Fit the first cooler in the port side cutout... Just a dry/temp fit to see how it looks. This is before I do any work to the coolers (filler primer, wet or dry sand, repeat until smooth finish). Overall I am really happy with the final molds and when it's all done and they are properly recessed I think it will definitely look the part showcasing a scale-like depth to the coolers that most model Corsairs don't have.
downwindleg/Aros ESM 50cc F4U Corsair Build (Electric Conversion)
Thanks! I cut a little too much on the starboard side so I will need to fill the gap...Any suggestions? Bondo? Fiberglass cloth? Not used to working with fiberglass for repairs...My YouTube RC videos:
Thanks Tom, that sounds like a great idea! It's probably a bit overkill how much attention and detail will be going into the coolers but I think they are such a cool feature of the Corsair, I want to do them justice.My YouTube RC videos:
:pop:Cool::Confused::Angry::Silly::)
Kinda says it all doesn't it Aros??
Grossman56Team Gross!Comment
Tod..........just use some Beacon Foam-Tac Foam Filler with a final thin coat of Foam Finish ;)Warbird Charlie
Like minds! I collect popsicle sticks for my epoxy and I was thinking the other day that they would be a great solution to build up the cooler pockets.My YouTube RC videos:
Knocked over with a nasty cold but I wanted to post this...I bought some filler primer over the weekend and have about 10 coats on the coolers. The primer is doing a nice job of filling the grooves. A lot of sanding and priming. I finally got to the point where I felt comfortable setting them in their homes. I have to clean up the edges with putty, primer and sanding but once that's done I think the end result will be worth the investment.
Man i hate You. No i didnt mean it. Its looking beautiful. As you already know the Corsairs are my first love and your living my dream Man:(.:)Dewey lComment
Picked up some bondo...Sanded around the edges until the chips were smoothed out, then added the bondo to fill the edges. Once dry I will sand smooth, probably hit it with another round of bondo if needed, sand, then filler prime. Should be good to go by then.
3 PhotosMy YouTube RC videos:
Thanks! I hope so! Unfortunately the bondo hasn't cured so I think I didn't have the mix perfectly 1:1 so I will have to do it over. Ah well. :Confused:My YouTube RC videos:
