  • Wow, Sie sind immer noch hier und SUCHEN. Wo sind die Daten, Dr. Okon??????So geht es nicht weiter. Du lenkst Hobbyisten von den Fakten ab. Bitte, Mann, schließ deine datenlose Post in deinen Schrank.
    Click image for larger version  Name:	20250823_151237.png Views:	0 Size:	666.5 KB ID:	431506
    Hier noch einmal für Ihre anonymen Freunde: ein gut sichtbares Foto der Deltas auf der Rückseite einer Parallelhybridmaschine. Wo sind Ihre Fotos von der einzelnen Hybrid-Terminierung auf der Rückseite, Dr.? Sie sind jeden Tag hier und schauen sich meine an. Sie liegt nie im Schrank. Sie begleitet einen dämlichen Amerikaner überall hin.​
    • Do you not realize these photos sent to me is personally through email from Dr Sariful Islam at ABB in Raleigh NC where I'm at? It is the 24 slot 10 pole inrunner with and elaborate hybrid winding that surpasses all others of its type. even the one in Munich Germany.
      You trippin' brother.
      I have a direct line to them.​
      • The NC STATE D.E.E.C.S. Used a special winding as a migration from the 12N10P machine to a 24 slot 10 pole. It is based on 2 sets of wye to delta windings connected in series. This showed a 1.25% increase in average torque. It reduced torque ripple from 5.3% to 1.25%. It also reduced the THD. from 4.6% to 1.1%. The simultaneous reduction of super and sub harmonics increase the power factor of the machine by 7% and the core loss performance by 15 %.. Pretty significant improvement form the DL conventional winds done here as there power factor is .90 and this is.95 . This technique also applies to SRM's, and IM's. Attached Thumbnails
        Type (9) was Dr Gerling and Gurukuq's​ version.
        • Who will really tell them that the difference seen here in pm performance of a 24 slot 14 pole hybrid machine is not worthy of a speed plane motor that failed from demagnetization.
          It also incorporates a stagger of 7 slots between the winding sets. The magnet loss was reduced to 60 watts in the hybrid versus 1148 watts in the conventional wye..
          The machine makes more torque and throughput power. running so much cooler with much less electrical noise.
Name:	24N10P y-d winding arrangement with 5 slot shift. (1).png
            Apparently you cannot wind it.
            • Click image for larger version  Name:	a1619387-26-3 layer winding.png Views:	0 Size:	17.6 KB ID:	431539
              3 layers 12N10P .
              You have never wound it so how do you know what any of it does? I hope its clear now to everyone including your friends in Germany that no you Dr Okon do not have any relevant data.on the subject matter And that you are here looking at mine at 1:45 AM est. USA
              Facts!
              • Any interested reader can take his or her favorite calculator of choice and throw arbitrary motor constants at it to see what and how that affects max efficiency. A mere 7/10th of an amp less of idle current makes a measurable difference in peak efficiency and it's broadness across the rpm ranges it runs. Turn back around and throw 7/10ths of a milliohm less of DC resistance and see what affect it has on the peak efficiency values .
                The no load current values are very important .
                • Click image for larger version  Name:	535436637_2025838588224746_1457916346214985916_n.jpg Views:	0 Size:	91.2 KB ID:	431550
                  Hi Boys
                  Look what i found, They are only asking 7 bands for it. Id like to check it out and make a cut with it to see if it will hold the number. 7000.00 is awfully cheap Its a HAAS machine which would be very eazy for me to use. I was trained on a Haas in mastercam.
                  Click image for larger version  Name:	Chess board.jpg Views:	5 Size:	74.0 KB ID:	431551
                  • Click image for larger version  Name:	20221221_101225.jpg Views:	0 Size:	124.4 KB ID:	431557 I think alpha iron may not be able to be processed with an edm and it is non conductive with a fully ferritic matrix. I think a core will have to but cut with a water jet or milled with coolant. It is annealed so it is easier to machine that the typical ductile iron. The "leaders" do not know anything about it as a solid core. It has very low coercivity an it is NON conductive.
                    Click image for larger version  Name:	image002.jpg Views:	0 Size:	22.2 KB ID:	431555
                    You could process a double YASA from it quite effectively. Higher power density also means you could degrade the magnetic material used and get the same performance as a conventional machine for much less coin.
                    You could use ferrite magnets versus neos. as an example.
                    TTYL
                    Hubert
                    • Dies führt mich zu einer weiteren Frage an die acht Piloten in Deutschland bezüglich ihres Motortuners. Wenn sie die Folgen erhöhter PM-Temperaturen sehen, die die Neos PM-Spezifikation überschreiten, ist ein Rotor mit Samarium-Kobaltmagneten aus konstruktiver Sicht sinnvoller als ein neuer CoFe-Kern. Werden die Magnete durch übermäßige Hitze geschwächt, bedeutet die hohe Permeabilität des Kerns nichts. Wo kommt also der Kobaltrotor ins Spiel? Die Lösung ist recht einfach. Sie haben etwas weniger Energie, daher müsste der Magnet dicker sein. Es gibt auch höhere Wicklungsisolierungen. Wenn er 200 °C sieht, benötigt er eine Drahtisolierung, die für mehr ausgelegt ist. All dies dient nur der Unterhaltung, denn wenn der Motor bei der Anwendung nicht überlastet wäre, würde er gar nicht erst höllisch heiß werden.
                      Wenn Sie einen Betrieb bei solch hohen Temperaturen planen, müssen Sie die Maschine entsprechend bauen.
                      Some attributes of samarium-cobalts are:
                      • Samarium–cobalt magnets are extremely resistant to demagnetization.
                      • These magnets have good temperature stability [(maximum use temperatures between 250 °C (523 K) and 550 °C (823 K)]; Curie temperatures from 700 °C (973 K) to 800 °C (1,070 K).
                      • They are expensive and subject to price fluctuations (cobalt is market price sensitive).
                      • Samarium–cobalt magnets have a strong resistance to corrosion and oxidation resistance, usually do not need to be coated and can be widely used in high temperature and poor working conditions. [4]
                      • They are brittle, and prone to cracking and chipping. Samarium–cobalt magnets have maximum energy products (BHmax) that range from 14 megagauss-oersteds (MG· Oe) to 33 MG· Oe, that is approx. 112 kJ/m3 to 264 kJ/m3; their theoretical limit is 34 MG· Oe, about 272 kJ/m3.
                      • Sintered samarium-cobalt magnets exhibit magnetic anisotropy, meaning they are typically magnetized along their easy axis, which is the preferred direction for stable magnetization. This is done by aligning the crystal structure of the material during the manufacturing process.
                      • Dieser kleine Audiosmith hat keine Ahnung. Turbo Petes Thread zeigt das. Er kriegt jeden Monat eine Auszeit wegen seines Geschwätzes … Dr. Okon ist sicher der Beste von euch, denn er ist der Einzige von euch, der schon mal einen Stator verpfändet hat. Komisch, wie er ihn plötzlich verteidigt.
                        Die Deutschen lesen hier offensichtlich mit
                        • Click image for larger version  Name:	image.png Views:	0 Size:	178.1 KB ID:	431568
                          Click image for larger version  Name:	image.png Views:	0 Size:	214.2 KB ID:	431569Click image for larger version  Name:	image.png Views:	0 Size:	66.1 KB ID:	431570 If its not applicable what is the far east discussion for?
                          • Und genau wie Herr Audiomith sagte, weiß er nichts davon und sollte es den Experten überlassen! Er weiß nicht einmal, wie Wechselrichter funktionieren. Oder wie man einen eigenen FOC-Antrieb in Betrieb nimmt. Er „kennt“ Messungen, kann aber seine direkten und Quadraturinduktionen nicht ableiten und sie einfach in die Motormodellparameter des Wechselrichters eingeben. Er kann also keine einfachen Anweisungen befolgen …
                              Weder Ralph noch Thomas haben eine Ahnung, wie hoch die D- und Q-Induktivitäten ihrer konventionellen Motoren mit konventioneller Wicklung sind. Von Hybriden haben sie definitiv keine Ahnung. Sie besitzen nicht einmal die nötigen Messgeräte. Nur ein weiterer Hobbyist, der über etwas schwadroniert, von dem er keine Ahnung hat. Deshalb ist der ganze Thread eine einzige große Frage …
                              • Thomas has absolutely no experience with any of this.
                                The editors have a lot to say without data.
                                In addition, the poster is full of crap. It is not difficult to find hybrid information on the WWW. It's everywhere. So you continue to make theater. You want Oscars.
                                Apparently he has read articles somewhere and knows that you are liars. He just wants to see what you have to say. Obviously he doesn't believe you, otherwise he wouldn't dare to find out more on his own.
                                Better offer the wrapping option to your pilots in front of me. I have diapering experience at the World Championships.
                                Mein Segen für den Wickeltechniker wurde direkt von Dr. Gerling und Dr. Islam erteilt. Beide kennen meine Außenrotoren. Die 12N10P-Rechte wurden direkt von den Afrikanern erworben.
                                • Click image for larger version  Name:	2d4a95ed7bb6dde0a19b6f47eb2f0fcb5797ca5f.gif Views:	0 Size:	5.1 KB ID:	431579
                                  Hi Ralph,
                                  it is of great importance if you and your friend there make declarations that you learn the mathematics involved and purchase one and then learn how to use it. Its critical to your conjectured editorials. . To talk about the "L" you have to first know what it is....However I'm happy you are starting to read on load reactors and their value in the circuit after learning about it here. Way to spread the good news from the USA.
                                  Aber haben Sie den Teil mitbekommen, in dem steht, dass eine Hybridmaschine keinen Neutralpunkt hat?
                                  thanx
                                  Hubert
                                  • Es ist eine Tatsache, dass der Zugriff auf alle Informationen, die ich Ihnen freundlicherweise zu Ihren Bildungszwecken zur Verfügung stelle, für den reinen Hobbyisten Geld kosten kann, da er möglicherweise nicht über bestimmte Berechtigungen verfügt, um alle Arbeiten anzuzeigen. Nur weil ich einen Link poste, heißt das nicht, dass jeder ihn sehen kann. Ohne zu bezahlen oder direkte Verbindungen zu den Redakteuren zu haben.
                                    Es ist wahrscheinlich keine gute Idee, in deutschen sozialen Medien zu behaupten, es funktioniere nicht, und dann zu versuchen, eine persönliche Verbindung zu den Redakteuren aufzubauen, damit diese Ihnen Fotos und Daten aus der Forschung schicken. Würden Sie das tun, wenn jemand online Ihre industrieerprobte Arbeit herunterspielt? Sie schaffen sich ein Problem, wenn Sie so etwas tun, um überhaupt Zugang zu erhalten. Die Experten können Sie nicht ernst nehmen, wenn Sie einen Haufen Unsinn online posten, ohne auch nur ein Fünkchen Daten.
                                    The IEEE
                                    Wenn sie darum bitten, schicke ich ihnen Geld und vermittle ihnen stets höchste Grüße und Respekt.
                                    Christian hat ebenfalls vollen Zugriff und kann euch, wenn er möchte, ausführlichere Informationen geben. Es sieht so aus, als hätte er die Gespräche mit euch aufgegeben und verbringt seine Zeit lieber im EV-Forum. Er weiß, dass alles funktioniert, er ist nur sauer auf mich. Macht euch keine Sorgen. Er wird bald darüber hinwegkommen, da er einem guten Gespräch über Elektromotoren nicht aus dem Weg gehen kann. Gebt ihm Zeit, und er wird euch beim nächsten Streit den F3A vor die Füße werfen, weil ihr das tun werdet ... haha!
                                    • I also do not care who winds it. If you wind a single and dual layer machine with the same exact amount or turns and gauge wire the dc resistance is the same but the self and mutual inductance is not at all the same. The Kv will be lower in the single layer when you run it with your speed control...so the torque constant is indeed higher empirically with the single layer. The q and d axis inductances are indeed also not the same between the 2 machines if you measure it therefore mathematically the dual layer PURE WINDING on the iron cannot not make more torque than the single layer winding or LRK. The slotting effect on the single layer external rotor makes it heat up the hobby motor rotor magnets faster so it may lose sync sooner than the dual layer without slot protection because the magnets lose adequate field to stay in sync. In a dual layer it is just like a short coiled distributed wind. The extra layer dampens unwanted harmonics. but it comes at the cost of torque because the winding factor is lower.. Some of the copper is used to dampen harmonics now not generate torque. The single layer will also run with less torque ripple on a six step drive. I do not care what Thomas has to say the oscilloscope will show you the dual layer generates a more sinusoidal BEMF than a single layer. The hybrid wind wouldn't care which way you go because it is a hybrid like some inverters are hybrid. The hybrid is a single layer delta with filters that clean the harmonic noise that raises pm loss. It is a pure winding that does it better than a dual layer wye machine with 3% higher winding factors just like the single layer has.
                                      *SL's winds have more trapezoidal BEMF that DL's.
                                      *SL's winds have more self inductance than DL's.
                                      * SL's showed less cogging torque when driven by zero cross algorithms(BLDC) than DL's which would be lower if driven in BLAC.
                                      *Static and output torque output is higher with SL's
                                      *SL's have higher torque density.
                                      IEEE TRANSACTIONS ON ENERGY CONVERSION,VOL.21,NO.1,MARCH 200695
                                      Comparison of PM Brushless Motors,Having Either All Teeth or AlternateTeeth Wound
                                      DahamanIshak,Z.Q.Zhu,SeniorMember,IEEE,and David Howe​
                                      Goodnight here every body
                                      I'm going to work on my mono plane and other fun projects.
                                      Hubert
                                      • Der arme Michael kann nur um 5050er betteln und Bilder davon posten, aber er schafft es nicht, ein Foto von einem Strafzettel wegen Geschwindigkeitsüberschreitung von 600 km/h zu machen. Er verschwendet einfach sein kleines Geld. Er ist hoffnungslos von nichts besessen. Er kann 100 davon kaufen, es wird nie passieren. Ralph....
                                        From his well managed photos it appears he is more enamored with their appearance than performance There is never a world record speed report with his friendly advertisements for you motor.
                                        • Er hängt ständig Briefbeschwerer auf. Sagen Sie ihm, er soll für all das, was er für Schwarz und Gold ausgibt, die Durchschnittsgeschwindigkeit angeben. Ich sehe seine Flugzeuge nirgends.
                                          Sieht aus, als hätte der Typ stattdessen einen Turnigy-Inrunner gewählt. Aber ich sehe, wie Sie als Agenten ihn umringen und versuchen, ihn dazu zu bringen, sich Crocoworld anzuschließen.
                                          Erpressung!!!
                                          wo ist seine Turbine, die du auf RCU gesperrt hast
                                          ​Id like to share here a few things about electric motors and inverters that I have been exposed to over the years. Hope there will be interest here (filedata/fetch?filedataid=91738) ​ Thank you. THE REAL 1BOHO.
