  • JamesonC
    MRC fanboy
    • 619
    • Laurens, SC
    Originally posted by Flanker271
    How does it balance with two 5000mAh side by side? Wonder if it's possible to connect them in parallel and double the flight time.
    Alpha already stated that he doesn't recommend going over a 6250mah in the 6s version. So, I doubt they are going to attempt to balance it. They only posted that to give an idea of the room in the battery area. Could it work? Probably, but you're gonna sacrifice a lot of the flight characteristics of this airframe making it that heavy on 6s.
    • Pete Lane
      Turbine lover
      • 290
      • Los Gatos Cally
      I did the math also. Using 650 gram packs X2 is 1300
      but 7 potential minutes. Average pack is like 850.
      So its 400 to 500 grams past that. It would fly but its not a carrier pigeon....lol
      • gooniac33
        The Original Gooniac
        • Jun 2016
        • 1047
        I use 6s 50c 6200mah pack that are actually lighter than almost all high C 5000s on the market. Its not about the capacity but rather the actual weight. If the pack is the right weight then go for it. But if its too heavy then that is what the issue really is.
        • JLambCWU
          • 267
          Hi Flying Hawk,
          We design our aircraft to accommodate battery ranges, when possible, to maximize the aircraft's appeal and lower the cost of ownership for those with existing batteries. This is due in part to size, wing loading, bay volume, and internal layout. The chances a model can meet these requirements declines the smaller its fan is:
          *All 90mms can fly a 6s 5000 (eleven aircraft)
          *Most 80mms can fly a 6s 5000 (five aircraft)
          *Few 70mms can fly a 6s 5000 (two aircraft)
          If modelers choose to use heavier batteries than recommended (i.e. 5800mAh in a 70mm Hawk) or lighter batteries than recommended (i.e. 2600mAh in 70mm F-104) that is their own prerogative.
          My team's prerogative is to ensure our batteries, which are industry common sizes, can be flown by our aircraft. There will be other battery sizes an aircraft can fly, but as long as the Venn diagram includes one of our batteries, our customers with those batteries are covered.
          This is one of the reasons why we haven't developed an aircraft that required 5s to fly well... Because few people have 5s packs.
          I fly the 70mm BAE HAWK with 70C 6000mah CNHL all the time. Battery all the way back and 4 clicks of nose up trim before take off. Flys great and almost 7min. Initial acceleration and climb are of course affected. But not what you would think. Stalls with wing drop happen faster in a loaded high G turn (as expected) but still acceptable. Love the extra room and the option!
          • e4dragongunner
            Living the dream!
            • 876
            • Arlington Heights Il.
            I smell 8 Minutes!
            • Pogo
              • 452
              • Waterford, Ontario, Canada
              And those would be? I'd like to get some if you're having good luck with them!
              Tom
              • Pete Lane
                Turbine lover
                • 290
                • Los Gatos Cally
                I smell 8 Minutes!
                No...that's Bacon !
                • C17loadmaster
                  Retired USAF Aircrew
                  • May 2018
                  • 371
                  • Auburn, CA
                  Tom
                  I did some comparisons....
                  I assume he’s referring to the Hobby Star 50c 6200mah, Its 780g. That’s the closest I could find. I actually bought a B-17 from the owner of RC Juice last month. I saw the price and didn’t investigate further... they’re $109
                  • DE2018
                    • Nov 2018
                    • 3
                    I noticed the torque arm on the nose landing gear appears to be plastic. Is that final production ? Should I be concerned given I fly off a regularly cut but somewhat wavy (not ideally flat) grass field ? Might as well ask, has this plane been well tested on short grass fields ? Don't want to be out of service for long periods of time and or or worse, tear the nose gear if that part fails.
                    • Pogo
                      • 452
                      Thank you C-17, good to know.
                      Tom
                      • Pogo
                        • 452
                        I really like the look of a Raptor with fuel tanks on- I hope to do them one way or another.
                        Tom
                          Tony got to the AZ Jet Rally a little early and did some dusk flying!
                          • WAY BAD
                            • 69
                            • Bossier City, LA USA
                            That afterburner tho! That was fun to watch...
                            • Shirty
                              Hobby Squawk Water Boy
                              • 1067
                              • Perth, Australia
                              Cool, nice flight
                                Nice flight Tony. Should start shipping in just about a month. I think this will be a fun one!
                                • andrew_flyguy
                                  Just wanna fly
                                  • Jun 2018
                                  • 162
                                  • Nashville TN
                                  Thanks for sharing that sunset flight!! Very much enjoyed it :)
                                    • 8215
                                    That centerburner is the perfect upgrade for this model. Nice flight, can't wait to snag one next year!
                                    • Bajora
                                      AA6JB
                                      • 462
                                      • Sonoma County, California
                                      • Pete Lane
                                        Turbine lover
                                        • 290
                                        • Los Gatos Cally
                                        Is the ducting on this jet split like on the F-4 ?
                                        I have a few ideas going on in my head.
                                        Pete
                                          Pete
                                          Hi Pete,
                                          Ask and you shall receive:
