  • timmybeetle
    Warbird addict
    • 132
    • Netherlands
    T33 lost plane in flight
    Sadly today my plane had a crash in a tree due to no control and power in flight.
    Picture is of my telemetry data of crash.
Name:	t33 crash brown out.jpg
    Picture below is with current and Vfas
Name:	t33 crash brown out current and Vfas.jpg
    At home I tested ESC and RCVR and they worked.
    I have to mention I have a Frsky X8r as RCVR and also I used an Hobby Eagle A3Pro Gyro in my plane.
    Picture below is my test with 2 times put my XMTR to OFF and last time I removed servo lead from RCVR to simulate no BEC power from ESC.
Name:	t33 crash xmtr to OFF and ESC servo cable out current and Fvas with text.jpg
    My findings regarding crash and seeing my telemetry data is that I lost my BEC voltage in flight.
    Plane is removed from tree and it is reparable luckily, but it will have some battle scars.
    I thought that I have read somewhere issues with this gyro and loosing control.
    I have many flight with this setup but sadly today I have this mishap.
    Greetings from The Netherlands Hans
    • Phantom
      • Mar 2019
      • 504
      • M.D.
      I have stopped using the X8r, it's the only common denominator to losing 4 EDF's totalling 2 grand. I still use the older Frsky receivers no problem.
        I have one of the x8r recievers, so far I been lucky, no problems. I did make sure to get the latest firmware into it. Mostly I use the s6r and s8r recievers in everything. Just recently began using the new archer series recievers. So far so good.
        • timmybeetle
          Warbird addict
          • 132
          • Netherlands
          Pilots
          I have about 8 of these X8R receivers ( I have EU firmware in it from 2016) and fly with them about 5 ore 6 years never a problem.
          As you can see in my telemetry data problem has to do with loosing power to receiver.
          I will test this receiver in my Tundra test plane, will update when done, probably this afternoon.
          Grts Hans
          • Phantom
            • Mar 2019
            • 504
            • M.D.
            I flew and lost all 4 jets in S. Korea, so don't know if it was a geographical situation, as there is are many competing signals of various strengths all over the country. But as I flew many other receivers during the 4 years I lived there without fail, I'm going to keep blame for the failures squarely placed with the X8r. Not going to use them. Personal preference based solidly on my own experience.
              Yes indeed, sometimes you have good luck others not so much
              • timmybeetle
                Warbird addict
                • 132
                • Netherlands
                Test Update RCVR X8R and Gyro Hobby Eagle A3Pro
                Today I flew a couple of flights with my Tundra to test X8R RVCR first, no issues, also before first flight did range test and everything was OK.
                Than I installed Gyro and flew also a couple of times, switching between auto level mode and stabilized mode, also no issues at all during my flights.
                So tonight I start repairing my T33 and it went quick, I first will fly it and after it will be fine I will start touching it up.
                I was able to test my ESC and motor at home in my garden, no problems so far.
                So next thing I will do is flying my plane but I will install a backup BEC in it , and at home check my telemetry data to see if I had an BEC voltage drop.
                Not I nice feeling to fly it again with this issue.
                Grts Hans
                • radfordc
                  • 375
                  • Lansing, KS
                  Hans, I do something different and I believe better. In parallel with the stock BEC I add a small 400mah 4.8v NiCd battery. As long as the BEC is putting out 5v the NiCd provides no current to the system. If the BEC fails then the NiCd battery provides power to continue the flight. I just plug the NiCd into an empty port on the Rx before each flight and unplug afterward. If no empty port is available use a Y cable to any servo. This simple system is nearly 100% foolproof.
                  • timmybeetle
                    Warbird addict
                    • 132
                    • Netherlands
                    Originally posted by radfordc
                    In parallel with the stock BEC I add a small 400mah 4.8v NiCd battery. This simple system is nearly 100% foolproof.
                    Hi,
                    Thanks for this advise,Is indeed a simple solution for a fail safe.😉
                    Regards Hans
                    • DennisJSparks
                      • Mar 2015
                      My T 33 after countless flights is using up the batteries much quicker than before and the batteries are a lot hotter after flying than they used to be. Even the new batteries I purchased are doing the same, I am thinking ESC or fan unit. Any thought would be appreciated
                      • radfordc
                        • 375
                        • Lansing, KS
                        Looks like this
                        • timmybeetle
                          Warbird addict
                          • 132
                          • Netherlands
                          Flight report
                          Today flew 4 lipos with my repaired T33.
                          No issues at all, I checked my telemetry data for RCVR voltage A1 and saw no strange behavior today.
                          Plane flew as great as always.
                          My solution for the moment with a second BEC installed gives me a save feeling for the moment flying my T33.
                          Grts Hans
                          Ready for take off
                          grts Hans
                          • timmybeetle
                            Warbird addict
                            • 132
                            • Netherlands
                            Hi
                            Don't know if you are able to see yours amp draw during flight?
                            Ore at least test this with an power meter on the ground to check this.
                            One option is to clean the fan unit and housing, I do this after 15 ore so flights,
                            see https://www.hobbysquawk.com/forum/rc...810#post261810 ,
                            I fly from a grass field.
                            grts Hans
                              • 8747
                              Check the soldering in ALL the connectors starting with the battery connector, then the ESC connector. I've found that if the soldering is not perfect or if older connectors get aged soldering, things get hotter.
                              • timmybeetle
                                Warbird addict
                                • 132
                                • Netherlands
                                Update signal loss in flight with my T33
                                Yesterday evening flew again with my T33.
                                Using same LIPO as with problem flight, and again I was loosing signal.
                                In flight after a couple of minutes I want to do a low run over the landing strip and giving full power to go up.
                                Suddenly my motor went out but luckily after a second I gained control and was able to fly further motor responding again, and make a save landing.
                                On the ground I gave a couple of full power but it still worked🤥
                                Flew my other LIPO's and had no issues at all.
                                At home I inspected LIPO XT90 connector for soldering , and there I think I found my problem.
                                See quote above.
                                My solution to put another BEC in my plane connected to XT90 connector from ECS is not the solution when you have a connector problem on yours LIPO.
                                I made for now a 1S lipo 750mah with a diode in the plus line, waiting for my 400mah nicd battery packs to arrive.
                                Greetings Hans
                                • DCORSAIR
                                  • 1918
                                  • Selma, Ca.
                                  Yes, check those connectors, I would have lost my big Roban 700 Cobra had I not heard sparking on this connector, the red wire is held on with just a tiny drop of solder and it broke loose before the next flight, so I advise those who are using these to cut the heat shrink off and look at it before use, at least add some more solder or throw it away like I did and make your own connector, it would have been Cobra down for sure. Sorry to put this here but I thought it would save someone's pride and joy, if your using one of these.
                                  • timmybeetle
                                    Warbird addict
                                    • 132
                                    • Netherlands
                                    Cheater hole T33
                                    Pilots
                                    Has anyone closed this cheater hole and flew with it?
                                    I fly from grass and maybe this cheater hole sucks the plane to the ground during take off!
                                    Maybe I will use duck tape and test this next time on the flying field . will see.
                                    Grts Hans
                                    • Icarus the 2nd
                                      • Aug 2018
                                      • 164
                                      • Pajottenland, Belgium
                                      Cheater hole T33
                                      Pilots
                                      Grts Hans
                                      Hans, the T-33 really needs the cheater on the belly or you won't be able to take off from grass.
                                      I've added a mesh screen (the stuff you use at home in your windows to keep out insects) and it keeps your EDF unit clean without loosing too much thrust.
                                      Want some pictures?
                                      • Ron1950
                                        Retired ATC
                                        • Oct 2015
                                        • 887
                                        • brandon ms
                                        i have always had trouble taking off from short grass here in miss it seems to get up to flying speed with take off flaps but wont lift the nose to fly today we tryed full flaps and finally after a long run it flew the nose came up at about 45 degrees right off the ground but we caught it in time to level it off..ive calabrated the throttle the cg is good useing a 4000ma 6s battery iam thinking about buying another 1920kv motor and see if that is the problem any suggestions? my f86 with same motor and fan has no problems getting off same field
                                        • EA-6B Geek
                                          EW Misfit
                                          • 485
                                          • South Central Ohio
                                          Hey Ron. I fly my T-33 off of a nicely paved asphalt runway, and I have noticed that it never just rises from the ground. Always seems to leap into the air suddenly. The results seem similar regardless of the flap setting. I think it’s an angle of attack problem. I tried increasing the length of the front strut, hoping for a smoother transition from the runway. Using an incidence meter, I noted an increase of 2 degrees after I lengthened the strut. Didn’t make a bit of difference. I still believe it’s an AOA problem. This thing really sticks to the runway after touch down on landing. Haven’t had a chance to try anything else, but I may install a set of smaller diameter main wheels, hoping to get that nose up some. I know smaller main wheels are no help if you are trying to get it off of a grass field, but this is all food for thought. Sure flies great!
