BTW, everyone who owns one of these needs to check out this video, this is exactly what I found and re CG'd it so that she was a bit nose heavy with the 5000. Made all the difference in the world. Now mine will fly with the 4500 all the way forward. Added 2.5 oz ( 10 x 7gm weight pads) of weight.
https://www.youtube.com/watch?v=-EgTgQZdeXs
I have mine set up at 95-97mm with the Admiral 4000 and it flies superb (no ballooning and still requires up trim to fly level). Originally used the 5000, however, I found it was a bit quicker and climbed better with the lighter 4000 and also have 2.5 oz weight in the nose. I also have 5 coats of spar urethane and the sound system along with 3 1/4 inch Hanger 9 wheels (couldn't quite get the Robarts to fit right) so it is a little heavier than stock, which is why I opted for the 4000mah instead. I still get 6-7 minutes of flight time so I'm satisfied with that. I absolutely love this plane, the favorite of all my warbirds. I'm currently flying on grass now and use up elevator during taxi, slowly increasing power to get it on the mains, then continue with a little up to keep the nose level and she lifts off beautifully on 1/2 flaps (same technique as in the video). Landing is a breeze with this plane, keep throttle at 25-30% on approach, then drop it to just below 25% about 10 feet above the ground and when I'm level about ankle height above the grass, slowly reduce power till the mains touch then keep a little up to prevent nose over as I shut her throttle down. Lately, all landings have been 2 pointers, rolling out well with no forward or side tipping-makes me look like I know what I'm doing (which is far from the truth).
This is just an absolute pleasure to fly and looks amazing in the air! :spit: Still working on my Corsair :corair1: to get all those issues worked out the same.
Jerry
to my detriment, so just wanted to know for sure. I'm the last person to take any advice from.
