    Would be absolute standup if FL would do a 1600 version of the Bear as well as the Hellcat too since it was such a turning force of the Pacific battle.
    Dan, I know you would be like number 1 or 2 in the preorder line for a Bear of that size knowing how many times you have indeared the many 1200's.
      • 7438
      Yes, I would, but now you see the prices! The 1200 mm Bearcat released at $199.00 and now is up to $279. The last one I got was obviously old stock, the decals wouldn't even stick to the plane. Yet it's shelf value increased. Still, can you imagine a 1600 mm 6s Bearcat (Or Hellcat for that matter) with actual scale landing gear and a folding tailwheel?
      Ahhhh, I'm still holding out for a P51B as well.
        Yes please to a 1600mm Bearcat!
          • 7438
          Bits and Pieces update.
          She's assembled and painted, all systems are working.
          I used the receiver from La Patrona and had the blue box sitting in storage, all worked well.
ID:	338171Click image for larger version
ID:	338172Click image for larger version
ID:	338173Click image for larger version
          Still have some work to do, The battery deck has to be manufactured and installed, I'll use the one out of the other Bearcat for a template. Note to self. Make a pattern of all pieces that can't be bought.
          I found that making everything blue really added to the authentic look, apparently, from what I've seen and heard in videos, Grumman painted them blue and slapped them out.
            • 7438
            The 3948 760kv motor seems like an ideal upgrade for this plane. The motor mount fits into the stock holes, the prop shaft was from La Patrona and the stock Bearcat prop fit onto that perfectly, so the stock bearcat prop shaft will mate up to the motor. I'm dealing with a slightly bent nose so I shimmed the motor to align it properly. The stock radial motor fit over the motor even with the damage to the nose, with no mods as well. I had the other 760 kv and weighed it against the 650 that I have in the other Bearcat, the 760 is lighter but heavier than the stock 580kv motor. The nice thing is that with the battery back, she CG'd up without having to add weight to the tail. Anyone looking for this motor, I got it from one of the 3D FMS birds, can't recall which one but it should be easy to find on the Horizon Hobby website, or Motion may have an equivalent motor.
            Just judging from the amount of throttle for taxiing and comparing it with the other Bearcat, she looks to be more powerful. can't wait to see he fly, I'm just waiting for an A3L which is on its way. With the ten channel receiver, I can vary the amount of gyro by using the control knob, it just doesn't get any better.
            BTW, the battery deck is installed, I used the one out of the other bearcat and trimmed the excess off an old battery hatch floor and it worked great!
              • 7438
              Well, the sun is out and the Bearcat is complete with the installation of the A3L yesterday. Traditionally, all my planes get their pictures taken out on the deck. Is it perfect, no, but it's damned close and considering the parts, with the exception of the motor, ESC and main landing gear wheels, are all from a plane that went down in 2017, she's an unexpected surprise!
ID:	338577Click image for larger version
ID:	338578Click image for larger version
ID:	338579Click image for larger version
              I'm noticing a pattern in the fleet now. Two Bearcats, two Spitfires, two flyable Mustangs, two P40's and two Pandoras. Hmm, wonder if that's significant?
                OV10 commented
                Editing a comment
                And I also noticed a pattern, that black cat is always lurking in the background during these glamour deck photo shoots.
                Since I live in the area where Rod Serling came from, I am always at mind to think is there a Twilight Zone
                event connecting your black cat luck to crashes LOL
            • boomer108
              Chief Boom
              • Apr 2014
              • 868
              • Chicago IL.
              Looking good Gman!
                • 7438
                We have three tuxedo kitties, all the same litter, so it's likely they are in there somewhere.
                They love to come down and watch me work on the airplanes, what can I say??
                  • 7438
                  Maiden today. I guess its a maiden as she's pieces from three airplanes flying in formation. Anyway, it flew, well like a Bearcat flies, a couple of clicks of elevator and she was in the groove. One gear door is giving me trouble so I'll have to play around with that, but otherwise...
                  I can honestly say that I've never had an issue maidening any of my Bearcats, this being, in essence the fourth maiden, she's a great airplane and with the upgraded power plants in both of mine, I've never had an issue with slow flight or landing.
                  • Terrible T
                    • Feb 2022
                    • 10
                    • Vancouver, WA
                    Hello, first post in/on this forum.
                    Recently decided to try a war bird. Came across a Flightline F8F 1200mm Bearcat which was affordable so picked it up. The bird was/is basically a derelict as its previous owner flew it hard and put it to bed wet (literally wet). Flew it with only two of the four props. Belly landed the bird most of the time (according to the owner) and generally took no to little care of it. Being a sucker for mistreated aircraft I brought it home.
                    I've had it up once now and it does what I expected. Not hard to fly at all if one keeps its speed up. I am however, wondering it I should replace the main gear as they both seem to be wobbly. The bird will taxi fine and takeoff and land fine BUT the gear just seems somewhat loose. Question is what is too loose for this bird? Hoping someone here can give me some insight.
                    Regards,
                    Thomas...
                      • 7438
                      There is a set screw at the base of the strut and the retract. It's a little difficult to see and only accessible when the gear is retracted. See if you can find it and tighten it up, I had the same thing.
                      • Terrible T
                        • Feb 2022
                        • 10
                        • Vancouver, WA
                        Greatly appreciate the information Grossman56. Went out and found the two grub screws positioned at the side of the trunnion/s. Tightened all four of them up but the loose strut/s remain.
                        While going through the process of locating the grub screws I did find what I believe to be the real problem, however, as both retract servos mounting flanges are broken across one side. If it were not for the metal cap each landing gear servo would simply rotate out of position on landing. It appears the metal cap/s are acting to hold the broken section of each flange in place. The cap also is splinting the remainder of the two flanges thus fixing both gear in place for now.
                        I could not locate the set screw/s.
                        Regards,
                        Thomas
                          • 7438
                          Regards,
                          Thomas
                          I'm not sure if you have the manual for the airplane. A few years ago I rewrote some of the manuals and still have them on my PC, here's what I was referring to:
Name:	Bearcat landing gear.PNG
                          As you can see, 'H' is the set (grub) screw I was referring to. It's easier to access if you remove the retract from the wing. Make sure both are tight as they will cause the wheels to slop in a toe in/toe out manner and if they're really loose, the retract will fall out. Hope this helps.
                          • Terrible T
                            • Feb 2022
                            • 10
                            • Vancouver, WA
                            Yes, the two grub screws identified in the above diagram are the screws I mentioned. I tightened both for/on each strut.
                            Took the bird out this AM. Handles well during taxi, takeoff and landing. One would not think so though when the gear are tested and there is such a great amount of slop.
                            Appreciate your attention to my question/s.
                            Regards,
                            Thomas
                              • 7438
                              Not a problem Thomas! One Bearcat fan to another!
                              • Terrible T
                                • Feb 2022
                                • 10
                                • Vancouver, WA
                                In need of a wing set for this Bearcat. The current set are functional BUT barely. Motion lists the sets as "Out of Stock". Wondering, and I know this is a long shot, if anyone here has a serviceable set they would like to sell?
                                Regards,
                                Thomas
                                • Herrsavage
                                  • Mar 2022
                                  • 14
                                  I have read elsewhere that this plane is not very good on grass.. Would you guys confirm that? 1200mm is my preferred plane size, but I only have grass to fly from. I have long wanted this plane, but was put off by reading that it didn't handle grass very well. Thanks.
                                  • Terrible T
                                    • Feb 2022
                                    • 10
                                    • Vancouver, WA
                                    My two cents.
                                    If I only had grass to land and takeoff from I would pass on the 1200mm F8F Bearcat.
                                    My experience to date with this airplane is limited, only having had it for a short time and having purchased it used. That said, on my airplane, the main gear are sloppy moving side to side, fore and aft excessively. This excessive movement is not only due in part to wear and tear but also to the stance/geometry of the main gear. Said movement does not however seem to cause issues during taxi, landing and takeoff while on our asphalt paved runway. However, once off the runway and on the mowed grass (field grass) things quickly change, as the airplane will come to an abrupt stop and nose over.
                                    It might be different on a well groomed grass field I suppose but given what I've experienced it would have to be a very well groomed one.
                                    All in all, I enjoy flying my Bearcat even with its sloppy undercarriage (used and abused) but as stated I have a paved runway to fly from and to.
                                    Regards,
                                      • 7438
                                      The Bearcat landing struts are wire covered with plastic, they are long for this size of model so if the wheels meet some resistance, it tends to torque at the wing/retract connection. Over time, you can see lines forming on the top of the wing and eventually, they may break out, as mine have on many occasion. With the recently rebuilt B'cat, I used some flight metal cut to shape and wrapped from the top of the wing over the leading edge and back over the lower wing. I made a template out of paper first and got the shape right then applied it, painted over it and it's much stronger as a result. I've heard guys using packing tape to do the same thing, but I figured a layer of aluminum would be ideal, besides I have a bunch of it laying around. I was hoping that they would come out with an upgrade for the struts, putting a spring loaded shock absorber in it, but not likely now. So the only other thing we can hope for is a 1500 to 1600 mm Bearcat in the future!
                                      • WillCorsair
                                        • Aug 2021
                                        • 21
                                        • Kansas City area
                                        Do you have any pics of your mods? Thanks.
