Adding the plywood under the front retract seems to have helped. It rotated and lifted off easier today.
AND, three successful bombing runs! Munitions were armed (with flour) and impacted on target on the runway.
I'm glad it worked as well as it did and the guys got a kick out of it.Comment
Good bomb videos are actually rare. Many times( I mean many) I will ask my friends or someone nearby to video the drop. Guess what? They flub the perfect hit on target. Either film the drop or film the target. Better yet, film both with two cameras. I want to place a camera on the target one of these days. I never get around to it.Don't just fly--WREAK HAVOC!!!Comment
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
So I received my sonictronic spring hinges to do my landing gear door mod. I am a little worried the Dynam retracts won't be able to overcome the spring tension in the hinge. Those little springs are stiff.
I also got my bomb bay doors to close without making the servo buzz by lengthening the control rod on one side. Must have been a geometry error on the servo placement on one side. Now they work perfect. The bombs still come out of the plane much more scattered then with my B-17. I think the bomb bay is quite narrow on the B-26 and the bombs must bump into each other on exit. Or the plane is flying faster then my B-17 and the bomb tails have more bite. Any angle off and they go further in that direction before stabilizing.2 PhotosDon't just fly--WREAK HAVOC!!!Comment
The Sonictronic spring hinges for the gear doors worked, but they really put a load on the retracts. I am not going to use them. I even tried lightening the spring tension by uncoiling one wrap off the hinge. No luck. Instead I will use an FMS 3 second sequencer from the old 1450mm P-51 and servos. I bench tested and it works. I buried the Dymond 2.2 gram servo half way into the wall.Don't just fly--WREAK HAVOC!!!Comment
Here is a shaky hand video of my gear door in action.Custom made fiberglass front gear door for Dynam B-26 Marauder and sequencer.Don't just fly--WREAK HAVOC!!!Comment
Are you sure about your CG(60-55mm)? Did you do your mods before first flight? Calibrate your escs? My blackwidow escs were way off before calibration. My b26 flies great. Half flaps takeoff,full on landing. Mine first batch,bone stock,no mods,weights in the tail. I did reglue several things....,wingmounts,nacells,wing panels, weights. I am rarely below 3/4 throttle in level flight. 8min flights with china hobbyline 4s 4000 40c with another minute + in reserve. Very curious as to what is wrong with yours.Still flying P.15, avanti(#2), mig 21, yak 130 70mm(#2), f35, f9f panther, a10 64mm, F8 crusader/ PA ultimate amr /HK skipper, durafly dh vampire, p 51,spit mk24, corsair, flybeam/ BH f86 50mm, deltawing 50mm/ HH su 26 mm,umx pitts,umx sbach, blade nano cp s,blade 450x, inductrix 200, inductrix pro, umx yak 54,umx f27 fpv/ electrifly 4s L39/ flyzone beaver/ volantix asw 28, /dynam B26
RIP.. roc hobby waco,strega #2(you will be missed), Fw 90mm eurofighter.Comment
"I am rarely below 3/4 throttle in level flight" I think this is very important. This plane could use a little more power. In banked turns, you need to be at or near max throttle. Flying at too little power (too little airspeed) and the plane will wallow around like a hippo. Not enough power in a turn and it will drop like a stone. And this is assuming the ESCs are calibrated and battery is good.Are you sure about your CG(60-55mm)? Did you do your mods before first flight? Calibrate your escs? My blackwidow escs were way off before calibration. My b26 flies great. Half flaps takeoff,full on landing. Mine first batch,bone stock,no mods,weights in the tail. I did reglue several things....,wingmounts,nacells,wing panels, weights. I am rarely below 3/4 throttle in level flight. 8min flights with china hobbyline 4s 4000 40c with another minute + in reserve. Very curious as to what is wrong with yours.Comment
I am using a smaller battery (4S 3600). Less weight = always better... and I still get long flight times. I rarely use full throttle. I don't think the 4000 is necessary.
Good tips from CFIT Rob.... I'll add, its a good idea to use "takeoff flaps" whenever you are flying slow, especially in turns. For example, like when you reduce power getting ready to land... half flaps on base and then on the turn to final. then full flaps for landing. The flaps help avoid stalls, especially during turns at lower speed.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
I do, with a 4000 pack and I get 7 mins flight time. And I do get a from level loop so I feel like mine does have enough power. And i do fly at half throttle 90% of the time. Maybe it's the thicker air out here, but I haven't seen much of the issues like that after I replaced the fuselage and entire wing, as well as the engine nacelles in the original plane, really dang near the entire airframe. Anyway since I replaced it all, it's been greatComment
