LB... I like your F-4 livery from Kansas... Are you doing your bird like that?? If so, maybe we can do them at the same time and I can see if I can out-weather you... Rule #1 is you can only use your airbrush if you are over the legal limit of BAL to drive... LOL So, Makers Mark and the Paasche in hand, and three two one go!!!!! :Cool::Drinks::Drinks::wacky
H, I am doing the CAG VF-111 on this one, so unusually shipshape, as it were. Seems stupid now that the 'Gray Version' is available, but I started it and I will finish it. Tamms wants me to do my "Fighting Jayhawks" version, too. So I will need to do another. It's a tough job but someone has to do it. 1:1, ours was so dirty, it looked almost solid greasy green most of the time. No offense to the ground crew, just the way things were. So 'weathering' would be 'big fun' and you're on. Which version are you doing? KANG F-4 Euro 1 camo is pretty cool. Best, LBOriginally posted by Hardway View PostLB... I like your F-4 livery from Kansas... Are you doing your bird like that?? If so, maybe we can do them at the same time and I can see if I can out-weather you... Rule #1 is you can only use your airbrush if you are over the legal limit of BAL to drive... LOL So, Makers Mark and the Paasche in hand, and three two one go!!!!! :Cool::Drinks::Drinks::wacky"I am having an extraordinary ordinary life."~Lucky B*st*rd~
H, I won't be jumping on a 2nd F-4 soon. Gotta B-17 in the box and a Corsair coming, but I can assist with the livery, though there are good pics out there and I might have a few somewhere. CRXMANPAT's RC Club President did a Jayhawks F-4, so there could be good intel already where it needs to be. ;) Best, LBOriginally posted by Hardway View PostWe need to talk more, but I will be your wingman anytime!! I just need to ask Callie!!! LOL
ps: You won't need Callie's permission to be my wingman. LOL Your quals are outstanding, I checked. :Not-Talking:LOL"I am having an extraordinary ordinary life."~Lucky B*st*rd~
crxmanpat, Sorry, thought I had seen photos some time back last summer of your F-4 and his and commented about the Jayhawk livery and any affiliation with McConnell AFB. My apologies, sir. I will do better research in the future. Respectfully, LBOriginally posted by crxmanpat View PostElbee, you know Gary? I've never seen him with a Jayhawks F-4. Must have been a while ago. Saw him this morning, got a Byron fan adapter from him for my F-16 project."I am having an extraordinary ordinary life."~Lucky B*st*rd~
crxmanpat, LOL No doubt. It comes with the territory these days. Best, LBOriginally posted by crxmanpat View PostNo worries LB. Was wondering how you knew Gary. You may have been remembering someone else's post."I am having an extraordinary ordinary life."~Lucky B*st*rd~
I have the cockpit set and it's very nice indeed as a starting point, but it REALLY could do with a instruction sheet of some kind.
I am also a plastic kit modeller, but I can't understand where some of the parts go.
there are four parts that look like bomb sway braces but is that really what they are.
Also, please can anyone out there tell me if there should be a instrument dials backing sheet to go with it ?
A plastic modelling tip that I will pass onto you all.
Its to use the Dull Gold foil that you find around the tops of wine bottles, is just about the perfect colour match for ejector seat straps etc, as used on the seats in the Phantom.
Also because it's foil, it will readily form to the shapes of both the seat and over the pilots.
Another tip is to go to a drapes shop where they sell buttons and other sowing stuff, and look for a sparkling clear cristal type spangled type thing, and you can trim the front of the missiles and then stick the crystals on the front, and it looks like the missiles heat seeker head.
Happy new year to you all from the U.K.
Gordon Fraser.
Not exactly on topic, but since plastic parts are being discussed, I am offering this tip for the F-4's plastic main gear doors...
A non-perfect landing (wing low) resulted in the right main gear door contacting the ground and breaking. Here's a <flight proven> tip to prevent this from happening again. I glued about a 1/2 inch wide, very thin (est. 1/64 in thick) carbon sheet to the inside of the gear doors' bottom edge and painted it to match. To attach the carbon sheet to the gear doors, I used the tacky foam glue (that comes with the F-4) for a flexible bond. Clamping for several hours was required to ensure the carbon sheet formed to the door shape and didn't detach when the clamp was removed. This is an "invisible" fix that, so far, has prevented any more main gear door breakage. I got the very thin carbon sheet off another crashed model's main spar (plywood + carbon laminate)...worked great. Spare main gear doors are available from MRC, but this tip might save you the hassle.
- Likes 3
Gordon, Happy New Year to you, too. As for the F-4 Cockpit parts, if you're referring to the 1 part below lower right, I had a similar reaction and have no answer. You have 4, I only have 1. The OEM printed instruments do not match the cockpit kit dial placement, though the 3DPUP parts are close enough to actual to use a good picture reduced to roughly 35X28mm size. That's how I resolved it. I have attached a pic of the panel I used, but it is truly a compromise as the 3DPUP parts are representative at best. If you want that instrument panel as a picture file or any other cockpit docs, let me know and I'll send it by PM. Best regards, LBOriginally posted by Gordon View PostI have the cockpit set and it's very nice indeed as a starting point, but it REALLY could do with a instruction sheet of some kind.
I am also a plastic kit modeller, but I can't understand where some of the parts go.There are four parts that look like bomb sway braces but is that really what they are.Also, please can anyone out there tell me if there should be a instrument dials backing sheet to go with it ? Happy new year to you all from the U.K.Gordon Fraser.
Thank you so much. That panel photo is extremely helpful.
I agree that the cockpit kit is a real upgrade but not very scale, and I understand what Motion has tried to do by producing this kit.
I am going to use them as a starting point.
that's the part that I can't identify. I have four of them in my kit. Maybe Alpha can help us here.
G, I am sure you have access to the myriad Internet photos and specs. That particular photo just reduced better than even my manual schematics. If you don't find it let me know and I'll send you a PDF or zip-file of that photo. Best, LBOriginally posted by Gordon View PostThank you so much. That panel photo is extremely helpful.
that's the part that I can't identify. I have four of them in my kit. Maybe Alpha can help us here."I am having an extraordinary ordinary life."~Lucky B*st*rd~
Oh!!! YES!!Originally posted by Elbee View PostEA6BG, Looks truly amazing. Really like the Marine livery. Bravo Zulu, sir. Best, LBCurrent Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,
I agree that's nice looking. Now I have a question for ya Mr 6B. I would think with a handle like, "EA-6B Geek" you would be hammering MRC to make a Prowler. Did you just give up and accept all we're going to get is an Intruder? Ya know if they could get some scale Prowler speed breaks to actually work. People would buy a model of a Prowler for that alone.Originally posted by EA-6B Geek View Post
Best Regards
Woody
Prowler had super cool speed breaks. W
