Originally posted by Dual Prop Dave
View Post
Landing the bearcat on grass has beaten the gear and wings up. Have ripped both out of the wings,twice, foam tac to the rescue, This plane needs to be landed on pavement, take off on grass if you get her rolling a little bit will work without a nose over. Paint match at home depot. Not meant for even short grass strips. options would be larger tires which means you fly with the gear down all the time! I have the 1600 mm spitfire and take off and landings on my grass strip are not an issue s the tires are a lot larger and shock absorbing struts
It seems that there has been an addition to the description of the bearcat. There is now a line called recommended environment where it says not for grass unless it is smooth and short or paved , After putting on new wings the flight today was upon landing at my grass field it snagged the left wheel and ripped out the landing gear. I am keeping foam tac in business. I will get rid of the plane as it is not suited to fly off grass unless it is a golf course putting green. Needs larger wheels that wont snag or switch to 2 bladed prop, fly with the gear up and land it on its belly!
I'd recommend that if the gear pops out, epoxy it back into place. With the length of the strut, the amount of torque applied to the retract/ wing joint in an anything but perfect landing is enough to weaken, if not pop it out. So, since it's out, use Epoxy to nail it back together again.
Grossman56Team Gross!
Glues don't stay stuck to EPO
One place Dynam got it right is they tend to sandwich foam between a "plate" and the retract, making it so you have to rip out a hunk of foam. rather than just pop a glue joint.
You could set up similar with a thin aluminum plate on the upper surface of the wing and carrying screws from the retract mounting lugs through the aluminum... but that leads to some cosmetic issues.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Originally posted by Fallguy44 View PostAre the older versions, say more than a year old different from the latest versions? Or has everything remained the same? Thanks!Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
The manual calls for the push rods to go in control horn #1 which is the outer most hole. The hole is also larger than holes 2 and 3 as seen in the picture. Using #1 hole, there is a decent amount of play at the clevis attachment to the point that I can move the aileron up and down slightly which I can imagine isn't great for the flying. Anyone else run into this? Should I go hole #2 instead? All the control horns are this way.
Originally posted by crxmanpat View PostI didn't have that on mine, but since there's a little slop using the first hole, just go with the second. You will still have plenty of throw. But make sure you use the second hole on both ailerons so you won't have differential throws.
Originally posted by fhhuber View PostGlues don't stay stuck to EPO
Dynam plates are just as bad, I have to glue the plates in just like the pocket style, think surface area when ever you glue thing.
Ron.AMA 424553
Had a close call today with the Bearcat. I was pulling up from a low pass, and noticed a flash of something seemingly falling off the aircraft. I did a low pass and didn’t see anything, and finish out my flight. When I taxied back in after landing, I was surprised to find my right flap linkage dragging across the ground! The control horn pulled out, and was dangling beneath the aircraft for most of the flight. Glad it was windy, so I never used any flaps today!
- Likes 2
How to stiffen the top of the rudder? Flips over on landing. Right now using tape. Be nice if the whole tali assembly was replaceable instead of buy a whole fuse.
BTW, found a solution on landing on grass, use packing tape on the top and bottom of the wing around the retract, to stop the retract from pulling out and taking part of the wing with it
Originally posted by Mikeinlutz View PostHow to stiffen the top of the rudder? Flips over on landing. Right now using tape. Be nice if the whole tali assembly was replaceable instead of buy a whole fuse.
Be sure you won't drill through any wires or hit the pushrods, etc... and you can often run the tube from top of the fin to the bottom of the fuselage.
Standard procedure for stiffening a foam tail surface. Slot in or drill a passage for a CF tube. You can substitute bamboo cooking skewer for the CF, but its heavier.
Modifying most EPO models for higher speed, you need to add the stiffness and strength to the tail surfaces. So, we've learned to do it.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Has everyone seen the post on MRC site that says to fly this plane with nothing under 4000mah otherwise it’s tail heavy? That’s a big lipo for such a small bird, but I’ve had no end of tail heavy issues with mine and I’ve only flown it 2 times. The retracts on this plane are a joke-I’ve had 8 PAIRS of retracts in this plane to find 2 that don’t die after being operated more than 2 times! I had actually decided to make it a belly lander and went and got the power upgrade and 2 blade prop for it-am yet to try it out. I just wondered if any of you have flown it with a 4000mah 4s in (and if y’all have also had retract unit issues with it)
