GG, if I use half flap on take off and it is in trim then on landing come through half flap to full flap and the plane dips a wing, how does the gyro know whether it was a gust of wind or one flap a few degrees out of trim? Would the gyro not bring it back to level fight using ailerons to compensate or is the gyro only a single momentary correction? Just asking, don't have the problem.
:f4::punch:
" low over guys building houses so chose a downwind half flap fast-ish landing. . Put the flaps down and lo and behold it started to behave a lot better. Landed OK, fast but fine and I taxied it back to the car. Raised the flaps and the left one stayed down. I thought it would be a pull apart job but it turned out to be just a faulty connector on the board, fairly easy fix so onwards and upwards ....:f4::punch:
:f4::punch:
