    There is a little voice now saying "you need the Mig too".
      Yeah, since August I've purchased this Mig, Ta-152, Tigercat, two Bearcats, F-14, F-15, F-16, F-104 90mm, another F-5, and the upgraded Me-262. Finally had to start hanging planes from the ceiling in the garage! LOL
        Wow Pat! You have been busy. That is quite the fleet in such a short time.
          Yeah, MRC put a serious dent in my bank account late last year! :)
            Oops, just ordered the upgraded 8S Yak-130. :)
              Oops? Yeah right... LOL
              • gooniac33
                The Original Gooniac
                • Jun 2016
                • 1047
                Lots of good flights with the mig at Apollo this past weekend...
                • Topdogzrc
                  MiG Driver
                  • 77
                  Well my friend wanted to test some new settings on his camera by tracking my MiG, but for some reason the video quality isn't that great.
                  Anywho, here is me throwing the MiG around for a DBF demo.
                  • Boots Whirlygig
                    • 560
                    • Granville Ohio USA
                    Are you running the stock power in that MIG?
                    I'm impressed with the performance, and you fly it very scale like. That vertical!
                    • Topdogzrc
                      MiG Driver
                      • 77
                      She's totally stock with an Admiral 5000 mAh and an AR8000 on a DX9.
                      She's a totally fun flyer and I'm glad I got it to replace my LX MiG-29. I can actually fly it hard without worry of shedding a wing or blowing something apart now :)
                      • bradl4648
                        Your Motion RC CS Team Rep
                        • 369
                        I thought I would do my review thanks for reading and hope this helps all!!
                        Mig 21 review and build
                        Received the plane in great shape from UPS that is a great start for sure.
                        As usual packaged in a clam shell foam core . That is actually nice for them to do so well protected.
                        this plane is gorgeous in that plastic glaring back almost do not want to fly it ... NOT!
                        The build
                        So the first thing they want you to do is remove the intake cheater cover off. Then glue the tail end of the fuse to the main body . So they supply a wire with a hook on it this is used to pull the elevator to the battery bay. This is also used for the wing connector wires as well.
                        Install the carbon spars threw the fuse then install The wings. They get screwed on at this point pull all wires threw the fuse. Their is two clear plastic pieces (this made me wounder what it was for ) well they fit on the sides of the inner fuse and covers over the wing wires. You glue that in place 1 for each side. This is used to stop any air flow loss. Now use the long wire and pull all wing wires to the battery compartment. I used the bread ties to make the wires neater in the plane yes zip ties work to (hay these were free!) Now re glue the cheater cover back on I used the supplied glue.
                        Now screw on the elevators and hook the pushrods up and that is were I got my first glitch. On mine the pushrods were actually to long on both sides. As you realise to long is not an issue but to short and that's a problem. I just straightened out the z-bend and used my z-bender and fixed it simple as honey.
                        Next was install the rudder then pull wire to the nose with the rod again. use 4 screws to fasten this down.
                        Now glue the pylons to the wings and wing fence, antenna ,plastic part F-G and fin. On the carbon rod , antenna ,nose cone I choose to not glue them on for storage and transporting they will break I now it.
                        Radio setup
                        Elevator, ailerons and rudder are all identical
                        Low 50 expo 30-50
                        Med 72 expo 30-50
                        High 100 expo 30-50
                        Flaps
                        Put the flap servo speed to 4-5 second delay
                        Take off flaps 30% up elevator 10% up
                        Landing 45-50% up elevator 15% up
                        The idea is to not have to use any up elevator on landings. You want to come in high alpha at a 45 degree attitude. You only need to use throttle and ailerons possible rudder but not elevator until you flair. If you start falling use throttle if you rise decrease throttle that simple.
                        Flight
                        I will add this once the weather corporates with me to do so so stay tuned!
                        PROS
                        this plane went to gether fairly nicely with some glitches
                        the over all look is fantastic
                        I like not having the gear doors on this just another thing that can go wrong so that's cool for me.
                        CONNS
                        This is the first time I have some real issues they are minor just need to be brought up.
                        I know the wings are small but once you put the wings on and glue the plastic pieces in the fuse the wing can never be taken off. (remedy I will bye some servo wire connectors m/f and cut the wires at the wing attachment points and that will fix it) .( ADMSERVCONNSET)
                        On mine I had to do some rebending on both elevator pushrods (not a big issue just saying)
                        Overview
                        Other then the small issues this plane is fantastic and once the weather breaks this baby is going mach2!!! OK what ever it will do is fine .
                        I think this is a sure beauty and will keep you up to date
                          A little eye candy.... Just having fun experimenting.
                            I know I asked on RCG, but can I assume you're using some kind of powder ejection like you are working on for the A-10?
                            • ryramZ
                              Pilot Ryan
                              • Dec 2012
                              • 814
                              That looks awesome!
                                You are warm Pat... I hope to debut a functional version at NEFI.
                                Thanks Ryan.
                                  Thanks Ryan.
                                  Now don't tease us..........cause when I meet up with you at NEFI the first thing out of my yap will be show me that AB Dude LOL
                                    I definitely hope to be able to do that.
                                    • jay bennett
                                      • 33
                                      what programmer can I use to change the setting on the esc, I have two flights on mine and it seems under powered, will the inrunner that freewing sell make it any quicker?. I fly from grass and it takes forever to get to flying speed and when in the air it does not seem to get going and the new nano tech 5000 only get two mins and have 26% left is this correct? I have had a 90mm stinger from the same grass and it went like a rocket so I was expecting the same sort of performance.
                                      • bill34207
                                        Jet Junkie
                                        • 455
                                        • Bradenton, Florida
                                        Something is definitely amiss Jay. The Mig is a rocket compared to the Stinger 90. Considering the % left in your packs after only two minutes I'd be suspect of them. You might want to hook up a watt meter and do some static testing. Sounds a lot like your pack(s) might be sagging under load.
                                        How old/new are they? It takes about 5 cycles to get a lipo broken in and working at full capacity.
                                        As for programmer, I don't know of one but the manual is available and it can be set with your radio.
                                        • Shirty
                                          Hobby Squawk Water Boy
                                          • 1067
                                          • Perth, Australia
                                          Pic from the weekend. ::) agreed, check your esc settings as well jay. As an example, having brake on, will reduce your watts by at least 20%. The esc should be set up fine, I've never read of a freewing one needing changes but in other models it's got to me with brake set as on.
                                          Click image for larger version  Name:	IMG_1090.JPG Views:	2 Size:	313.4 KB ID:	73733
