  • After i tried the bifurcated pipe and i saw that wasn't the best solution(lack of power and more fuel) i decided to buy another plane and install an oval pipe. This time i didn't had to cut the plane to install the new pipe. I also painted in black to see better the difference between the two faces. Also i replace the receiver with a 12 ch to have the rudders on separate chanel and to have the possibility to make some mix, in order to help me to take off easier from our field. We will see.
    Badan Kit - Yak55M 2.8m; EF - Extra 300 2.3m; Multiplex - Funcub;Funjet Ultra2;Parkmaster;FW - F22 90-X45 Xicoy;ROBBE MISTRAL 2.0
    • w00t
      • Comment
        • For the third F22 i decided to put a straight oval pipe with the X45! Good decision! the plane fly awesome, i flew around 10 min with 1 l tank, so that is very good. Before with the bifurcated pipe i flew only 4 min with a 0.8 l tank and the tale off was difficult. But how you can see in the movie, i fly only on the grass field and my problem is the behavior of the plane. How can avoid the hopping of the plane? My Sebart's friend doesn't have this behavior..
          • Almost done on the F-22 wheel set...
ID:	402816 Click image for larger version
            • Looks great......
