New E-flite Fw-190A, 1.5m
  • Oxotnik
    Originally posted by Tim K
    Yep, I have the flightline one and the old FMS 190 that I also repainted in Heinz Bar's scheme. I really like Fw190's
    You’re not alone there. I have the Starmax 1.6m, EFlite 1.5m, and FlightLine 1.1 m Würgers. Yesterday, I took my FlightLine and EFlites 190s to the field.
  • Gilatrout
    Originally posted by Oxotnik
    Heinz Bar's Rot 13. Nicely done!! If you have the Flightline Rot 13, too, you should take "Me and Minnie Me" photo. :-)
    Nice, the weathering looks great.
  • Phatbob
    Any issues with the MRRcsound and the stock ESC? Thanks !
  • Tim K
  • Oxotnik
    Here is my repaint of the e-flite 190. Markings from Callie Graphics of course.
    Click image for larger version  Name:	IMG_3499.JPEG Views:	4 Size:	243.7 KB ID:	301044Click image for larger version  Name:	IMG_3498.JPEG Views:	4 Size:	268.4 KB ID:	301045Click image for larger version  Name:	IMG_3500.JPEG Views:	4 Size:	267.3 KB ID:	301046Click image for larger version  Name:	IMG_3497.JPEG Views:	4 Size:	276.4 KB ID:	301047Click image for larger version  Name:	IMG_3503.JPEG Views:	4 Size:	333.4 KB ID:	301048Click image for larger version  Name:	IMG_3505.JPEG Views:	4 Size:	228.7 KB ID:	301049Click image for larger version  Name:	IMG_3504.JPEG Views:	4 Size:	244.9 KB ID:	301050
  • Tim K
  • Oxotnik
    Yesterday, I put 4 or 5 flights on my Weiss Funf. I was fighting with my dorkcam all day, and only got the camera to stay on for one full flight. The greys and purples are a really good camo; so, I edited out most of the 'invisible plane' and trimming segments of the flight.
    A couple thoughts about this video and the flying/landing characteristics of this model...
    First off, during this video, I was having to fight the flaps with a lot of down elevator. I usually don't like to mix elevator with flaps, if I don't have to, but this model does need a good helping of DOWN elevator mixed in with the flaps. On the aborted touch-n-go approach, there were several things going on. I was fighting the flaps with a lot of forward pressure, while managing the altitude and descent rate with the throttle, then I hit the ground effect (which is very characteristic of our field when the wind is coming from the south (right)), and the combination resulted in a really ugly approach. I ultimately called a mulligan and eased back into the power to go around. I managed the approach and touchdown MUCH better on the second attempt.
    Takeoff. Wow! This plane is an absolute dream to take off. By far, it is the easiest of my planes to take off. Once on the Mains, she tracked perfectly straight, with very little P-factor yaw. After the tail is up and power is further advanced, she eases into the air with a beautifully-scale, low-AOA takeoff.
    Flight. The top speed is good. She's not a speed demon, by any stretch of the imagination, but she's not slow either. Top speed is still significantly above scale speed. I was running 90% throw on both the ailerons and elevator (100% on the rudder), and she felt wonderful in the air. I didn't fly at 100% throw, but I wouldn't expect her to be too twitchy with full throws. I didn't do many aerobatic maneuvers in this particular video, but rolls were nicely axial and Immelmanns and Split-S's were very nice during other flights. Even when I cranked pretty hard on the elevator in an Immelmann, I never felt that I was close to an accelerated stall (snap). She was very well behaved and predictable.
    Landing. Gotta be on your A Game until the Mains are firmly on the ground. All warbirds need throttle to manage the altitude and elevator for the speed, but it's especially true of this model. When throttle is cut, she slows down quickly and drops like a rock. You've gotta work the throttle all the way to the ground. If you try to glide-land this model (using the elevator to control the descent rate), it'll probably result in a really ugly landing. During the 4 or 5 flights that I did yesterday, I shot a bunch of touch-n-goes. Some were really good, a few were so-so, some were ugly. I had a few approaches there were looking really nice, then right at the end, I'd further reduce the throttle for her to settle in, but she drop more quickly than expected... and would bounce. The compressed springs in the struts really want to unload. Bounces are ugly.
    Overall assessment. Takeoff and flying characteristics are wonderful. For landing, use very good technique. She'll be VERY unforgiving of less-than-perfect landings.
  • Oxotnik
    Gilatrout, Beautiful work! After putting work into an aspect of a repaint, and having it turn out well, it's a great sense of accomplishment. Great work. Can't wait to see the fully completed Graf Wurger.
  • starcop
    Thank you.
    This tail took most of the day and is only one side.
    Both sides were painted white and then I generated painting masks to protect the white where the red decals would go. Then on went the yellow.
    Then came the part where my computer froze and I lost my decal templates. After recreating the decal templates, and printing them out, I was just able to put them on the one side before getting too tired to keep it up.
    Tomorrow, assuming I don't run out of decal paper will be the other side, the paint masks and decals for fuselage crosses, and the swastikas.
    I will say that even though this has been a lot of work, this plane has been an absolute joy to repaint.
    That is pain-stalkily a lot of work. The final product will be a re-creation of what you see. An Artist at work! Bravo, bravo. Beautiful job!
  • Gilatrout
    Originally posted by starcop
    Looks Fantastic! Excellent. Yes Sir, it's just time well spent.
    Thank you.
  • starcop
    Just takes time.
  • Oxotnik
    Yep. An airbrush can work miracles. Herr Graf would be proud.
  • Gilatrout
    Easy fix though...
    Just takes time.
  • starcop
    The paint job is bloody awful. Polka dots, really?
    Easy fix though...
  • Oxotnik
    Double posted. My apologies.
  • Oxotnik
    Originally posted by Cfreuen20
    LOL I didn't hear anything, I was just looking at the list in your signature.
    Ah. I haven't deleted it from my list of planes. I guess I should, but that'd be like finally admitting that my beloved is actually gone. I'm not quite at that stage of mourning. LOL
    Someone has also commented on a video or two of my Do-335 within the last few days.
    Seriously, the BH Do-335 is a fine aircraft. As I'd set it up with dual 6S batteries and a pair of Power 60 class motors, she was heavily wing loaded. She flew fine, was very predictable, and landed well. Just had to keep her speed up. She doesn't, however, like to do a Split-S maneuver from below 100'. LOL
    I really regret dumb-thumbing her so badly.
  • Cfreuen20
    Why? What have you heard? It's all lies!!!
    LOL. Well, she is no more. I did a terrible dumb-thumb and smashed her into the ground. She smashed so hard that the two batteries caught on fire, and the young man who was helping me pick up the pieces handed me three 3mm wood screws saying, "Here, you can use these again." The short story is that it was late morning and the Sun was still on the other side of the runway. I came down the runway, medium height, and rolled her. As soon as the roll started, she went into the Sun. When she came out of the Sun her wings were mostly level and nose down a bit. Thinking that I'd completed the roll, I gave her up elevator. But.... she had only half rolled... and DOWN is UP and UP is expensive... very, very expensive.
    I really liked the BH 335. I ordered it as soon as it was announced (there's a definite theme here...). The BH ARF is well constructed. I installed two 5055 motors (390kv, IIRC) with MAS 16x10x3 props. She had plenty of power. I flew her on a pair of 6S-5AH (plugged in parallel). She was very stable, flew well, had gobs of power. Landed easily, but had to keep the speed up. What I didn't like about her is that the ventral stab is integral to the fuselage. With much of a flare, or if gear failed such that a belly landing was required, the tail (and thus the rear fuselage) was going to be ripped off. So, I decided not to get another one, after smiting mine.
  • SanExup
    A good review of it.
  • Oxotnik
    oxotnik -off topic, but how do you like that BH Do-335? I have their 2000mm spit, and like it quite a bit. the 335 was certainly intriguing.
  • Cfreuen20
