  • Robbie9859901
    • Jun 2017
    • 27
    Originally posted by Tigerman
    My aim is to fly a F4 Phantom.. Work on them when I was in the RAF. Was not sure I was up to flying a F4 Phantom, so I brought a F 86 Sabre then progress onto the T33. Then brought the 90mm F22 and I am flying them all fine. I have told the F4 Phantom is a lot harder to fly then the EDF I have (( by some one who has never flown the Freewing F4 Phantom). So if I can fly the F86, the T33 and the 90mm F22. Would I be OK to progress to the F4 Phantom, or should I still get more practise on EDF.
    The next question is 6s or 8s. Would prefer the 8s
    I went with the 8S. You takeoff with about a third more watts than the 6S. If you fly each one at the same speeds, you will get longer flight times to figure out the handling. You won't be as rushed for time.
    • jasmith41
      EDF-obsessed
      • Sep 2021
      • 317
      • AZ and NE Ohio
      Originally posted by t33jetman
      I right there with you bro on the details :)
      Sweet.
      • jasmith41
        EDF-obsessed
        • Sep 2021
        • 317
        • AZ and NE Ohio
        My F-4 Blue Angel with the 6S 12 blade inrunner on a grass runway:
        nice flying Hugh... i hope to be that good and confident in my ability someday soon...
          • 2715
          Those flights were flukes, I go through spare parts like my wife goes through shoes and purses! But seriously, I think it's more mental nervousness with the F-4 that once you get over it (which I still get squirrelly at times), you figure out that it really is a sweet flying EDF.
          • locharrow
            • Feb 2020
            • 283
            " I go through spare parts like my wife goes through shoes and purses!" Hugh, your lucky............ my wife goes through my purse and I go through my own soles.
            • jasmith41
              EDF-obsessed
              • Sep 2021
              • 317
              • AZ and NE Ohio
              yeah - no comparison... not even close, and i'm the one that bought her all of the shoes and purses. forget about the jewelry... 🤣🤣🤣
              • locharrow
                • Feb 2020
                • 283
                "forget about the jewelry" I was two years off alcohol till you :face_with_symbols_o bring up jewelry .................:see_no_evil:
                • GliderGuy
                  • 1416
                  There are alternatives:
                  Example: Cost of divorce = $100k
                  If you buy 5 planes post divorce but without having to ask permission = $20k per plane
                  Jewelry might actually be a cheaper solution!
                    • 2715
                    We've had our typical windy Spring weather for the last 2 months but did get out Wednesday for a few flights. Winds were constantly shifting and usually resulting in a crosswind, but you have to take what you get or stay home! The FW F4 really is an outstanding flying aircraft and with the 12 blade inrunner, it's got lot's of thrust to take-off from just about any grass surface quickly. More than enough speed for this "Little Old Lady From Pasadena" (in this case Miami) and the vertical is outstanding. This is one of my EDF's that I like to fly first in the day as it helps get my confidence going to fly some of the others. Started out using the bendable Spitfire nose pin when this first came out, but early last year swapped back to the stiffer stock pin and have yet to break it, but there's always tomorrow. This one's been around for a while, but "Takes a Licking and Keeps on Ticking" (a healthy spare parts inventory doesn't hurt either). :hugging:
                    • jasmith41
                      EDF-obsessed
                      • Sep 2021
                      • 317
                      • AZ and NE Ohio
                      Hugh, another great flight vid - gorgeous bird as well, and i love your rc field - no trees...🤣🤣🤣
                      I flew in Geneva (MARC field outside of Cleveland) yesterday and had more than my usual issues. The worst one was trying to land the F5 rocketship - i just could slow it down enough (not my day) and once i was able to finally set it down, it was still going so fast that it shot off the side of the runway and bounced up and then into the mud snapping the nose clean off where it connects to the battery compartment. The glue is still drying and i'll be doing some paint and body work later i guess... it didn't even bend the gear, which is more than i can say for the eflite f16 70mm - the weakest gear out there i think. still fun to fly though - i'm better at landing that than the F5. I guess i just need more practice...
                      • themudduck
                        -TMD- Foaming at the Mouth!
                        • 1041
                        • Burton OH (near Cleveland)
                        And we need better weather! Dang it.
                        Flying at a field with a 300' runway and trees is definitely a challenge but it makes us better pilots. Eventually!
                        • jasmith41
                          EDF-obsessed
                          • Sep 2021
                          • 317
                          • AZ and NE Ohio
                          indubitably... and more creative when it comes to getting planes out of the trees... #manlift 🤣
                          • locharrow
                            • Feb 2020
                            • 283
                            Sure does............ Click image for larger version
                            • jasmith41
                              EDF-obsessed
                              • Sep 2021
                              • 317
                              • AZ and NE Ohio
                              bummer dude - at least it appears as though the gear is all still intact... 👍
                              • locharrow
                                • Feb 2020
                                • 283
                                Plane was very repairable and flew again. Had another incident where I just lost orientation that required new fuselage but the old wings, tail feathers and electrics are all still flying. :punch::f4:
                                • EA-6B Geek
                                  EW Misfit
                                  • 485
                                  • South Central Ohio
                                  A great spring day at Deer Creek State Park. Maidened a new Flex F-100. Multiple flights on the trusty Flex Jet. Click image for larger version
                                  • EA-6B Geek
                                    EW Misfit
                                    • 485
                                    Oops! Think I put that on the wrong thread. Meant for “What did you fly today”.
                                      • 4869
                                      • locharrow
                                        • Feb 2020
                                        • 283
                                        Nice looking Miss America in the background there..... had the Hanger 9 one with a 120 FS pulling..........boy it could move. :punch::f4:
                                        • Mud Duck
                                          • Feb 2022
                                          • 46
                                          Apologies for a post that is likely answered elsewhere in this thread but I’m posting from an iPhone and the search features don’t work too well in this format.
                                          I direct my question to those with the 8S high performance version of the F-4. I have purchased all of the recommended components and batteries from Motion R/C.
                                          According to the manual, the recommended center of gravity is 190mm or 7.5”. No matter how hard I try to shove things further back, I am still coming out nose heavy and the F-4 is balancing at 7.0” to 7.125”. I absolutely do not want to add more weight to this already heavy model unless it is absolutely necessary for successful flight. Obviously I’m worried about being able to flare for the landing.
                                          Thoughts and recommendations or point me to the post(s) that address this issue. Please and thank-you.
