    • 8827
    Alpha makes much sense. Leaving something like a gyro for manual activation (especially on a plane like this) may be trouble waiting to happen. All will work well until that first brain fart.
    • Greyhound61
      Hobby Squawk Pilot
      • 37
      • Lucerne - Switzerland
      Dear Xviper, dear Alpha,
      thank you very much for your comments and help. Indeed, I have to re-think my configuration. I will fly the stock setup and will later decide, whether I will use a gyro (Alphas 2nd setup)
      • fhhuber
        • Aug 2015
        • 1476
        Experimenting in trying to detail the F-14 cockpit. I have found that the F-4 Phantom ejection seats at 145% are correct.
        I am printing them split front/rear appx 4mm behind the cushion in the enlarged scale to reduce the amount of supports needed. (may not be the ideal split, but it works well)
        I'd recommend scaling them off a little to make them not as thick front to rear though. Its butchering my badly gatored cockpit (planning to get a new one) to get the rear one in.
        Use another "rear" of the F-4 phantm's ejection seats for the front. the Tomcat front seat uses the same full figure pilot figure as the rear. The Phantom uses a bust only in front is why it uses a clipped ejection seat in front.
        Tons of room for a canopy servo with the larger scale 3D printed seat, but I am not doing that mod.
        I will upload my edited STL to Thingiverse after verifying with another print.
        This is the SPLIT, done in Blender, not the scaling. I did the scaling in Cura slicer. So you could print the split version without scaling for the Phantom.
        I'll similarly split the front ejection seat because I also have the Phantom.
        • p51mustangman
          • Feb 2019
          • 63
          Just put in my order for a pair of centerburners for the cat, can’t wait to try them out!
          where do you get these?
            • 2818
            • Arlington, TX
            The original CenterBurner line of simulated afterburner lighting systems is the world’s best and most trusted simulated afterburner lighting system! Designed around a custom built LED light boards, it provides a center "glow" and flame effect like a full size jet aircraft afterburner!
            • pullupnow
              Pilot
              • 70
              • Long Island NY
              Perfect morning to put a few flights on Vark 101
              • pullupnow
                Pilot
                • 70
                • Long Island NY
Name:	F-14 blowing pollen.jpg
ID:	196411Click image for larger version
Name:	F-14 blowing pollen 2.jpg
                • pullupnow
                  Pilot
                  • 70
                  • Long Island NY
ID:	196418Click image for larger version
Name:	F-14 pass 2.jpg
ID:	196419Click image for larger version
Name:	F-14 flare.jpg
ID:	196420Click image for larger version
Name:	F-14 touchdown.jpg
                  • RaptorMan2275
                    • May 2019
                    • 10
                    Hey everyone! New here and wondering if anyone has done a successful 8s setup in the f14? Sorry if this has already been answered but I’m still trying to figure out how to navigate the site. Any info would be awesome! Thanks!
                      Hi RaptorMan, welcome home to Hobby Squawk! We designed our F-14 for 6s power systems. I think in the early days after its release there were a couple pilots who tried 8s, but I can't think of anyone who still actively flies 8s in this bird. It's really intended for the power/weight/cost balance of 6s. 8s can get expensive and heavy in a hurry, without massively meaningful benefit to how the aircraft already flies. As the lead project developer I always recommend trying the model as we intended it, in its stock PNP form. If you're not satisfied, then consider the costs of upgrades (inrunner 6s, lightweight 8s, etc). Largely, the vast majority of our customer family ends up coming back to the stock setup.
                      • RaptorMan2275
                        • May 2019
                        • 10
                        Thanks for the reply Alpha! It definitely appears that information on a solid 8s setup for this beautiful bird is few and far between. I really appreciate your input as I haven’t added the F-14 to my collection as of yet and am just trying to weigh out my options in the power system department. I’m the kind of guy that likes to burn a hole in the sky with speed and really want this thing to hall ass. I guess I’ll just try the stock power system first and go from there. I was extremely happy with the F-22 8s btw. Great job on that thing!
                        • e4dragongunner
                          Living the dream!
                          • 876
                          • Arlington Heights Il.
                          I have the F-14 and I am replacing the stock power with the A-10 Setup, Supposed to be lighter and pack more of a punch... ;)
                          • RCINFORMER
                            • Dec 2013
                            • 13
                            I just posted this the other day.... Special thanks to Carl Lydick for filming this Flight Demo & sending me the file to play on the RCINFORMER YouTube Channel:) See carls YouTube Channel at wilmracer on YouTube.....
                              Hey Rich, good to see you on the Squawk. Will definitely check it out. Thanks! I sure enjoyed seeing you fly it at Nall. That was actually the first time I have ever seen the Tom Cat fly in person.
                              • James
                                Administrator
                                • Aug 2017
                                • 1543
                                https://www.youtube.com/watch?v=bXo5IpU7_gk
                                Great work Rich!
                                • e4dragongunner
                                  Living the dream!
                                  • 876
                                  Yea!!! Welcome Rich.
                                  Love your Vids X10. Great work.
                                  You guys out front. You Steve, Jeremy, have really set the tone for the rest of us!
                                  Thanks for all of your efforts and insights! Hope to see you at Jet Jam! :Cool:
                                  • Aces
                                    Pilot Wannabe
                                    • Jul 2018
                                    • 179
                                    • Georgetown Texas
                                    Hi guys. I have the F14 and although I skimmed through every page of this thread I would love to know where to purchase the center burners? Thanks for the help.
                                      • 8827
                                      • Aces
                                        Pilot Wannabe
                                        • Jul 2018
                                        • 179
                                        • Georgetown Texas
                                        Thank you! Ordered!! 😜
                                        • C17loadmaster
                                          Retired USAF Aircrew
                                          • May 2018
                                          • 371
                                          • Auburn, CA
                                          Now you need aluminum tape!
