  • fredmdbud
    • 450
    bye
    • kallend
      • 1862
      I'm unsubscribing from this and the thread in RCG. Nothing but the same ol same ol...
      OK.
      • radfordc
        • 375
        • Lansing, KS
        You can tell Evan is a pilot....announcing his departure!
        • fredmdbud
          • 450
          More tests with bigger batteries. Caught early, stabilators can recover, but if with enough speed gained (last test), the problem appears; flaps-up fixes things. This might be a reason they went up to 30g.
          It may seem very brief, but you lose a lot of altitude quickly when at full throttle.
            • 2693
            It seems that a picture (or video in this case) is worth a thousand words. Those stabs really flex at full throttle and flaps!
            • GliderGuy
              • 1408
              Excellent video study! What servos was this done with?
              The video shows why my first flights with the original 17g servos didn’t have issues…..I flew it like a grandpa: 1/2 throttle and no flaps until slowed on down wind after the gear was down. Faster flying was only done after upgrading the FFS servos.
              • kallend
                • 1862
                So very strong evidence of an aeroelasticity problem that may be overcome by brute force.
                A more elegant solution would be a redesign of the stab pivot geometry and mountings to reduce the flexing forces and increase the structural stiffness.
                In my opinion (which is unchanged since last year).
                • fredmdbud
                  • 450
                  And uneconomical. Very academe.
                    • 2693
                    When you gotta go, you gotta go. Makes sense to me!
                    • fredmdbud
                      • 450
                      Last flaps-test video for now, including tufts to show airflow over the stabilator, with close-up clip of the dive at the end.
                      Captain MoMo in the background ("When are you going to dive?")
                      • kallend
                        • 1862
                        Brute force is a Band-Aid fix.
                        • fredmdbud
                          • 450
                          A Band-Aid fix today is better than a redesign years away.
                          Or just widen the flap span - they're not molded on the wings, and are an easy DIY project (balsa).
                          But probably not good enough for you, so just don't buy it (which I suspect is the case).
                          • 4qr1hu9n7
                            • Dec 2020
                            • 36
                            Why would anyone be foolish enough to deploy flaps at full throttle ?? Clearly exceeding the flight envelope of the model.
                            4QR1HU9N7
                            • radfordc
                              • 375
                              • Lansing, KS
                              Thank you so much for your wise counsel...of course no one ever had this thought before so you have been quite helpful.
                              • Airguardian
                                Post Stall Svengali
                                • Aug 2020
                                • 1664
                                • Catalonia
                                I already provided a much more elegant band-aid fix 'yesterday'.
                                Glass the stabs with a continuous ligthtweight cloth (WBPU will do), closing the profile.
                                Reinforce stab assemblies (easier way to do is by epoxying in the verticals).
                                Add some stronger servos too. Use a proper linkage. Shift CG aft, 15mm minimum, reflex airfoils. Boom, done.
                                • fredmdbud
                                  • 450
                                  Then prove/demonstrate it?
                                  • locharrow
                                    • Feb 2020
                                    • 283
                                    This is what my honest trader in China tells me regarding upgrades...
                                    "Hi thank you for your reply. Yes, the elevator servos are 30g now. Thank you.
                                    However, the Mig29 in our stock has 23g elevator servos. And after the stock is sold out, we will have Mig29 with 30g elevator servos. At the same time, we will try to buy 30g servos from Freewing if they have it now. If we get 30g servos, we can replace the servos for you as well. Thank you.
                                    My plan is to fit a pair of CF rods in the underside of each stab and as a belt and braces fix get on my knees and pray for a week before maiden. Having plenty butt puckering flights with the Freewing F4 to worry about what happens when the Mig arrives!
                                    • fredmdbud
                                      • 450
                                      Motion RC has been pre-emptively providing 30g servos and upgraded rods with MiG-29's purchased since May.
                                      Will be interesting to see the specs of the servos the Freewing factory will start installing.
                                      • GliderGuy
                                        • 1408
                                        (Edits added after original post)
                                        Thanks Fredmdbud for the videos..
                                        Band aid fixes work good enough via demonstrated success. For sure I DO NOT fly fast with flaps down and have no desire to push the flight envelope into that realm of no man’s land.
                                        Happily pushing well past 1,000 flights and still going strong courtesy of multiple band aid fixes. The main one I did not do was glass the FFSs. But, that’s my choice. So far, one aileron and one rudder servo needed to be replaced (they started to chatter) just to be on the safe side.
                                        By my count, I did 15 band aid mods suggested by the group think or discovered on my own (like beef up the main gear attachments and adding RF chokes). Many of the mods were likely not needed, but were implemented during the early phase of this forum when the real cause of the crashes was unknown. None were hard to do.
                                        I love this EDF!
                                        Aside: Some of you in the past have asked how well the batteries have held up. The Admiral Pro 6000 50C batteries put into service 04/2020 have finally started to show signs of their 14-month age. All have a very slight puffing and the internal resistance readings are starting to creep up. Time to spend some $$$. They've supported a large number of flights with the AL37, F-4 and MiG. I got my money's worth outa these (charged at 4.5 amps, consumed about 4000 mAh with a typical flight profile, never charged below a 50F outside air temp, no cool down after a flight...put them right back on charge upon landing).
                                          • 8755
                                          Happily pushing past 1,000 flights and going strong courtesy of multiple band aid fixes. The main one I did not do was glass the FFSs. But, that’s my choice.
                                          By my count, I did 15 band aid mods suggested by the group think or discovered on my own (like beef up the main gear attachments and adding RF chokes). Many are likely not needed but were implemented during the early phase of this forum when the real cause of the crashes was unknown. None were hard to do.
                                          I love this EDF!
                                          That in itself, may be the critical factor in your success with this plane.
                                          That's astonishing! Between this plane and your AL-37, how do you find the time to fly so much and are your thumbs worn down?
                                          Something must be working for you but perhaps the only one that really made the difference was NOT flying fast with flaps down.
