    • 7387
    Thanks MesRcPilot, if I couldn't laugh about it all the fun would be gone!
    Spent the day doing paint touch ups and reinstalling the rebuilt nacelle. The ring glued back on quite easily, I used 8 toothpicks to help stabilize it, but in hindsight 4 would have been enough. Did a bit of filling and sanding then started in with the paint. On with the silver and then a couple of passes with the paint gun with the pearl coat then back to the brush for the clear coat. Two clear coats on so far, it'll need one more though. I trimmed a bit of the upper nacelle out so I could slip the retract and ESC in without having to remove them from the airplane, thus saving me removing the panel that covers the wiring and trying to feed the ESC wire back through the fuse. Went extremely smooth, probably half to three quarters of an hour for the swap out. I did reinstall the motor before gluing the ring back on which is a heck of a lot easier to do. So, now the only thing missing is the gear doors which have decided to give up the ghost and break the little pins off, so she needs a new set, no biggie. This plane has been so inexpensive as regards replacement parts that I can't complain. Short of upgrading the motors, in the four years I've owned her, she's cost me a nacelle and a couple of sets of props.
    My favorite (favourite if you're in Canada!) airplanes are the Flightline 1600mm Spitfire and F7F. BTW, there will, at some time be a new Bearcat in the fleet as well, that plane is just too great to be without!!
    • MesRcPilot
      Hobby Squawk -Spitfire pilot
      • 163
      • City of Split ,Croatia ,EU
      Hello Grossman , thanks for the reply ... humor and joke must be an integral part of RC modeling .... because, nothing would make sense. We cannot take any stock production model for granted. Greetings from Croatia.
      Jos
      • tdstaf
        • Oct 2019
        I'm using the admiral receiver in the Tigercat and am having a hard time locating a good postion to mount it flat. I'm using the 4000 4 cell lipo's and they are in the way
          • 5401
          On the floor behind the battery area, other side of the bulkhead? Or under the turtle deck behind the end of the canopy piece?
            Welcome to Hobby Squawk, tdstaf! Evan D is right, those two places are the most common for mounting the receiver in our FlightLine 1.6m F7F Tigercat. I have mine mounted on the floor behind the battery.
            • mr.frankenjet
              Eat, sleep, FLY FLY FLY !
              • 448
              • Virginia, USA
              Loving my tigercat, here is the 2nd flight and already she feels dialed in
              rc flyin addict
              • theoldALFER
                Taildragger Pilot
                • Jun 2017
                • 163
                • Cape Coral, Florida
                Well, I finally got the Cat back together and ready for flight. She is made up of parts from my Tigercat number one, Tigercat number two, new parts from Motion RC, and who knows where else. So she is appropriately named “Bits ‘n Pieces.” Plus I have enough parts for a second one...:pop
                Can never have enough....
                • Gilatrout
                  RC Pilot Addict
                  • 806
                  • Albuquerque NM
                  I'm resurrecting mine now. So much hanger rash. I found that the Montana-cans Navy color is an excellent choice for refreshing the blue.
                  I originally planned on a simple refit, but I love this plane so much.
                  • coyote137
                    • 14
                    Finished re-paint and new graphics on Tigercat, Working on new cockpit interior and pilot
                      Very striking!!! Love it and your puppy too!! Jerry
                        coyote137 Welcome to the Squawk!!! Glad you are onboard!!! Happy Easter!
                        • easyjack
                          • Aug 2018
                          • 8
                          • Winter Haven Fl.
                          Has any one put the FMS front landing gear in place of the stock gear? All I want to do is bolt on the landing gear with out using FMS servo and landing gear assembly. Thank you Jack
                            easyjack Sorry Jack, hate to disappoint ya but it won't fit which is the reason no one has written about doing so
                            Welcome to the Squawk also
                            Here's proof of the above claim:
                            Since I had the FL before losing it to the infamous incinerator and replaced it with the FMS,
                            here is the stock FL nose strut held in front of the FMS strut with top of strut at the trunnion.
                            The FMS is a little over an inch longer at the axles
                            Click image for larger version  Name:	IMG_1393.JPG Views:	0 Size:	107.1 KB ID:	249408
                            Best regards,
                            • easyjack
                              • Aug 2018
                              • 8
                              • Winter Haven Fl.
                              Thank you "WC".. I knew it was too good to be true. However I do like the wheels... I am sure the axles will need to be changed. Thank you again Jack
                                easyjack Hello Jack, If you are looking to upgrade the nose gear to a oleo shock system that has a standoff scale look you may be interested in this mod I did over three years ago
                                • easyjack
                                  • Aug 2018
                                  • 8
                                  • Winter Haven Fl.
                                  Thank you again, I will be doing your alteration... Today, I am purchasing the kit and all the extra landing gear "stuff" for my grass field. Jack
                                  • theoldALFER
                                    Taildragger Pilot
                                    • Jun 2017
                                    • 163
                                    Seco Cat in the “fleet.” Click image for larger version
                                    • ntackC
                                      • May 2018
                                      • 2
                                      Do you have to take the servo apart to replace the nose wheel pin?
                                      • ntackC
                                        • May 2018
                                        • 2
                                        Yes you do!!!
                                        • redbarn
                                          RC Hack
                                          • 44
                                          • NE Oregon
ID:	261888Click image for larger version
