  • e4dragongunner
    Living the dream!
    • 876
    • Arlington Heights Il.
    Welcome Tom.... They may be. However in place of a screen shot of the codes, I usually take a stab or a wing in to get it matched at the store ! :-)
    I hope this helps.
    • e4dragongunner
      Living the dream!
      • 876
      Originally posted by Stevonoles
      Is anyone using the Admiral 6000 in their F4? If so, can you post a pic to show where you are setting the battery? Been flying it with the 5000 and it flys perfectly. Just want a little more flight time.
      Hey brother Welcome..... So I lost my 1st F-4 as I Lost orientation on flight 2 . My second is 6s using a JP fan. Have one flight using a 6000 Admiral. Balanced ever so slightly nose down ... and I mean ever so.... at 190 mm.. ON the maiden I needed a ton of up elevator trim. I plan to go to 195mm for the next flights. Will keep you posted. And Welcome Again!
        • 4812
        Stevo, Welcome to the "Squawk" and the F-4 Forum. Best, LB
        • slamdance64
          • 70
          • Ottawa, Ontario, Canada
          Originally posted by Elbee
          Yeppers, LB...ad nausium...The "Make Shop" is working; however, the "Paint Shop" is on vacation. Best, LB
          Hey Elbee,
          where did you get the Daisy cutters for the 500lb's? I have not seen them before on Thingiverse. Looking great!
          • slamdance64
            • 70
            I have been flying all of my flights with 8S Admiral 6000mah packs. I have mine roughly in line with the intakes. I have the CG marked at 180mm and just moved the packs around until it balanced. If you watch RCinformer's video of his 8s flight, you will see.
            Cheers
            • Woodcock
              Old Returning Pilot
              • Apr 2018
              • 830
              • SoCal
              I didn't think it was dumb mate. Welcome to HS. Try not to let that sour ya.
              Best Regards
              Woody
                • 4812
                Originally posted by slamdance64
                Hey Elbee, where did you get the Daisy cutters for the 500lb's? I have not seen them before on Thingiverse. Looking great!
                SD64, There wasn't a mod for the MK82, so I made 'em myself. I 'Z' cut the tip of the MK 82 and saved it as an STL file, printed the remaining portion of the Mk82, then modded the tip STL in CAD for a 'new' printed tip which included the longer Detonator. Easy Breezy, Lemon Squeezie. Best, LB
                • spook
                  • Jun 2019
                  • 15
                  • Germany
                  Hi,
                  is there anybody who did the rcgeek F4 E nose conversion and has some pictures how to modify the gear doors?
                  Thanks!
                    Originally posted by spook
                    Hi,
                    Thanks!
                    Hello spook and welcome to HobbySquawk. I did the Tom Mansel F-4E nose mod and think it should be quite similar.
                    Click image for larger version  Name:	IMG_20190124_195825.jpg Views:	0 Size:	312.5 KB ID:	206023
                    • Stevonoles
                      • Jul 2019
                      • 13
                      • Ormond Beach
                      Thank you for the advice. I do have my CG marked for the 5000. I will try the 6000 and see how it goes.
                      • spook
                        • Jun 2019
                        • 15
                        • Germany
                        Hi, thanks for the pics. Great mod you did! Where can I find the 3D File or buy it? Could you show the hinge you used at the cover thats connected to the nose gear strut?
                        • e4dragongunner
                          Living the dream!
                          • 876
                          I think this is it !
                          • Luckiestpants
                            • 5
                            Hi all, quick question converting 6s to 8s, how far back do the batteries sit to give 190 c of g please? Any pics would be appreciated. In return here’s my F4 in 892 sqdn Royal Navy colours with thanks to Callie Graphics
                              • 5383
                              Only you can figure that out by putting your batteries in and checking balance. Batteries weigh different amounts and you’ve modified your airplane. It all makes your setup different.
                              If you look through the last few pages this has been discussed thoroughly.
                                The G nose (Wild Weasel) is different than the E nose. I only know of two sources for the E nose and that is Tom Mansel and Chris Wolfe. Chris's is more scale. The small door on mine was hinged with a standard Dubro hinge.
                                  Welcome to Hobby Squawk!!! Glad you are on board!!! Very nice job on your F-4!!!! Jerry
                                  • e4dragongunner
                                    Living the dream!
                                    • 876
                                    Hey guys wanted to share a fix for the F4 Nose gear. I sheered the pin on my second F4's 1st flight. X wind and blew me off the runway in to the grass ... Was not rough at all. Fairly gentle landing I wouldn't call it a greaser but hit was nothing excessively hard. I was really surprised that I broke the nose pin.... Well after inspecting the pin I noticed the pin is ( or looks like) pot metal on the inside.
                                    I ordered the following part from Mc master car, Part # 90224A155 10.99 each (WELL WORTH IT)
                                    With a bit of Dremel work, you can turn this 5mm case hardened steel pin in to this.
                                    This should not bend or break!
                                    • okcrcpilot
                                      Crash Certified!
                                      • Jul 2018
                                      • 13
                                      • Ocala, FL.
                                      Originally posted by Tom Lasko
                                      New guy question....I was told somewhere in these 185 pages that the a Home Depot Behr flat paint codes are in here for a factory paint match.
                                      I was hoping someone could help me identify where they might be. Thanks
                                      I hope this is what you are looking for.
                                      • Tom Lasko
                                        • Jul 2019
                                        • 14
                                        Thank you okcrcpilot, that’s what I was looking for exactly!
                                        The guys behind the counter at my local HD vary greatly in skill level color matching paint, so this should help . Question: did you feel that the samples above where a “spot-on” match to the factory paint ?
                                        • okcrcpilot
                                          Crash Certified!
                                          • Jul 2018
                                          • 13
                                          • Ocala, FL.
                                          Yes, these colors matched my camo F-4 to a "T". Now I bought my F-4 in March of last year and don't know how consistent Freewing is with their colors, so YMMV. Glad I was able to help.
