  • Shaun Evans
    • Apr 2021
    • 125
    • California, USA
    Not really sure, sorry.
    looking at the old thread on the other site I said a couple years ago 150mm but I may have changed from then.
    Hi,
    What would it take to persuade you to measure it for me? ;)
    • Polyphren
      • Dec 2020
      • 37
      Hi, the CG for my red raptor is 150mm. A correction for inverted level flight is not necessary with my plane.
        • 5416
        I’ll try to do it soon.
        check and verified, 150mm.
        • Shaun Evans
          • Apr 2021
          • 125
          • California, USA
          Hmph.
          I guess I'm very nose-heavy, then. :(
          Thanks!
          • mribeiro
            • Jun 2020
            • 9
            Can some confirm if this lipo fits one an 8s setup?
            4s 5200 90c - size: 35X46.8X160mm x 2
            from the book is in the limit H=70.
            I have a chance to buy with 60% discount lipos for a 8s setup
            Tks
              • 5416
              So two would be 70mm wide, 47 tall and 160 long, no problem. The F-22 has a very large battery area.
              • mribeiro
                • Jun 2020
                • 9
                Yes, but 70 is on the limit, if some reason have 36 dont fit.
                if some one measure i will appreciate
                  • 5416
                  But 70mm is the width not the height. Mine are 75x 45x145 and there is a ton of extra room every dimension.
                  • mribeiro
                    • Jun 2020
                    • 9
                    Originally posted by electric jet
                    Hello all, I finally found time to unbox and assemble my 90mm F22 and I have some questions. first off, with a admiral 5000 bat. I have to push the bat. back half way off the battery tray to even get close to neutral CG. with the gear up and the canopy cover installed it is still slightly nose heavy??...I see videos of guys pushing the bat. closer to the blue box and flying that way. I have checked my measurement (150mm from wing/fuse crotch) and accurately marked it. Do you all just fly nose heavy?Or is the plane not that sensitive? What am I missing.
                    Also, how much if any expo you guys using with this aircraft. I'm new to EDF, any advise would be appreciated. won't be flying till spring anyway. Thanks
                    Hi, I have the same issue or not, I have the battery back to get 150mm.
                    do you fly like this?
                    • Av8er278
                      • Jan 2021
                      • 123
                      • San Diego, Ca
                      Question does everyone check cg with gear down and plane in flying position not inverted ??
                      • Oachidori
                        • 52
                        • Bucharest, Romania
                        Is there other possibility that that?
                        Badan Kit - Yak55M 2.8m; EF - Extra 300 2.3m; Multiplex - Funcub;Funjet Ultra2;Parkmaster;FW - F22 90-X45 Xicoy;ROBBE MISTRAL 2.0
                          • 5416
                          Yes, gear down and upright.
                          • Av8er278
                            • Jan 2021
                            • 123
                            • San Diego, Ca
                            Thanks Evan
                            • mribeiro
                              • Jun 2020
                              • 9
                              Anyone's have cheating holes in this model?
                              • mribeiro
                                • Jun 2020
                                • 9
                                Anyone change the esc to have reverse thrust? If so what esc do you have?
                                • Gilatrout
                                  RC Pilot Addict
                                  • 806
                                  • Albuquerque NM
                                  I believe that either the Spectrum Avian or Castle Escs support reversing
                                  • Airguardian
                                    Post Stall Svengali
                                    • Aug 2020
                                    • 1686
                                    • Catalonia
                                    Am joining the show!
                                    • ridgerunner
                                      • Nov 2017
                                      • 275
                                      • Central Utah, USA
                                      +1
                                      Very nice flying! Love the flat spins and those flip-floppy maneuvers near zero airspeed.
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1686
                                        • Catalonia
                                        Thanks!
                                        • Airguardian
                                          Post Stall Svengali
                                          • Aug 2020
                                          • 1686
                                          • Catalonia
                                          Flights 6 to 9! :)
