    • 5416
    Sure thing. This plane is so tolerant. CG, battery weights... very tolerant, a real floater. After a few flights consider tailerons, full span flaps and other programing. I still think it should have come stock with TVs and more lights. Beating the dead horse...
    • Shaun Evans
      • Apr 2021
      • 125
      • California, USA
      Hi guys!
      I just finished my conversion. It's 10.5# AUW with the external tank and a K-55. Engine is way too big, but it's what I had so...
      Anyway, what do you think of the weight?
        • 5416
        Should be good.
        • mribeiro
          • Jun 2020
          • 9
          For full span flaps you need mor mix with down elevator?
            • 5416
            I have no mix with standard flaps and a bit of up mix when using full span.
            • Shaun Evans
              • Apr 2021
              • 125
              • California, USA
              Speed brake
              • Polyphren
                • Dec 2020
                • 37
                Fun in the Autumn sky…
                • mribeiro
                  • Jun 2020
                  • 9
                  So I'm waiting the arrived this model.
                  where do you place the gyro?
                  Do you bypass the bluebox or not?
                  change the bec or not?
                  Any mods need or advise i will appreciate
                    • 5416
                    I don’t have a gyro in mine for the flight servos. I do have a steering gyro. I did bypass the MCBe for ailerons, elevators, rudders and flaps. I did that so I could do some programming.
                    I also tried mine stock 6s, 8s, 10s, and 12s. I put it 8s, not a stick FW 8s after trying the different set ups. Since I went 8s I did need a different ESC/ BEC. I also added thrust vectoring and wing tip lights.
                    • Polyphren
                      • Dec 2020
                      • 37
                      Sometimes a gyro might be helpfull, but most of the time, the Raptor flies fine without. In my video, the gyro was switched off.
                      I recommend an enforcement of the front gear. The plastic part that holds the gear servo unfastens rapidly in the foam compartment. …at least in my plane. There are two holes prepared for screws. For the hole under the servo compartement you‘ll need a flat head screw. Underneath the cockpit I glued a piece of plywood for mounting the screws.
                      The two rear gears were also modified. The retract gears and the wheels are connected with a 5cm bolt that is fixed with two grub screws on each side. After take offs or landings on grass the bolts will unfasten, so that the plane might suffer unexpected steerings. I added a drop of Locktite to the bolts. (You can still disassemble the gear if necessary)
                        • 5416
                        I can't picture what you are trying to describe...
                        • Polyphren
                          • Dec 2020
                          • 37
                          Currently the head of the screw collides with the gear, so I will buy a flat head screw tomorrow.
                          @Evan D: Better?
                            • 5416
                            I see. Thanks. I thought you were talking the main gear since you said "rear gears" and then "retract gears and wheels". Do you fly off grass?
                            • Polyphren
                              • Dec 2020
                              • 37
                              „Do you fly off grass?“ … every time I miss the runway 😁
                                • 5416
                                • Polyphren
                                  • Dec 2020
                                  • 37
                                  That‘s what I did for the rear wheels.
                                  • Shaun Evans
                                    • Apr 2021
                                    • 125
                                    • California, USA
                                    Hi,
                                    How much down-elevator are you guys having to use for inverted, level flight?
                                      • 5416
                                      About none... A little lean on the stick.
                                      • Shaun Evans
                                        • Apr 2021
                                        • 125
                                        • California, USA
                                        Hmmm.....
                                        Mine needs tons. What's your cg?
                                          • 5416
                                          Not really sure, sorry.
                                          looking at the old thread on the other site I said a couple years ago 150mm but I may have changed from then.
