New E-flite Fw-190A, 1.5m
  • t01ga
    SanExup Thanks man, appreciate that. You are right; I printed the number and placed a thin clear plastic over and cut it out. The “3” is 3” tall and 1 3/4” wide. Having a clear stencil helps with accurate placement.Click image for larger version
  • SanExup
    t01ga Of course all of the details you have done are amazing. I am drawn to the stenciled numbers. This is one detail I feel like I have to attempt. Did you print numbers and create the stencil template? Do you mind me asking what the dimensions are? They look perfect. The quality it gives versus a decal is outstanding.
  • t01ga
ID:	309959Click image for larger version
ID:	309963Click image for larger version
ID:	309961Click image for larger version
ID:	309960Click image for larger version
ID:	309962Click image for larger version
ID:	309958 Some static shots from the field!
  • Shark102
    I masked off the whole cowl and painted it white. Then used a combination of vinyl decals and painted black squares. Then a covered everything in a satin clear coat.
  • Dora Nine
    How/what did you use to mask the cowl?
  • Shark102
    Originally posted by sfcfury View Post
    Looks good shark! What are you using for the aerial?
    It’s approx 3/32 para cord with 2 springs on either end.. a bit thick I know but wanted it to hold up well.
  • sfcfury
    Originally posted by Shark102 View Post
    My re-paint, looking much better IMHO
  • Shark102
  • t01ga
    SanExup It is a good idea. I can airbrush a lighter green in areas where I want it to fade then put a very light flat coat on the whole plane. I think I see if it flies first 😉 then do the extra work. Thanks buddy
  • SanExup
    Tolga, I apologize if you already know this, but you can apply a really thin coat, over the semi gloss, with the flat to knock down the sheen. It probably won't do anything to restore the green. But I definitely have top coated gloss with matte for that same reason.
    Assuming you used water based poly or acrylic, or polycrylic.
  • t01ga
    quitcherbitchen thanks mate, appreciate it. I had a great dilemma when it came to clear coat between flat and semi-gloss. I must admit I am quite disappointed how the semi-gloss darken my green, masked the light fading of the paint effect and came out shinier than I wanted. Just have to wait natural weathering to take its course. It has been a big learning curve and a great journey.
  • quitcherbitchen
    Thanks for posting. The video does show what a great job you did. I would be afraid to pick it up LOL.
  • t01ga
    For anyone who is interested in seeing all the details on my plane here is video...
  • t01ga
    Originally posted by quitcherbitchen View Post
    Pretty spectacular. I envy your patience. Also, what do you mean it's done? This is a hobby, nothing is finished until you sell it.
    Haha, believe me I am done customising this plane. There is nothing left to add.
  • quitcherbitchen
  • t01ga
ID:	308565Click image for larger version
ID:	308564Click image for larger version
ID:	308563Click image for larger version
ID:	308562Click image for larger version
ID:	308561Click image for larger version
ID:	308560Click image for larger version
ID:	308559Click image for larger version
ID:	308558Click image for larger version
ID:	308557Click image for larger version
ID:	308556Click image for larger version
ID:	308555 Calling it done.
    I should wait too see how it flies but FW190 is now my new favourite.
  • Oxotnik
    jetdoc , nicely done!! Death to the dastardly polka dots!!
  • e4dragongunner
    Just beautiful work.... the word "elegant" comes to mind!
  • jetdoc
ID:	308350 Just finished redoing the "White 14" scheme on my eflite 190. I just couldn't take the "polka dot nightmare" that came out of the box. I completely repainted the entire plane including struts and wheel wells. I noticed that the replica scheme HH patterned the model after was lacking the fuselage green of the original as well as improper coloration. I matched the RLM 74, 75 and 76 colors provided in a Monogram German colors paint chip book with samples from Lowe's. I ended up repainting the wings as well. Graphics are from Callie and I followed it up with a light semi-gloss clearcoat. I refrained from heavy weathering as weekly flying seems to accomplish that just fine. Click image for larger version
ID:	308351Click image for larger version
ID:	308352Click image for larger version
ID:	308354Click image for larger version
ID:	308349Click image for larger version
ID:	308355Click image for larger version
  • t01ga
    Originally posted by BikerPatriot View Post
    job well done this looks great!
    Thanks man, appreciate it!
