  • Coconut
    • Apr 2019
    • 212
    What's that you're using to check the CG?
    • Trhodes
      • 11
      • Colorado
      It's a couple of dowels that attached to base...they're about 12-14" long with felt pads on the ends to protect the wing. Pretty easy to gin up.
        • 7385
        Looks good! I run a 650 KV with a FMS 1400mm Corsair prop on the Blue Angels Bearcat.
        Click image for larger version  Name:	IMG_5302.jpg Views:	0 Size:	134.4 KB ID:	356794
        I had to put a tab of stick on weight for the CG
        Click image for larger version  Name:	IMG_5311.jpg Views:	0 Size:	195.2 KB ID:	356795
        So I hollowed out a square and fit it in, I usually run the battery back a bit but the CG is pretty forgiving.
        On this one, I use Dave Brown tires, I love those I swear you can hear them suck onto the runway.
        With the other Bearcat, used a 780kv with the stock prop and didn't have to use any tail weight.
        Click image for larger version  Name:	IMG_5650.jpg Views:	0 Size:	148.0 KB ID:	356796 Performance wise, they are, at least to the eye, identical.
        One thing I've noticed with both is the tailwheel likes to jump and I'm thinking of a Dave Brown tailwheel to save my prop tips. You have to taxi very carefully at our field as the runway surface is not the best to say the least.
        Still waiting on a 1600 mm Bearcat.....
        • Trhodes
          • 11
          • Colorado
          Update on the maiden yesterday. Had two good flights - really like how this stays straight and with just a touch of right rudder, takes off at half throttle or a bit more. My club has a nice geo-tec field about 600 feet long (?) or there abouts.
          On the second landing I forgot to use flaps, came too fast and got a bounce. Left landing gear came out. Looking at that gear there was less than 50% glue adhesion in that gear pocket and on the gear. Put it back with a liberal amount of hot melt glue. It did cause a small crack on the top of the wing.
          First time using the HobbyEagle A3Super 3 and liked that system a lot. Need to get more familiar with it.
          All in all, it went well - repairs made, and ready to go again maybe Thursday. We'll see.
          • flyingiceberg
            • 58
            • Austin Texas
            I have been off the forum for quite a while. Has anyone managed to put safe in this plane? I want to let my son fly it. I have a spare AR636A I can use. I use Spektrum. NX10. If there's another way to do it with other spectrum receivers I'm open to other options as well. I'm just not that good with the programming yet.
              • 8814
              Did the AR636A come out of another plane? It may be "locked". However, even a locked one can be wiped clean and "updated" so that you can program your own parameters into it. That being the case, yes, it can have SAFE on it. It may already have SAFE installed.
              • flyingiceberg
                • 58
                • Austin Texas
                Not yet. It will come out of the Pawnee Brave Night Flyer. Since my last post I have learned more about forward programing with the right receiver which I don't have yet. I have already unlocked the AR636A. I want to get safe on a few of my planes, the BEarcat and Pawnee included as well as an FMS P-51
                  • 8814
                  It will most likely be "locked" and tailored to work in the Pawnee. But if you know how to unlock it then, there should be no problem programming it the way you want. However, I did unlock an older 636 out of an Opterra and there are many things that cannot be done with it.
                  • flyingiceberg
                    • 58
                    • Austin Texas
                    I may just pick up the AR631. Forward programming looks a lot easier than trying to figure out the safe programmer.
                      • 8814
                      Great idea and probably your best option. Some of my unlocked "safe" receivers will not forward program at all. The 631 is likely the most efficient and cost effective way to go about this for many planes. I've used several myself when I'm not using the HobbyEagle type of receivers, which can also provide a similar function to "safe".
                      • zepovinho210
                        • Oct 2022
                        • 3
                        This is my first tail dragger warbird in the 1.2 meter category.
                        I can assure you that this plane does not need any kind of SAFE or AS3X at all. It tracks rock solid and can handle wind with ease. I don’t use them at all. I use a 620 antenna less rx.
                        With an Admiral 3600 4s or a Spektrum 4000 4s all the way forward, the plane balances perfectly. No need to use nose weight.
                        Set up is as per the manual, with 30 percent expo.
                        Great plane. However, mine arrived with the decals already installed so no decal choice.
                          • 7385
                          I would think the easiest way is to Buddy Box with him
                          • edwarda10pilot
                            Advanced Pilot
                            • Jun 2018
                            • 19
                            • Seguin, Tx.
                            Hello all. I just purchased the Flightline F-8 Bearcat and would like to clear coat the entire plane. I would like to use a gloss clear from a rattle can. I have seen other posts where some have brushed on Minmax but I am looking for something in a spray can. Any advice?
                            Thanks,
                            Ed
                              • 8814
                              I use a foam brush to apply MinWax. Rattle cans seem easier and faster but it gets everywhere, every nook and cranny. I don't want to bath the servos with spray. Also, the propellant in rattle cans might dissolve foam if held too close. If held too far, the coverage is poor and you either have to do another coat or you keep spraying longer than you should and the result are runs. I think you can buy MinWax or Polyurethane in spray cans.
                              On the other hand, brushing it on can leave streaks and to get a nice ****geneous covering, a 2nd or 3rd coat may be desired. I just do one coat and leave it at that. I've stopped using rattle cans and prefer to brush.
                              • edwarda10pilot
                                Advanced Pilot
                                • Jun 2018
                                • 19
                                • Seguin, Tx.
                                Thanks xviper. I found some Minwax Spar Urethane gloss clear spray cans on Amazon and ordered a couple of cans . Will report back on the results.
                                Ed
                                • Ks.jetflyer
                                  • 131
                                  I just received mine. Have a question. Can I plug everything directly into the rx and not use the blue box or will that cause problems?
                                    • 5401
                                    You can. You’ll need a couple Y’s but it’s easy to do. I removed mine.
                                    • Ks.jetflyer
                                      • 131
                                      Thanks for the prompt reply. Thats what I thought, but wanted to be sure.
                                      • Ks.jetflyer
                                        • 131
                                        Have mine ready to go. Have a question on the retracts. Mine retract and extend at a rapid speed and are jerky not smooth. Never had electric retracts go this fast. Any thoughts or suggestions?
                                          • 5401
                                          It should be smooth. Was it bought used? Other than a bent jack screw and maybe needing a bit of grease on the jack screw there's nothing to make it jerky. Speed is what it is on these you can't slow or speed them up.
