    • Nov 2013
    • 2648
    • Cody, WY
    Hi Evan: good head work there using the piano wire! What diameter piano wire do you use, and do you glue them into your wingtip?
    I think I’ll pursue your great idea of the piano wire skids and also try to find some suitable material to stick onto the impact points where the tip tank contacts the runway when the plane tips, usually on landings.
    I just replaced my tip tanks with new ones that I’d like to protect. I can use the old ones as a testbed to find the best solution for my TBird.
    Thanks for the tips!
    Cheers
    davegee
    • MikeT
      Here......Hold my beer.
      • 1060
      I did a quick search and this came up. I'm sure other places have it too..
      Team Associated Chassis Protective Sheet [ASC9787] | Cars & Trucks - AMain Hobbies
      Unfortunately discontinued. Need to poke around I'm sure someone else makes it. So far all I've found is colored or printed.
      Mike
        • 5385
        I think I just used an extra push rod... Doesn't need to be too thick. Poked it in a 1/4" on those but the tips have plastic over them. On foam maybe 1/2'...
        Cheers
        davegee
        • Mr408w
          RcPatriot
          • Oct 2017
          • 14
          • Norway
          At last one maiden flight on the freewing T-33 in this windy season! At least Up here North, in south-east part of Norway! More maiden waiting ....
            Evan D Those skids are a great idea, I'll have to try that specific shape. Normally mine just trail off, but your triangle shape looks much more "finished".
            Those will come in handy..
              • 5385
              Thanks Alpha, keeps me from printing so many missile fins!
              • EA-6B Geek
                EW Misfit
                • 485
                • South Central Ohio
                I don’t have many flights on this T-33 yet, but it’s a pleasant surprise every time a take it out. Easy to fly, and it really rips.
                  • 5385
                  I see a theme
                  • SanExup
                    • 912
                    • Western Wy.
                    EA-6B Geek Nice flight line!
                    • F22trainer
                      Piper PhD
                      • Mar 2018
                      • 1484
                      • Sun City, Az
                      Does anyone have an idea or technique they use to prevent scuffing or damage to the bottoms of the tip tanks without pulling the paint off, like tape often does?
                      Thanks for any ideas.
                      Cheers
                      davegee
                      The $1 store has these polypropylene mats which are sold as counter-top savers, usually 3 -6 in a pkg. they a quite thin and flexible when cut into strips, and they have different colors! I use contact cement and have put them on several different planes including 3 of my gliders in place of skids and even on the Ryan STA on the wingtips.
                        • Nov 2013
                        • 2648
                        • Cody, WY
                        Nice Idea! Any chance you could post a pic of one installed on your plane to give me a better idea exactly how you do yours?? Thanks for your input.
                        Cheers
                        davegee
                        • F22trainer
                          Piper PhD
                          • Mar 2018
                          • 1484
                          • Sun City, Az
ID:	317809Click image for larger version
ID:	317810Click image for larger version
                          Cheers
                          davegee
                          use the Weldwood or similar solvent based (not water based) Contact Cement. Apply to both surfaces and let dry fully (30 minute) then just carefully position and stick it down - there is no repositioning, so get it in the right place. A bunch of toothpicks can be a nice bridge. Just lay them across the dry cement align your piece and start pulling them out one at a time.
                          Click image for larger version  Name:	78F9BAC3-FB6F-4C2D-A9B2-87504E5B3E7C.jpeg Views:	0 Size:	62.7 KB ID:	317806Click image for larger version  Name:	4DC63C29-31F5-450F-8F30-500EC6DFAB6B.jpeg Views:	0 Size:	115.3 KB ID:	317807Click image for larger version  Name:	04D74C09-1351-4C87-BAB4-C57E7FAD6F29.jpeg Views:	0 Size:	45.6 KB ID:	317808
                          • SanExup
                            • 912
                            • Western Wy.
                            Is contact cement safe for foam?
                            • radfordc
                              • 375
                              • Lansing, KS
                              Yes, for EPO. T-33 is EPO
                                • Nov 2013
                                • 2648
                                • Cody, WY
                                Thanks very much, F22trainer! That looks like tough material that would keep scuffs limited to the protective layer itself and not penetrate to the model structure. I can definitely see some applications for these protective pads on some of my airplanes.
                                Thanks!
                                Davegee
                                • F22trainer
                                  Piper PhD
                                  • Mar 2018
                                  • 1484
                                  • Sun City, Az
                                  Thanks!
                                  Davegee
                                  They don’t do compound curves very well, but a little creative clipping does wonders and they do indeed work well. Lacquer thinner will remove excess or allow it to be removed and replaced.
                                    • Nov 2013
                                    • 2648
                                    • Cody, WY
                                    Sounds like a winner!
                                    Thanks!
                                    Davegee
                                    • long-love-rc
                                      • Jul 2020
                                      • 91
                                      One question on my new T-33:
                                      I just assembled my Freewing T-33. What a beautiful model!
                                      I am wondering if I need to put on a gyro. Considering my skill level, I can fly Freewing Bae Hawk with a gyro well, and the Eflite Viper 70mm. My field has some crosswind, usually slight, but may becomes a bit strong in the noon.
                                      Will a gyro help me? Thanks a lot for your input.
                                      • timmybeetle
                                        Warbird addict
                                        • 132
                                        • Netherlands
                                        Hello
                                        A gyro can always be of help (assistance) to keep yours plane steady.
                                        I fly from grass, so my CG is a bit more back than manual.
                                        In this case i build in a gyro to keep the plane flying straight, otherwise it would waggle a little.
                                        If you use a gyro, put in on a switch so you can turn it on/off.
                                        grts Hans
                                        • long-love-rc
                                          • Jul 2020
                                          • 91
                                          Originally posted by timmybeetle
                                          Hello
                                          grts Hans
                                          Cool! Just slapped on my gyro! fingers crossed, wish I have a nice maiden!
