  • t01ga
    " T "
    • 197
    • UK
    I like the wiper!
    About the latch, I don’t understand “and ca the other end”. If you take the latch apart there is a hole and set screw in the bottom of the part that sticks up (the pat you move with your finger), the latching pin goes through the hole and is held in place by the set screw. If you can pull it with pliers it’s loose and will end up moving. Plus moving it means the back part of it is no longer in the hole it’s supposed to ride in. It may be working but it may end up where you can’t open the canopy or it loosens and the canopy comes off.
    You can pull the pin and then drop a little CA on the pin just before the spring. It works for me and it is solid.
    Tolga
    Instagram: @_t01ga_
    YouTube: t01ga
      • 5402
      Ahh. to aid the setscrew. Got it.
      • Rcfiddy1
        Professional Crash Test Dummy
        • Aug 2015
        • 186
        • Manalapan, NJ
        wiper
        https://www.thingiverse.com/thing:2632986
        • flgboy
          • Nov 2019
          • 5
          Is anyone having issues taking the outer wing panels off? Mine will not budge, even when wedging in a thin shim or screwdriver to try and force them apart from the engine nacelle.
            • 8824
            Nope, mine goes on and off like “loosely goosy”. You should try a little light oil or silicone spray in the slots where the pegs go in, assuming you can get them apart again.
              • 5402
              Yes, loosely goosy... Some other planes didn't get the bits aligned right. Everything is perfect on mine.
              • vduniec
                Hobby Squawk Pilot
                • 314
ID:	263062 Here is a wing pylon for the outer panels that I designed. It is not an exact scale replica but it's as close as I can get interpolating off of various photos and drawings found online. I designed it to accommodate the freewing stores mounting system. There are attachment points for both the top and the bottom of the pylon.
                https://www.thingiverse.com/thing:4530629
                  Did anyone use my 7 tube launchers?
                  • Jpmcdo
                    • Dec 2015
                    • 60
                    I haven’t decided if I’m going to hang all the ordinance on the plane while I fly it, but if I do I think what you did was cool.
                    • t01ga
                      " T "
                      • 197
                      • UK
                      Originally posted by Rcfiddy1
                      That is the one!
                      Tolga
                      Instagram: @_t01ga_
                      YouTube: t01ga
                        • 5402
                        I got the markings on and took it for a spin this morning. It was windy today so the nervousness in yaw was back.
                        • Jpmcdo
                          • Dec 2015
                          • 60
                          Dumb question but need to ask anyway!
                          If the purpose of wiring the batteries in parallel is to keep both motors operating in the event one battery goes out and or use smaller batteries to get more power to the motors, then why would it be advantages to do this if one of the ESC's goes out? I maybe lucky but have never had a battery go out on me. I typically fly scale and usually land with at least 40% left in the batteries. So if I'm right, parallel will not help if one of the ESC's goes out.
                          Am I wrong?
                            • 8824
                            I answered your question in the "other" forum. I won't go into it much as I'm a bit more polite here.
                              • 5402
                              😃 Yeah, the "other place" is the jungle!
                              • ronwc
                                AMA 1025
                                • 37
                                • Largo, FL
                                Just to let you guys know, test flew my OV-10 today with the APC 10x8 two blade props, not counter rotating. It made quite a big improvement in speed and pull, which is what I was hoping. The airspeed itself was probably 5 to 8 mph faster, but the big difference was in the pull going up, mainly in doing a loop/climb, definitely better. The non counter rotation made no difference at at, not that I thought it would. I may try two 10x10 props later, but right now happy with it. The total price for to 10x8 props and two 2" spinner was about $22. Here are pics of amps and watts with stock three blade and with 10x8 two blade.
                                Ron - AMA 1025
                                • Jpmcdo
                                  • Dec 2015
                                  • 60
                                  Well said, thanks for the reply.
                                  • flgboy
                                    • Nov 2019
                                    • 5
                                    Transporting this plane is a bit awkward. Here is how I ended up wall mounting it. Most other small planes can be go on the wall straight in or sideways.
                                    • Bellke
                                      • 118
                                      • AZ
                                      I don't know if this was previously mentioned... I was catching up on a few podcasts and the guy from Legends Hobby (formally VQ Warbirds) was on and said they will be having an OV-10 towards the end of the year. WITH A 14 FT WINGSPAN. My first thought was what the heck are they going to power it with? He went on to say a couple of his "premier" customers that he gave a heads up to mentioned putting a couple of turbines (turboprops) on it. Now that would look scale.
                                        Originally posted by Bellke
                                        I don't know if this was previously mentioned... I was catching up on a few podcasts and the guy from Legends Hobby (formally VQ Warbirds) was on and said they will be having an OV-10 towards the end of the year. WITH A 14 FT WINGSPAN. My first thought was what the heck are they going to power it with? He went on to say a couple of his "premier" (Code for Doc/Lawyer that can afford $10-20K birds ) customers that he gave a heads up to mentioned putting a couple of turbines (turboprops) on it. Now that would look scale.
                                        And it would need it's own dedicated rollin hangar too :smirk: I'm just hangin loose to see if that A-1 that they just acquired is gonna have any quirky issues before I step up :star_struck:
