  • MikeT
    I maidened mine this morning. With the elevator set "level" as much as I could see using the molding lines on the vertical tail fins, I had to apply several clicks of DOWN trim to stop the plane from climbing at cruising speed (for me, that was about 3/4 throttle).
    On that note and at my altitude of almost 3500 feet, I found this plane (stock) to be somewhat anemic (read: under-powered). It flew fine with a perfect take off and fairly decent landings with a crosswind. However, I found it would not do a loop from a full throttle level pass. Even putting it into a shallow dive, it just barely made it (sloppy ovoid shape). If you want to fly it "scale", fine, fly it scale but man, going round and round and round gets boring real fast. Next up: increase the size of the ESCs and putting on the counter-rotating Scimitar props (10x8x5) from the EC1500. These props (on lower kv motors) make the EC1500 really lively. If the motors won't handle it, I'll get ones that will. Flew for about 7 minutes (3.8v/cell) on twin 4000 Admirals.
    Thanks
    Mike
  • MikeT
    Originally posted by Evan D View Post
    Yes, though for the flight it was noted I was not the pilot.
    Thanks
    Mike
    Right on xviper
    Round and round and round does get boring real fast and so does loops but doing touch n goes is a fine art skill that more pilots need to hone their landing skill levels on and this bird in stock power will take that abuse all day long.
    Originally posted by MikeT View Post
    Is this from experience with this model? Normally that's what I do but some of the photos I've seen you'd run out of trim.
    Mike
    Mike
  • MikeT
    Up to you but I would set it up by the book and be ready to add down trim. Better than having too much down to start with.
    Mike
  • sam51401
    Originally posted by yf22raptor View Post
    Had to change the struts and wheels to more scale
    used freewing t-45 struts , gonna paint the struts and wheels white .
    Also have a freewing yak 90 nose strut gonna try it out see if it works ..
    Funny you listed those exact struts as Charlie and I had talked about those very struts to use on the Uravitch kit. I see now that the nose strut isnt stocked at MRC so i got lucky. SInce im doing more painting and such, i was going to swap struts after i get a few flights on it. Post more pics of your nose strut when changed over. Thanks
  • Flat-Twin
    Hi there
    any ideas, when shipping to Europe/Germany will start?
  • MikeT
    Finished assembly on mine. Any thoughts on setting the elevator ? Book says neutral but some have started with some down as a starting point.
    Mike
    The book comp is a little too much...
  • Mr D
    Originally posted by KC8REH View Post
    I am wondering what the flap/elevator mix works best. The book says + 9% on low rates and + 18% on high rates. mine had problems with this mix. Also gear up or down to ballance. The book does not specify this. Thanks!
    My setting which work great. Click image for larger version
  • yf22raptor
  • KC8REH
  • sam51401
    Thought i would tease ya a little
ID:	261493Click image for larger version
  • themudduck
    Originally posted by ronwc View Post
    The plane is very power efficient. I'm using 3700mah 45C Roaring Top, and after about an eight minute flight today (3/4 to full power), still had about 70% power left. Which tells me I could fly for 15 minutes easily.
    Same thing I noticed - I flew two flights with a set of Admiral 3700's - first flight was 6 minutes and the second was 4 minutes - and after that they read 45% remaining. So its pretty obvious to me that 15 minutes is probably doable. (Third fight was with a different set of 3700's). More testing this weekend hopefully!
  • ronwc
  • vduniec
    She’s flown nicely for me on HobbyStar 5200’s and HRB 5000’s.
    Hobby Star 4600 35c 380g each.
  • Mr D
    I am using HRB 4S batteries purchased from Amazon. She flies beautifully with a range from 3300 to 4200 mAh.
