  • Awesome, thank you Evan.
    • Pardon me for asking a question and offending the keepers of all toy airplane knowledge
      • No. You asked in how many threads? I see at least three!
        • A little aerobatic formation practice through loops and barrel rolls in a Zeus vs Avanti S with afterburner at dusk. Feeling lucky there were close calls but no mid-air collision
          • very nice video amazing landing with.fpv,you got skills bro
            • Hi,
              How Can i find out the serial number of Freewing Avanti S V2 airplane that i bought from motionrc? i wrote motionrc more than five times, but i could not get an answer. I need to submit this serial number to the cıvıl aviation center to enroll the airplane. Moreover, since the airplane is at the custom now, i can not check on itself. To complete custom clearance process, i need to submit serial number to the civil aviation center in Türkiye, and then i can get the airplane from the custom. Please help me.
              • They don't have serial numbers.
                • Hello again!
                  Tomorrow I'm going to attempt to re-maiden my repaired Avanti. Planning on two lunchtime flights with 6S 4000mAh 65C packs (approx. 650g each).
                  For the tail sit test - if the plane passes this test (sits on the tail and slightest push on the nose brings it down) can a newbie safely take off without a gyro, or will it be super sensitive on the elevator?
                  This is the first flight after repairs so I want to take off without gyro and enable it later in the flight when I have some altitude.
                  I'll be using 60/80/100 rates all at 35% expo (NX10).
                  • Sounds good. Maybe make it touch nose heavier for the first flight.
                    • Perfect - Thanks !
                      Finally a day with lower temps, low humidity and low wind :)
                      • I have a lot if Freewing scale EDF .Decided to have a go at a sports jet .My question is the 80mm Avanti or the 70mm Vulcan ?
                        • Avanti. Best all around sport jet made. If you then want a more pattern ship type sport plane Zeus or Vulcan depending on budget. Want more of a 3D fun plane, the new Ares.
                          • Just brought the Avanti V2 .In the bits and pieces bag where the screws etc are .There is a piece of ply wood ,anyone where that goes or what it is use for ???
                            • Originally posted by Captain Moron View Post
                              You gotta picture? Does it have a small pre-drilled hole at each end? This may be for holding the ESC in place.
                              • Had me thinkin... but reckon ur right viper
                                  It's the aft end of the battery tray. Look for the foam pocket with the same size
                                  • I've added an 18th nozzle style to the set for the Avanti. This one is styled after the P&W F100 engine's nozzle on the F-15.
                                    Dress up the rear end of your Avanti.
                                    The rear of the FW Avanti S looks unfinished. Here is a set of nozzles for the 80mm Avanti S, in a variety of styles from civilian noise abatement to MiG to F-4 to f-15, F-16, variable geometry to F-35 stealth, and fantasy.Print parameters are not important - choose infill and wall thickness according to weight needs.
                                    • Hola!!!! Tengo una consulta sobre el AVANTI de FREEWING en su versión V2,es posible poderlo volar con baterias de 6s 3300 mah 60c? Cocretamente son estas baterías https://www.amazon.es/HRB-3300mAh-Qu...zcF9hdGY&psc=1
                                      Se que que cuanto más mah más tiempo de vuelo obviamente,pero son las que tengo disponibles actualmente para destinar a este avión.La duda también es por tema peso,que no se si serán demasiado ligeras para este avión.
                                      saludos pilotos!!!
                                      • You can but you’ll have short flight time and it will be very hard on the batteries. Weight won’t be a problem.
                                          Ok muchas gracias por responder
                                          saludos!!
