    Ah, then you saw Vic and Tony put on a show with it at AEF! Glad you're enjoying one of our biggest releases ever.
    • AceMigKiller
      Insta: Check5_Av8r
      • 175
      Already looking forward to bringing this and other MRC birds out for Arizona Electric Festival 2018. ;)
      Vic
      • bill34207
        Jet Junkie
        • 455
        • Bradenton, Florida
        Two more flights for this one today and shot hat cam video of both. Kind of noisy on the 2nd video as the neighboring drag strip was in full swing today.
        • Vasaro
          • Oct 2017
          • 22
          Sold a couple of planes so I can buy the Avanti. Two last questions before I pull the trigger. Do I have to use the 4000 pro or is the regular admiral 4000 fine? What's the difference in fligh time between the two?
          the place were I fly has a weird configuration were I can take off a paved road but need to land on the grass field. Most of the time the field has big holes ( no idea what animal or human is making them) so I prefer belly landing my rebel rather than loose a retract. Could I belly land the Avanti?
          • bill34207
            Jet Junkie
            • 455
            I would say yes to belly landing. It has a ply spine running the full length of it's belly.
            As for battery I run 5500's in mine and get around 4 minutes.
              • 7333
              I run a 4000, 4000 PRO and a 5000. Get a bit more flight time with the 5000 of course, not much if any difference with the PRO vs the regular. In the future, I'm thinking 4500 would be ideal. If I ever dump the 6s system in the Tomahawk, CB uses these and WOW!! Plus the'd be great in the Spitfire and any other 6s bird lay my hands on.
              • Topshot19
                Pilot
                • 189
                • logan utah
                Does everyone’s gear door actually close all the way ?
                • fhhuber
                  • Aug 2015
                  • 1476
                  Often some minor tweaking to get the doors to close right without interfering with the retract operation.
                  • Porkster
                    • 290
                    • Suffolk, UK
                    forgive me if i'm wrong, but it does look like your airframe around the nose area is bent so its not likely to close properly? When mine was new it used to close pretty well and the gear doors would almost overlap each other. The doors on mine came off on a rough field landing and I never bothered putting them back on.
                      • 7333
                      I am the champion nose bender of the AvantiLOL
                      My gear doors, which have been broken and reglued and reinforced, don't close too badly, I had to play with the spring and also, I had to crack the fuse open and repair and reset the plastic gear mount, Check to see if that is loose. What happens is that the gear cannot pull the spring all the way down and the spring keeps the gear from fully retracting.
                        • 7333
                        Looking at the picture again, it DOES look like the gear is not retracting fully, I'll bet thats your problem.
                        Out with the knife and the lighter fluid. The lighter fluid will soften the glue but its a wiggle and pull process that took some time. If you go that route, check the piece over and make sure that it's not cracked or damaged. Use some IPA to clean up the lighter fluid and reglue it with Gorilla Glue. You don't have to crack the fuse completely, just back far enough to get that piece out.
                        I'm eventually going to get another one,probably the kit version and put the motor and whatever into it, once I've got the hang of landing her. I'm a heck of alot better than I was thanks to the boys at Nefi, but every once in awhile I do a Grossman landing. The guys at the field don't even get excited about it any more!!
                          • 8749
                          Mine sort of looked like that (but not as bad) when it was brand new. After tinkering with the spring, it's been fine since. On mine, it depended on whether the spring went around the strut above or below that "knuckle". Rotating the spring ends and then re-tightening the screws did the trick. This ensured that the spring always ended up where it needed to be when the strut pushed on it. You have to experiment. If the doors don't close, belly landing won't be pretty.
                          • Topshot19
                            Pilot
                            • 189
                            • logan utah
                            Ya it’s my gear not retracting all the way. The plastic piece the gear sits on was getting wobbley from coming un glued so I glued it back down. So I’ll just have to play with it. That piece doesn’t look very friendly to take out. I just lifted it up a little and shot some glue under it.
                              • 7333
                              It isn't, like I said, it involves splitting the fuse and I don't see a spare part available.. I'll contact Mr Alpha and see if this is something that is common and whether there is something in the works to make it stronger. Besides better pilots that is!!!
                              • Vasaro
                                • Oct 2017
                                • 22
                                Just put my Avanti together but having a hard time balancing it with my admiral 4000. Could someone post pictures of their placement please. I know every plane is different but having a reference would be helpful
                                Thanks!
                                • Vasaro
                                  • Oct 2017
                                  • 22
                                  Looks like it balances upside down with the battery aligned with the front of the tray. Does that sound right?
                                  • HANGER FIFTYONE
                                    Pylon Racer
                                    • 27
                                    • Spring Hill ; Florida
                                    that is exactly where mine balances too.https://youtu.be/7v-XHRn5U8k
                                    Kenny
                                    • Vasaro
                                      • Oct 2017
                                      • 22
                                      Where are you placing your receiver since there is no space between the battery and the connector box
                                      • HANGER FIFTYONE
                                        Pylon Racer
                                        • 27
                                        across the very front of the compartment next to / on top of the connector board ; see video https://youtu.be/7v-XHRn5U8k
                                        Kenny
                                        • TSchwyn
                                          • Dec 2017
                                          • 11
                                          • Bluffton, Indiana
                                          My Avanti arrives Monday. If I add Elevator to flap mixing, do the elevators go up when flaps go down?
                                          Thanks for the input!
                                          Tom
