Yeah too much effort for details I would never notice or care about.
Hi All,
Wonder if anyone can help me with the Aircraft Type settings on the Spektrum DX6 & Spektrum AR631 with safe. Need to get this correct before I fly the beast :)
I am not sure on the Wing Type and Tail Type for the 90mm 6S 6CH. I just need the basic setup - nothing special like the flaps moving with ailerons etc yet :)
I have all of the control surfaces moving with both set to 'Normal' but I am not sure that is correct... ?
Should they really be set to some of the following :
Wing :
- Normal (shows 1 servo for both so does not seem right..)
- Dual Ali
- Flaperon
- 1 Ali, 1 Flap
- 2 Ali, 1 Flap
- Elevnon
Tail :
- Normal
- V Type A (1 servo each)
- V Tail B (looks same as A) ?
- Dual Ele
- Dual Rudd
- Dual Rud / Ele
My gut says Dual Ali & V type A or B but please advise..?
Any advice is much appreciated I have only flown an apprentice s and visionaire :)
* P.S. where are the stickers meant to go the manual does not say either...
Wing :
- Dual Ali
- Flaperon
- 1 Ali, 1 Flap
- 2 Ali, 1 Flap
- Elevnon
Tail :
- Normal
- Dual Ele
- Dual Rudd
- Dual Rud / Ele
Who is using one of the 3D printed front landing gear braces that you can purchase on ebay on their 90mm F22? I am going to be running on grass mostly and I was told that it is a good idea to install one of these front landing gear braces to strengthen the front landing gear on the F22.
Originally posted by Gsky View PostHi everyone,
im looking into fitting some lights to the f22 for orientation.
I saw some people using the f14 light set. Does anyone know if these lights fit straight into the bluebox? Or would the l39 set be easier to fit? Im not so got with the soldering/wiring.
thanks for the help.
Originally posted by starcop View Post
Hello Aros! Hope all is well buddy. I hope things are going awesome with your family too. Matt
Originally posted by xviper View PostEvery one of these "blueboxes" that I've seen in my planes have the ability to plug lights in. Here is the diagram of the one from my F-22 and you can see all the light inputs (2-pin). All Freewing LED lights should accept the same voltage that comes out of these blueboxes and all are 2-pin. Since only the take-off light is used, the rest are open for you to choose. You should have this same diagram in the manual of your F-22. If you want something much brighter from an aftermarket kit, then you may need to also get their light controller and plug that into the appropriate port on the RX.
