My MRC care package arrived today, with my replacement props. I've rebonded the gear well back into the wing and have installed a balanced prop. If the rain holds off long enough tomorrow, I'll try to get her back in the air after work. This whole work thing really gets in the way sometimes... :-/
I understand your :Angry: As i post earlier the manufacturer had to put a piece of plactic between the 2 halves of the wing (upper and lower) and attach the gear with screws to it. Last week i was intend to inject with a needle
ultra thin foam safe CA under the plate. No i will put long nylon screws with glue to make it stronger ( i hope) I don't want to lose the gears on my maiden.
It's NOT an FMS, you know. :Silly: Very few (maybe 1) of my Freewing planes have issues with landing gear. However, ALL of my FMS planes have.Comment
I've been flying my FMS P-51B off our grass field many times with no gear problems yet. If the FL Spit is as strong as the Mustang it will be OK.Comment
You need to talk to Scamp73. Ive flown off his club field and the grass is evtremely THICK. He has had alot of flights off of his field with no trouble at all and believe me if there was a problem with the retacts that field would take them out. My field has thinner grass but is very rough and runs at a slant and i have missjudged the slop several times and almost flipped the plane and there still solid. Right now from what im starting to read im getting a strong since of paranoia. Any foam plane can have a chance for the retracts to pull out so thats just the way of foam. Ive even had failures with retracts on balsa and they were screwed in and maintained. Nobody lands perfect all the time either. Just like Ryan said give them a tug and if they stay solid fly. If you bounce more than you gease landings or are a beginner at foam planes then get more practice. Your going to be fixing landing gear in more ways than just pulling out Just a word of advice..Dewey lComment
Sorry TI you were the one that said tug on them. Sorry man didn't mean to put your words in someone else's mouth. You to Ryan sorry.Dewey lComment
radford
go with the tree house studios flat matte clear acrylic spray from hobby lobby.. i have used it and also the high gloss clear to great results and love the finish.Comment
Even though a lot of you are not having problems with the retracts pulling out, if you look at the photos that Aros and I posted, it is pretty dang obvious that the couple of lines of glue (actually looks like hot glue to me), that hold the gear box in the wing, is insubstantial.
I reglued my gear boxes back into the plane (Foam Tac) and made 5 take offs and landings after work today. The grass was a bit too high. One nose over (the approach and touch down were fine), and one set down a bit harder that I would've liked, but the gear held solidly in place. I love how easy the Spit is to make a great scale take off and climb out. And she's such a beautiful plane in the air.
WarbirderComment
Howdy Spitifre pilots. #1, Something I found with mine, it must have gotten hit in transit. The propeller collet adapter the spinner goes over. I had a small dent on the threads, so while I was placing the spinner over the threads. I noticed it was difficult to slide it over the tip. I got out my spectacles and found the photo on this thread. The tip was dented aluminum threads, so with a drammel tool. I was able to carefully repair the tip. #2 This is ONE "Awesome airplane. I spoke about this years ago, wishing they would make one. Well, here it is, they did a fantastic job as well. It's a beautiful thing!!!2 PhotosComment
Holy Cow Ace! That area you fly at is crowded with lights, dumpsters, tree's. I would have way too much going on in my brain to land like that. I'd say, you have some great skill if you had an open area. You could be dangerous. (in a good way) Roger that, good landing. Matt (Rock--n-Roll) Hero! ;)Comment
I have close to 30 flights on mine on grass and have had no issues at all with the gear or anything else for that matter.You need to talk to Scamp73. Ive flown off his club field and the grass is evtremely THICK. He has had alot of flights off of his field with no trouble at all and believe me if there was a problem with the retacts that field would take them out. My field has thinner grass but is very rough and runs at a slant and i have missjudged the slop several times and almost flipped the plane and there still solid. Right now from what im starting to read im getting a strong since of paranoia. Any foam plane can have a chance for the retracts to pull out so thats just the way of foam. Ive even had failures with retracts on balsa and they were screwed in and maintained. Nobody lands perfect all the time either. Just like Ryan said give them a tug and if they stay solid fly. If you bounce more than you gease landings or are a beginner at foam planes then get more practice. Your going to be fixing landing gear in more ways than just pulling out Just a word of advice..Comment
What is the flying weight of this plane. MRC shows 100.5 oz as the flying weight using, I assume, the 22.5 oz Admiral 4500 6S battery. My battery weighs 26 oz and with the plane the total is 126 oz. How did I get a pound and a half heavier by adding 4 oz?Comment
