How much lift can the airliner generate? What is theweight of plane except with batteries? I was planning on buying 22000mAh battery which weighs 2.5kg. Can it lift it along with a gyro?Comment
How much lift can the airliner generate? What is the weight of plane except with batteries? I was planning on buying 22000mAh battery which weighs 2.5kg. Can it lift it along with a gyro?Comment
In my opinion, it won't work... This plane doesn't fly like a real one. He is fast and needs speed all the time, especially in corners. High weight with such a small supporting surface of the wings will cause problems.
I agree lusec ive been thinking about 2 4000 mah,, for an 8000 capacity,, (currently running 6000) and have been nervous about a 250 gram weight increase..... have not come close to tip stall,, but am on the power in turns..... so 2 or 2.5 kg seems heavy..Comment
Did say thinking about... ( Will do it) but based on 3 minuts for 6000 mah.. i beleive 4 minuts for an 8000 mah.. 33 percent increase. Any business would luv that flying my f4 for 3 then 4 minuts was huge increase why 100 pcennt throttle? 80 or 90 keeps esc etc way coolerComment
Afternoon all,
the airframe i have i bought used. I have notice the join on the fuselage is starting to open ever so slightly at the top and don't want to re-paint and then have the tail section disconnect
what is the best way to repair this? Epoxy rods in to cut out slots on the external join then filler to hide?
Thanks all,
SR.Comment
Many ways im sure... mine was painted first ,, not enuf research first.. but i used a soldering iron to put (Melt) small groove, around 6 inches long on the to join and epoy in place... noo filler req jjust bit more red paint u can c it in batt placemen t pic 2381Comment
thanks. Least i know someone else has had to sort this issue.
trying to strengthen the join internally might be another option if i can reach in far enough.
Greetings all, have a question. Has anyone totally glasses a AL 37 and if so did it effect flight weight to the point where the aircraft becomes something really super cool to hang from the ceiling? Reason being I'm doing a Southwest livery (all painted) and just sanding off the little mold markings I've gouged the foam with just the corner of the sand paper and also as others have stated the paint pulls off in some places. I'm thinking about using 3/4 oz fiberglass cloth and polyurethane. Any advice would be greatly appreciated.Comment
Also, anyone who has installed graphics where you have to wrap a piece from the belly to the tail, were you able to do that without cutting, or having wrinkles? Any tips you want to share? I'm psyching myself out thinking about laying this on at the angle it needs to go on, having to deal with three different curves, trying to have stripes match with the vertical fin stripes, etc... Thinking big decals like the Southwest tail bits, for instance.Comment
