me on HobbyStar 5200’s and HRB 5000’s.
                                • ronwc
                                  AMA 1025
                                  • 37
                                  • Largo, FL
                                  The plane is very power efficient. I'm using 3700mah 45C Roaring Top, and after about an eight minute flight today (3/4 to full power), still had about 70% power left. Which tells me I could fly for 15 minutes easily.
                                  Ron - AMA 1025
                                  • themudduck
                                    • 1041
                                    Same thing I noticed - I flew two flights with a set of Admiral 3700's - first flight was 6 minutes and the second was 4 minutes - and after that they read 45% remaining. So its pretty obvious to me that 15 minutes is probably doable. (Third fight was with a different set of 3700's). More testing this weekend hopefully!
                                    • sam51401
                                      • 368
                                      • Sellersburg IN
                                      Thought i would tease ya a little
ID:	261493Click image for larger version
                                      • KC8REH
                                        • 17
                                        • Grand Rapids, Mi
                                        I am wondering what the flap/elevator mix works best. The book says + 9% on low rates and + 18% on high rates. mine had problems with this mix. Also gear up or down to ballance. The book does not specify this. Thanks!
                                        • yf22raptor
                                          Love to fly
                                          • 75
                                          Had to change the struts and wheels to more scale
                                          used freewing t-45 struts , gonna paint the struts and wheels white .
                                          Also have a freewing yak 90 nose strut gonna try it out see if it works ..
