    • 8218
    Originally posted by PhantomNut
    I already have the graphics! :Cool:
    :Cool::Cool:
      • 4838
      Hey all, Has anyone come up with a way to paint 'inside' the intakes? I am trying to avoid a big mess and any 'disassembly' of the glued parts to paint white in there. Might be unavoidable. Help!:Scared:Best, LB
      • Torkrollin
        Lower
        • Mar 2018
        • 37
        • Meridian, MS
        I used plastic grocery bags. Stuff way back, and used go get um hook to get them out.
        Meridian Aeromodelers
          • 4838
          TR, did you use 'rattle can' then? I was thinking 1" Foam Brush with a broom handle attached. LOLBest, LB
          • Lcacing
            • Dec 2017
            • 155
            My F4 is almost done, added some weathering and Callie graphics. I painted the vertical stab white to avoid any grey showing trough. I’m trying to figure out how to tackle the servo side of the vertical stab, since the decal is one piece it’s hard to line up and make the correct cut for the servo arm. Maybe I’ll cut the decal in to to make it easier ????.
              • 4838
              Originally posted by Lcacing
              My F4 is almost done, added some weathering and Callie graphics. Since the decal is one piece it’s hard to line up and make the correct cut for the servo arm. Maybe I’ll cut the decal in two to make it easier ????.
              Lcacing, I had a similar issue and cut-out the white portion first as I had sprayed Insignia White over my primer. I figured this would be easier in the long run rather than trying to put down a large decal. I then cut off the 3 sun-rays that would lay over the rudder servo and the control horn (if Required). I matched the "sun" with the other 3 sun rays attached to the opposite side and using a line drawn where the vertical meets the fuselage (slip fitted the vertical to that part, drew a line) as a horizontal reference measuring back from forward attach point.to the 'sun'. I then applied the sun rays to match the sun cut point and the opposite side sun rays. Not a fun task but worth the extra bit of care required. Hope this helps. Best, LB
              • Crucianpilot
                • 9
                What spray paint did you use?
                  • 4838
                  CP, I just used rattle can Testors. Not my favorite, but I will matte coat the entire airframe when completed. Don't think it matters, just wanted a gloss finish to apply the markings. Best, LB
                  • Torkrollin
                    Lower
                    • Mar 2018
                    • 37
                    • Meridian, MS
                    I've used rattle can, but not good results. Airbrush water based paint worked well for me. Foam brush may work too.
                      I've used Testors/Model Masters rattle cans with great success on many of my models. And I typically finish them off with a spray of Testors Dullcote which helps seal in the decals and knocks off any shine. I've also used Rustoleum 2X and gotten good results.
                        • 5398
                        I've had good results with Testors Model Masters too. And covered with Polycrilic…
                          Yep, I've done the Minwax Polycrylic gloss treatment as well after painting.
                          • Torkrollin
                            Lower
                            • Mar 2018
                            • 37
                            • Meridian, MS
                            Sorry guys I should have specified, I was just referring to inside the intakes.
                            • poochies
                              • Dec 2014
                              • 22
                              Can anyone with the grey version see if there’s supposed to be the red sections that go between the white rays on vertical stab , I have the white rays and the bottom red half circle just find it strange they didn’t include all
                              the rays , especially since the red half circle is there .. thanks ! I was going to paint it all red then add the white rays .. but thinking the red will be too dark with white decal over it ...
                              • Gordon
                                • Dec 2018
                                • 39
                                • Gloucestershire, United Kingdom.
                                After much thought and reviewing of various colour schemes, I have decided that as the British Phantoms are very different from the Freewing Phantom, I have decided to do a US Marines Phantom from the VMFA-333 Shamrocks.
                                • Woodcock
                                  Old Returning Pilot
                                  • Apr 2018
                                  • 830
                                  • SoCal
                                  Nice choice, I love those shamrocks.
                                  Woody
                                    • 4838
                                    G, I noticed the same and thought the mods might be beyond my patience. I still believe RAF Phantoms are outstanding, though an F-4 VMFA-333 "Irish Marine" Fighter Pilot? LOL Gordon, you are the Man! Guinness for everyone on me. Best, LB
                                      And a shot of Jameson for giggles.... :=)
                                      • PhantomNut
                                        • Sep 2018
                                        • 95
                                        • San Diego,CA
                                        Have any of you guys that have painted over freewing models had any luck shooting Tamiya spray paint over the factory paint without any damage?
                                        • EA-6B Geek
                                          EW Misfit
                                          • 485
                                          • South Central Ohio
                                          We called this squadron "Trip Trey" when I was in the Marines. Great choice G!!
